PotatoChip
fsutil dirty query returned both C: and D: drive as Dirty.
Desc of the problem and other information:
First started off about 6 months ago, my pc has 2 drives, C: and D: with D: being empty, nothing stored, not used for anything.
started storing files and within some time there was about a full drive of files,music, programs etc
A program (osu! a music game) was running on D: and froze. After 10 mins of freezing, ctrl+alt+del and power button not working, i stupidly decided to switch it off by the wall.
After restarting the PC, nothing much was different.
A few days later, some songs began to freeze and fail to play.
I checked it out, when clicked, it says cannot play on WMP.
some time later, some winrar files began to fail to open/extract files from. the error message was "Error, cyclic redundancy check"
after many weeks, more and more files began getting this "cyclic redundancy check" error. i have searched online and performed CHKDSK many times with /f and /r with no hope.
Downloaded malware bytes and done many deep scans and found nothing
Used Norton 360 and deep scans, etc, still nothing
reluctant to by a new hard drive, i moved most of the existing files to my C: drive...
some corrupted files such as .mp3/.iso and some other files could not be copied, they were deleted.
some small files took a LONG time to copy across, which was worrying.
after that, i performed the "fsutil dirty query" check on both drives daily. D: is Dirty, C: is NOT dirty.
Until a week ago, i was downloading some files via bit torrent which returned a "cyclic redundancy check" error.
after a few days, i turned on my PC, something popped up, a message saying;
wmpshare.exe directory xx/xx/xx/filename.mp3 is corrupt. number of these messages increased as the days passed
and soon some files were unable to be opened.
tried checkdisk again, fixed nothing.
Any advice?
also, does moving a corrupt/infected file to a clean drive "infect" the drive/ make it corrupt?
(I know some corrupt files cant be copied, but some did...i think...)
I have 2 checkdisk logs available, done between a few days to see if the corruption has "spread" as well as a testdisk log
Any advice?
