Hi and welcome to the Forum:
You'll have to wait for a Crash Dump specialist to analyze your Dump files but there are a few things you can do in the meantime.
First, programs like driver booster2, iobit malware fighter are loaded with Spyware viruses, and should
NEVER be used. Most likely they are the cause of your BSODs--a very common occurrence. Drivers should always be replaced or updated manually, especially for video and hard drive devices. There are tools that are used by us Computer professionals but those you listed are not among them--and they require expert skills to use.
Did you recently attempt a Win10 upgrade on that machine? If so, what version of Windows did you upgrade from? (for example, Win7, Win8, Win8.1 or earlier).
Hopefully, you have or made Factory Recovery Discs for that ASUS laptop. Is this the case?
Before proceeding you'll need to have those discs. Also, before proceeding, you'll need to make sure you have all your Personal Data
BACKED UP TO EXTERNAL MEDIA FIRST!! THIS WOULD INCLUDE DOCUMENTS, PHOTOS, MUSIC, VIDEOS, EMAILS, ETC. THAT CANNOT BE REPLACED IF YOUR TROUBLESHOOTING KILLS YOUR LAPTOP! Once you have determined if you have Recovery Discs and a recent backup of your data, you can proceed with attempting to repair your laptop. This won't be a comprehensive repair list, as we need to wait for the Crash Dump Analyst as I stated earlier, however, some simple things can be done first. I would go into
PROGRAMS in Control Panel and remove the driver booster2 and malware fighter first. Then go to MALWAREBYTES.ORG and download the free
MALWAREBYTES program. Install the program and run a full scan to remove any spyware viruses on your laptop. Bitdefender will not do a good job on spyware virus removal. Use the Removal tool and remove all spyware viruses found. Rerun
MALWAREBYTES until it comes back with NO THREATS FOUND (0 viruses).
Next, download the free
JUNKWARE REMOVAL TOOL, you can google it, and install/run this program. It will remove stuff clogging up your Windows that are not virus specific.
After running these 2 tools, reboot your system and see if your BSODs abate. This may take a couple of days of turning on and off the laptop to determine. If the BSODs don't come back you've fixed your problem!
These are general steps, and may not fix your problem, especially if your driver booster program scrambled your drivers.
If the CDA (Crash Dump Analyst) here on the Forum can indentify the corrupted drivers, he can assist you with reinstalling them. If the problem continues to occur after that, you might then pursue reinstalling the original Windows version that came pre-installed on your ASUS laptop from the factory. From there, you can re-upgrade to Win10. This should fix the problem. If it doesn't you might consider performing the upgrade from a Win10 ISO file disc or a purchased Win10 retail boxed disc as opposed to the Win10 upgrade download from Microsoft app store.
Lastly, if you do get your laptop working again or go through the Windows reinstall and Win10 re-upgrade, I suggest you look at a better Anti-Virus program; such as Avast or Norton.
Good luck,
<<<BIGBEARJEDI>>>
