Interrupt Exception Not Handled - Random
Discussion in 'Windows 7 Blue Screen of Death (BSOD)' started by NeverWinner, Dec 30, 2010.
  1. NeverWinner
    NeverWinner New Member
    Dec 30, 2010
    20
    I built this computer several months ago and have already tackled 2 other BSODs. This 3rd one is annoying me a great deal so any help is much appreciated!
    I've barely used the computer because I don't see it ready to use with all these problems. I'm not an overclocker. I just want this computer to run neatly with the hardware I've shoved into it, on a clean Windows 7.
    I haven't ever had any boot problems. All the minor issues and 2 BSODs occurred at random times or during Windows 7 Backup. This may sound unrelated but I'm beginning to think it's due to the setup of my two 1TB SATAIII Hard Drives (AHCI).
    memtest86+ was all green.
    I'm hoping a genius BSOD evaluator can help me!
    Thanks in advance!
    System Specs:
    Windows 7 Professional x64 - MSDNAA.
    Motherboard: ASUS P6X58D-E
    CPU: i7 930
    RAM: Corsair XMS3 6GB Tri 1600Mhz
    HDD: 2x 1TB Western Digital Caviar Black SATAIII 6Gb/s
    GFX: MSI GeForce 460GTX 768MB GDDR5
    PSU: Corsair HX850W
    CASE: Coolermaster HAF932
  2. Captain Jack
    Captain Jack Honorable Member
    Mar 6, 2010
    1,984
    Hello and Welcome !
    Run a Hardware Diagnostic (Memory and Hard Drive) follow this link for instructions Hardware Diagnostic !! « Captain Debugger
    Then Enable Driver Verifier Driver Verifier - Enable and Disable - Windows 7 Forums
    Then use this Tool and run all the option expect Dump files and attach the files here SF Diagnostic Tool v4
    Bugcheck:
    INTERRUPT_EXCEPTION_NOT_HANDLED (3d)
    Arguments:
    Arg1: fffff880030aff60
    Arg2: 0000000000000000
    Arg3: 0000000000000000
    Arg4: fffff80003069780
    Debugging Details:
    CUSTOMER_CRASH_COUNT:  1
    BUGCHECK_STR:  0x3D
    PROCESS_NAME:  System
    CURRENT_IRQL:  5
    EXCEPTION_RECORD:  fffff880030b06f8 -- (.exr 0xfffff880030b06f8)
    Cannot read Exception record @ fffff880030b06f8
    TRAP_FRAME:  fffff880030b07a0 -- (.trap 0xfffff880030b07a0)
    Unable to read trap frame at fffff880`030b07a0
    LAST_CONTROL_TRANSFER:  from fffff80003070ca9 to fffff80003071740
    STACK_TEXT:
    fffff880`030af6a8 fffff800`03070ca9 : 00000000`0000003d fffff880`030aff60 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
    fffff880`030af6b0 fffff800`0306cfe9 : 00000000`00008fc1 fffff880`056b5e53 fffff880`030aff60 fffff800`0309e668 : nt!KiBugCheckDispatch+0x69
    fffff880`030af7f0 fffff800`0309740d : fffff880`011752f4 fffff880`0117358c fffff880`01161000 fffff880`030b06f8 : nt!KiInterruptHandler+0x29
    fffff880`030af820 fffff800`0309ea90 : fffff800`031c091c fffff880`030af898 fffff880`030b06f8 fffff800`03001000 : nt!RtlpExecuteHandlerForException+0xd
    fffff880`030af850 fffff800`030ab9ef : fffff880`030b06f8 fffff880`030aff60 fffff880`00000000 fffffa80`0681a0d8 : nt!RtlDispatchException+0x410
    fffff880`030aff30 fffff800`03070d82 : fffff880`030b06f8 fffffa80`06881800 fffff880`030b07a0 00000000`00000040 : nt!KiDispatchException+0x16f
    fffff880`030b05c0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExceptionDispatch+0xc2
    STACK_COMMAND:  kb
    FOLLOWUP_IP:
    nt!KiInterruptHandler+29
    fffff800`0306cfe9 90              nop
    SYMBOL_STACK_INDEX:  2
    SYMBOL_NAME:  nt!KiInterruptHandler+29
    FOLLOWUP_NAME:  MachineOwner
    MODULE_NAME: nt
    IMAGE_NAME:  ntkrnlmp.exe
    DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
    FAILURE_BUCKET_ID:  X64_0x3D_nt!KiInterruptHandler+29
    Followup: MachineOwner
    Hope this helps,
    Captain
  3. cybercore
    cybercore New Member
    Jul 7, 2009
    15,826
    Memory is not set right, should be 9-9-9-24. Load optimized defaults in the bios.
    Update Marvell:
    mv91xx.sys Fri Dec 25 01:45:39 2009
    Marvell magni
    mvxxmm.sys Fri Dec 25 01:45:15 2009
    Marvell Flash Technologies
    Update motherboard driver for NEC USB 3.0:
    nusb3hub.sys Tue Feb 23 21:10:14 2010
    Crash Dump
    Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
    Loading Dump File [C:\Documents and Settings\XPMUser\My Documents\123010-18330-01.dmp]
    Symbol search path is: SRV*C:\Documents and Settings\XPMUser\My Documents\Symbols*http://msdl.microsoft.com/download/symbols
    Executable search path is:
    Windows 7 Kernel Version 7600 MP (8 procs) Free x64
    Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
    Machine Name:
    Kernel base = 0xfffff800`03001000 PsLoadedModuleList = 0xfffff800`0323ee50
    Debug session time: Thu Dec 30 11:27:29.575 2010 (UTC - 5:00)
    System Uptime: 0 days 0:17:16.635
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    BugCheck 3D, {fffff880030aff60, 0, 0, fffff80003069780}
    Probably caused by : ntkrnlmp.exe ( nt!KiInterruptHandler+29 )
    5: kd> !analyze -v
    Arguments:
    Debugging Details:
    CONTEXT:  fffff880030aff60 -- (.cxr 0xfffff880030aff60)
    rax=0000000000000000 rbx=fffffa8006881800 rcx=fffffa8006881950
    rdx=fffffa800686b9d8 rsi=0000000000000040 rdi=fffffa800681a0d8
    rip=fffff80003069780 rsp=fffff880030b0938 rbp=fffffa800686b9a8
     r8=fffff880030b0960  r9=0000000000000000 r10=fffffa800686b9a8
    r11=0000000000000000 r12=fffffa800681d270 r13=fffffa800681a0d8
    r14=fffffa80062f0800 r15=0000000000000000
    iopl=0         nv up ei pl nz na pe nc
    cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00000202
    nt!DbgBreakPoint:
    fffff800`03069780 cc              int     3
    Resetting default scope
    BUGCHECK_STR:  0x3D
    CURRENT_IRQL:  5
    LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff80003069780
    STACK_TEXT:
    STACK_COMMAND:  kb
    FOLLOWUP_IP:
    MODULE_NAME: nt
    Drivers
    fffff880`05847000 fffff880`05885000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
    fffff880`00f6d000 fffff880`00fc4000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
    fffff880`03ee2000 fffff880`03f6c000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
    fffff880`058e2000 fffff880`058f8000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
    fffff880`01198000 fffff880`011a3000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
    fffff880`05885000 fffff880`0588d000   ASACPI   ASACPI.sys   Wed Jul 15 23:31:29 2009 (4A5E9F11)
    fffff880`07671000 fffff880`0767c000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
    fffff880`00fd7000 fffff880`00fe0000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
    fffff880`00dc9000 fffff880`00df3000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
    fffff880`05616000 fffff880`0583a000   athrx    athrx.sys    Wed Mar 31 21:54:32 2010 (4BB3FCD8)
    fffff880`03d91000 fffff880`03d98000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
    fffff880`044b4000 fffff880`044c5000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
    fffff880`0459e000 fffff880`045bc000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
    fffff960`00740000 fffff960`00767000   cdd      cdd.dll      unavailable (00000000)
    fffff880`03d31000 fffff880`03d5b000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
    fffff880`00e9e000 fffff880`00f5e000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
    fffff880`0143a000 fffff880`0146a000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
    fffff880`00d0f000 fffff880`00d6d000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
    fffff880`014c8000 fffff880`0153b000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
    fffff880`058d2000 fffff880`058e2000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
    fffff880`06b21000 fffff880`06b2f000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
    fffff880`04413000 fffff880`04496000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
    fffff880`04496000 fffff880`044b4000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
    fffff880`03ea6000 fffff880`03eb5000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
    fffff880`017ea000 fffff880`01800000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
    fffff880`0fe75000 fffff880`0fe97000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
    fffff880`06b2f000 fffff880`06b39000   dump_diskdump dump_diskdump.sys Mon Jul 12 23:32:05 2010 (4C3BDE35)
    fffff880`06bc5000 fffff880`06bd8000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
    fffff880`06b39000 fffff880`06bc5000   dump_mv91xx dump_mv91xx.sys Fri Dec 25 01:45:39 2009 (4B345F93)
    fffff880`03d16000 fffff880`03d1e000   dump_mvxxmm dump_mvxxmm.sys Fri Dec 25 01:45:15 2009 (4B345F7B)
    fffff880`06b15000 fffff880`06b21000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
    fffff880`05289000 fffff880`0537d000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
    fffff880`0537d000 fffff880`053c3000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
    fffff880`01000000 fffff880`01014000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
    fffff880`011a3000 fffff880`011ef000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
    fffff880`0154c000 fffff880`01556000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
    fffff880`01400000 fffff880`0143a000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
    fffff880`01556000 fffff880`015a0000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
    fffff800`035dd000 fffff800`03626000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
    fffff880`053c3000 fffff880`053e7000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
    fffff880`0680e000 fffff880`06827000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
    fffff880`06827000 fffff880`0682f080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
    fffff880`06800000 fffff880`0680e000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
    fffff880`03c47000 fffff880`03d0f000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
    fffff880`017e1000 fffff880`017ea000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
    fffff880`0588d000 fffff880`058ab000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
    fffff880`044eb000 fffff880`04501000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
    fffff880`058ab000 fffff880`058ba000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
    fffff800`00bc2000 fffff800`00bcc000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
    fffff880`059ba000 fffff880`059fd000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
    fffff880`013e1000 fffff880`013fb000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
    fffff880`0178c000 fffff880`017b7000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
    fffff880`0527f000 fffff880`05284200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
    fffff880`0688f000 fffff880`068a4000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
    fffff880`0684b000 fffff880`0686e000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
    fffff880`00cb7000 fffff880`00cfb000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
    fffff880`0683d000 fffff880`0684b000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
    fffff880`058ba000 fffff880`058c9000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
    fffff880`06830000 fffff880`0683d000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
    fffff880`00e81000 fffff880`00e9b000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
    fffff880`03d5b000 fffff880`03d88000   MpFilter MpFilter.sys Sat Mar 20 01:58:08 2010 (4BA463F0)
    fffff880`045bc000 fffff880`045d4000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
    fffff880`03eb5000 fffff880`03ee2000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
    fffff880`0146a000 fffff880`014b8000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
    fffff880`045d4000 fffff880`045f7000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
    fffff880`00fe0000 fffff880`00feb000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
    fffff880`03c00000 fffff880`03c0b000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
    fffff880`00fcd000 fffff880`00fd7000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
    fffff880`01014000 fffff880`01072000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
    fffff880`03e9b000 fffff880`03ea6000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
    fffff880`017cf000 fffff880`017e1000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
    fffff880`010d5000 fffff880`01161000   mv91xx   mv91xx.sys   Fri Dec 25 01:45:39 2009 (4B345F93)
    fffff880`01190000 fffff880`01198000   mvxxmm   mvxxmm.sys   Fri Dec 25 01:45:15 2009 (4B345F7B)
    fffff880`0163a000 fffff880`0172c000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
    fffff880`0591c000 fffff880`05928000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
    fffff880`068a4000 fffff880`068b7000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
    fffff880`05928000 fffff880`05957000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
    fffff880`0fe00000 fffff880`0fe15000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
    fffff880`03e00000 fffff880`03e0f000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
    fffff880`03f6c000 fffff880`03fb1000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
    fffff880`0172c000 fffff880`0178c000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
    fffff880`03c0b000 fffff880`03c1c000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
    fffff880`03e8f000 fffff880`03e9b000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
    fffff800`03001000 fffff800`035dd000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
    fffff880`0123e000 fffff880`013e1000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
    fffff880`03d88000 fffff880`03d91000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
    fffff880`05267000 fffff880`0527f000   nusb3hub nusb3hub.sys Tue Feb 23 21:10:14 2010 (4B848A86)
    fffff880`04501000 fffff880`04531000   nusb3xhc nusb3xhc.sys Tue Feb 23 21:10:16 2010 (4B848A88)
    fffff880`10b31000 fffff880`10b32180   nvBridge nvBridge.kmd Fri Jul 09 17:07:54 2010 (4C378FAA)
    fffff880`0fe15000 fffff880`0fe38000   nvhda64v nvhda64v.sys Mon Jun 21 18:07:25 2010 (4C1FE29D)
    fffff880`0fe9f000 fffff880`10b30e00   nvlddmkm nvlddmkm.sys Fri Jul 09 17:15:58 2010 (4C37918E)
    fffff880`04533000 fffff880`04586000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
    fffff880`03fba000 fffff880`03fe0000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
    fffff880`00e40000 fffff880`00e55000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
    fffff880`00e00000 fffff880`00e33000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
    fffff880`00e6a000 fffff880`00e71000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
    fffff880`00e71000 fffff880`00e81000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
    fffff880`0153b000 fffff880`0154c000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
    fffff880`07435000 fffff880`074db000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
    fffff880`0fe38000 fffff880`0fe75000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
    fffff880`00cfb000 fffff880`00d0f000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
    fffff880`058f8000 fffff880`0591c000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
    fffff880`05957000 fffff880`05972000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
    fffff880`05972000 fffff880`05993000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
    fffff880`05993000 fffff880`059ad000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
    fffff880`03e3e000 fffff880`03e8f000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
    fffff880`059ad000 fffff880`059b8000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
    fffff880`03ddb000 fffff880`03de4000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
    fffff880`03de4000 fffff880`03ded000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
    fffff880`03ded000 fffff880`03df6000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
    fffff880`01600000 fffff880`0163a000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
    fffff880`04586000 fffff880`0459e000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
    fffff880`068c8000 fffff880`06b14f80   RTKVHD64 RTKVHD64.sys Tue Jul 06 06:05:16 2010 (4C32FFDC)
    fffff880`01161000 fffff880`01190000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
    fffff880`074db000 fffff880`074e6000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
    fffff880`017c7000 fffff880`017cf000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
    fffff880`076dc000 fffff880`07772000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
    fffff880`07525000 fffff880`0758c000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
    fffff880`074e6000 fffff880`07513000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
    fffff880`059b8000 fffff880`059b9480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
    fffff880`01800000 fffff880`019fd000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
    fffff880`07513000 fffff880`07525000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
    fffff880`03c3a000 fffff880`03c47000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
    fffff880`03c1c000 fffff880`03c3a000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
    fffff880`03e2a000 fffff880`03e3e000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
    fffff960`004f0000 fffff960`004fa000   TSDDD    TSDDD.dll    unavailable (00000000)
    fffff880`044c5000 fffff880`044eb000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
    fffff880`05600000 fffff880`05612000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
    fffff880`04531000 fffff880`04532f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
    fffff880`05256000 fffff880`05267000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
    fffff880`10b96000 fffff880`10bf0000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
    fffff880`05200000 fffff880`05256000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
    fffff880`06bd8000 fffff880`06bf3000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
    fffff880`053e7000 fffff880`053f4000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
    fffff880`00e33000 fffff880`00e40000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
    fffff880`03d98000 fffff880`03da6000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
    fffff880`03da6000 fffff880`03dcb000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
    fffff880`017b7000 fffff880`017c7000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
    fffff880`00e55000 fffff880`00e6a000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
    fffff880`00d6d000 fffff880`00dc9000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
    fffff880`015a0000 fffff880`015ec000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
    fffff880`0583a000 fffff880`05847000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
    fffff880`03fe0000 fffff880`03ff6000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
    fffff880`03e0f000 fffff880`03e2a000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
    fffff880`03dcb000 fffff880`03ddb000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
    fffff880`00c00000 fffff880`00ca4000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
    fffff880`00f5e000 fffff880`00f6d000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
    fffff880`03fb1000 fffff880`03fba000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
    fffff960`00010000 fffff960`00320000   win32k   win32k.sys   unavailable (00000000)
    fffff880`058c9000 fffff880`058d2000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
    fffff880`00fc4000 fffff880`00fcd000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
    fffff880`0686e000 fffff880`0688f000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
    fffff880`07772000 fffff880`077a3000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
    fffff880`10b33000 fffff880`10b96000   yk62x64  yk62x64.sys  Wed Sep 15 10:31:29 2010 (4C90D8C1)
    Unloaded modules:
    fffff880`07600000 fffff880`07671000   spsys.sys
        Checksum:  00000000
        ImageSize:  00071000
        Checksum:  00000000
        ImageSize:  00071000
    fffff880`0146a000 fffff880`01478000   crashdmp.sys
        Checksum:  00000000
        ImageSize:  0000E000
    fffff880`01478000 fffff880`01482000   dump_scsipor
        Checksum:  00000000
        ImageSize:  0000A000
    fffff880`03c8a000 fffff880`03d16000   dump_mv91xx.
        Checksum:  00000000
        ImageSize:  0008C000
    fffff880`03d1e000 fffff880`03d31000   dump_dumpfve
        Checksum:  00000000
        ImageSize:  00013000
  4. NeverWinner
    Dec 30, 2010
    20
    Hi Captain,
    Thanks for your help and apologies for my delayed response.
    I ran MemTest86+ for 8 passes and no problems came about.
    I went through the chkdsk steps (wow, it took a long time to complete) - no errors found.
    I enabled the Driver Verifier and got a BSOD when restarting. I read further down that thread and found out I shouldn't tick the "<unknown>" drivers. I went through it again with the correct settings and restarted with no problems. However, nothing looked different. I'm not sure what that verifier did.
    I have also attached the folder created by the Diagnostic Tool (I wasn't sure what you meant by "expect dump files", sorry :frown:)
    Thanks again for helping!
  5. NeverWinner
    Dec 30, 2010
    20
    Hi Cybercore,
    Thanks to you as well for the help!
    I don't recall changing the memory timings (I don't even know how to :) ). I'm going to head to the BIOS now to try and find it and revert the settings back to default.
    The Marvell drivers are a nightmare. The Asus download site has various drivers listed for my motherboard:
    Marvell 912x Controller Driver V1.0.0.1036
    Marvell 9128 Controller Driver V1.0.0.1034 (WHQL)
    The newer driver (not WHQL) causes BSOD so I've dropped down to the older one that is WHQL and it appears to be fine.
    I can't find a newer driver for NEC USB 3.0 (currently 1.0.20.0).
    Thanks a lot for your help!
    I thought I would be clever and download the latest of each driver separately, as opposed to sticking in the motherboard disc and receiving a load of bloatware. I'm tempted to format, reinstall OS and start again.
  6. Captain Jack
    Mar 6, 2010
    1,984
    Hello,
    How is the Memory timings thing going ? Then there are lot of failures for Windows Update especially on Microsoft Anti Malware engine. I would also recommend you to reboot under Safe Mode and Download Malwarebytes and run a complete scanning. Is the Driver Verifier still running ? If not turn it on and let it run for 36 hours.
  7. NeverWinner
    Dec 30, 2010
    20
    I managed to find the memory timings section in the BIOS and everything was set to AUTO/Default.
    I'm certain it's not malware but I will run that scan anyway just to make sure. It's a clean Windows 7. The only programs installed are Google Chrome, Google Talk, Microsoft Security Essentials.
    I switched off the Driver Verifier since I had no idea what it was doing (should it output anything anywhere? log file?). I'll enable it again and leave it on as you recommend.
    Is it worth formatting and reinstalling everything? As I say, I have nothing to loose - No documents. I'm just worried that I'll end up in the same place again.
    Thanks for your continued help...
  8. Captain Jack
    Mar 6, 2010
    1,984
    Hello,
    Post a screenshot of CPU-Z again we we can see any changes has made. Then Driver Verifier will catch the bad or rouge driver that is crashing your System and record it under the crash dump file no other logs. Turn in on for 36 hours. If we didn't reach anywhere then we could try to reinstall the OS.
    Good Luck !
  9. NeverWinner
    Dec 30, 2010
    20
    CPU-Z shows the same info as the previous screenshot.
    Driver Verifier has been (and still is) running - I am trying to get a BSOD now by running Windows Backup (normally does the trick!).
    I'll post BSOD as soon as I get it.
    Thanks!
  10. NeverWinner
    Dec 30, 2010
    20
    I got the BSOD and have attached the dmp. As expected, it happened during Windows Backup. It finished backing up documents (as always) and began taking image backup. Then came the crash (as always).
    I couldn't boot back up afterwards. It got stuck on "Starting Windows" for 20 mins with no HDD activity. I turned off and on to finally boot into Windows.
    It's not looking good is it?!
    I just can't work out what it is! :mad:
    Always happens during backup (image). Sometimes during just web browsing. Sometimes in idle. Just all so unrelated! I know the cause is always 3rd party software but I'm beginning to blame Windows.
    I'll wait for a reply from someone on here with some advice but at the moment I'm thinking of starting afresh (...and ending up back on this forum with the same problem :zzz: )
    Thanks!
    EDIT: ntoskrnl.exe ?!
  11. cybercore
    Jul 7, 2009
    15,826
    That's system kernel file, don't try to fix it. : )
    Ok, let's see ...
  12. cybercore
    Jul 7, 2009
    15,826
    1. Disable driver verifier - start > verifier.exe /reset
    VERIFIER_ENABLED_VISTA_MINIDUMP
    2. Update drivers as in my 1st post:
    Attach cpu-z memory and spd tabs then.
    Crash Dumps:
    Loading Dump File [F:\a\Minidump\D M P\DMP\010911-26208-01-dmp]
    Machine Name:
    Kernel base = 0xfffff800`03012000 PsLoadedModuleList = 0xfffff800`0324fe50
    Debug session time: Sun Jan  9 09:45:52.607 2011 (UTC - 5:00)
    System Uptime: 0 days 0:00:12.809
    BugCheck A, {26f000520050, 2, 0, fffff800030a22b3}
    Probably caused by : CI.dll ( CI!SHATransform+236 )
    7: kd> !analyze -v
    IRQL_NOT_LESS_OR_EQUAL (a)
    If a kernel debugger is available get the stack backtrace.
    Arguments:
    Arg1: 000026f000520050, memory referenced
    Arg2: 0000000000000002, IRQL
    Arg3: 0000000000000000, bitfield :
    Arg4: fffff800030a22b3, address which referenced memory
    Debugging Details:
    READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800032ba0e0
     000026f000520050
    CURRENT_IRQL:  2
    FAULTING_IP:
    nt!IopCompleteRequest+ae3
    fffff800`030a22b3 488b09          mov     rcx,qword ptr [rcx]
    DEFAULT_BUCKET_ID:  VERIFIER_ENABLED_VISTA_MINIDUMP
    BUGCHECK_STR:  0xA
    IRP_ADDRESS:  ffffffffffffff89
    TRAP_FRAME:  fffff88003368080 -- (.trap 0xfffff88003368080)
    rax=0000000092a54e2c rbx=0000000000000000 rcx=000000000d28520f
    rdx=00000000ed464321 rsi=0000000000000000 rdi=0000000000000000
    rip=fffff88000e75cd6 rsp=fffff88003368210 rbp=00000000488d8660
     r8=00000000a2ee19ae  r9=000000001d7d732f r10=000000003c8d31c8
    r11=00000000e1036a58 r12=0000000000000000 r13=0000000000000000
    iopl=0         nv up ei ng nz na pe nc
    CI!SHATransform+0x236:
    fffff880`00e75cd6 8b7334          mov     esi,dword ptr [rbx+34h] ds:00000000`00000034=????????
    LAST_CONTROL_TRANSFER:  from fffff80003081ca9 to fffff80003082740
    STACK_TEXT:
    fffff880`03367ac8 fffff800`03081ca9 : 00000000`0000000a 000026f0`00520050 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
    fffff880`03367ad0 fffff800`03080920 : 00000000`00000000 fffff980`02c4cee0 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
    fffff880`03367c10 fffff800`030a22b3 : fffff780`c0000000 00000000`00000001 00000000`00020400 fffffa80`08a72f20 : nt!KiPageFault+0x260
    fffff880`03367da0 fffff800`0305f0c7 : 00000000`00000001 fffffa80`05544680 fffff880`03367e00 fffff800`00000000 : nt!IopCompleteRequest+0xae3
    fffff880`03367e70 fffff800`03035bb5 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDeliverApc+0x1d7
    fffff880`03367ef0 fffff800`0309dc44 : 00000000`00000000 00000000`00000000 ffffffff`ffffffff 00000000`00000110 : nt!KiCheckForKernelApcDelivery+0x25
    fffff880`03367f20 fffff800`0308082e : 00000000`00000000 fffff980`03020fcc 00000000`48034a00 00000000`61084c89 : nt!MmAccessFault+0x1844
    fffff880`03368080 fffff880`00e75cd6 : 00ff1525`05000040 e83bc100`7d3ff125 753a488d`8e181000 76d0816f`daa8f5a4 : nt!KiPageFault+0x16e
    fffff880`03368210 fffff880`00e76d0c : fffff880`03368408 fffffa80`6b7bcaca fffff980`fa80b9a4 fffff800`c7a77f75 : CI!SHATransform+0x236
    fffff880`033682a0 fffff880`00e33824 : fffff8a0`005ba500 fffff980`030000f0 00000000`00000000 00000000`00000000 : CI!A_SHAUpdate+0xcc
    fffff880`033682e0 fffff880`00e2bb38 : fffff980`03000198 00000000`00000000 00000000`00000400 0000000a`00001000 : CI!HashpHashBytes+0x40
    fffff880`03368310 fffff880`00e2b281 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : CI!CipImageGetImageHash+0x310
    fffff880`033684f0 fffff880`00e29fbb : 00000000`00000001 fffff880`033687b0 fffff880`033687b0 80000000`00000020 : CI!CipValidateFileHash+0x211
    fffff880`03368660 fffff800`032ed68e : 00000000`00000056 00000000`000fffff fffffa80`08a72f20 00000000`00000000 : CI!CiValidateImageHeader+0x213
    fffff880`03368740 fffff800`032ed57c : 00000000`00000001 00000000`01000000 fffffa80`08a5fd10 00000000`00000000 : nt!SeValidateImageHeader+0x2e
    fffff880`03368780 fffff800`0337dd95 : fffffa80`08a72f20 fffffa80`08a5fd10 00000000`00000001 00000000`00000056 : nt!MiValidateImageHeader+0xa4
    fffff880`03368840 fffff800`03373013 : fffff880`03368aa0 00000000`00000000 fffff880`03368d58 00000000`00000001 : nt!MmCreateSection+0x8c9
    fffff880`03368a50 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!NtCreateSection+0x162
    STACK_COMMAND:  kb
    FOLLOWUP_IP:
    CI!SHATransform+236
    SYMBOL_STACK_INDEX:  8
    SYMBOL_NAME:  CI!SHATransform+236
    MODULE_NAME: CI
    IMAGE_NAME:  CI.dll
    DEBUG_FLR_IMAGE_TIMESTAMP:  4a5be01d
    FAILURE_BUCKET_ID:  X64_0xA_VRF_CI!SHATransform+236
    Drivers:
    fffff880`00f92000 fffff880`00fe9000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
    fffff880`03c21000 fffff880`03cab000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
    fffff880`0115a000 fffff880`01165000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
    fffff880`00e14000 fffff880`00e1d000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
    fffff880`00c2a000 fffff880`00c54000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
    fffff880`02d8b000 fffff880`02d92000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
    fffff880`042b2000 fffff880`042c3000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
    fffff880`02d2b000 fffff880`02d55000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
    fffff880`00e1f000 fffff880`00edf000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
    fffff880`01800000 fffff880`01830000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
    fffff880`00ce4000 fffff880`00d42000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
    fffff880`01468000 fffff880`014db000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
    fffff880`01830000 fffff880`0183e000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
    fffff880`04211000 fffff880`04294000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
    fffff880`04294000 fffff880`042b2000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
    fffff880`03ddb000 fffff880`03dea000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
    fffff880`019e1000 fffff880`019f7000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
    fffff880`0183e000 fffff880`01848000   dump_diskdump dump_diskdump.sys Mon Jul 12 23:32:05 2010 (4C3BDE35)
    fffff880`02d18000 fffff880`02d2b000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
    fffff880`02c84000 fffff880`02d10000   dump_mv91xx dump_mv91xx.sys Fri Dec 25 01:45:39 2009 (4B345F93)
    fffff880`02d10000 fffff880`02d18000   dump_mvxxmm dump_mvxxmm.sys Fri Dec 25 01:45:15 2009 (4B345F7B)
    fffff880`0446b000 fffff880`0455f000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
    fffff880`0455f000 fffff880`045a5000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
    fffff880`011b1000 fffff880`011c5000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
    fffff880`01165000 fffff880`011b1000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
    fffff880`014ec000 fffff880`014f6000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
    fffff880`019a7000 fffff880`019e1000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
    fffff880`018a4000 fffff880`018ee000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
    fffff800`035ee000 fffff800`03637000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
    fffff880`045a5000 fffff880`045c9000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
    fffff880`0199e000 fffff880`019a7000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
    fffff880`042e9000 fffff880`042ff000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
    fffff800`00bbd000 fffff800`00bc7000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
    fffff880`013cb000 fffff880`013e5000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
    fffff880`0105e000 fffff880`01089000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
    fffff880`00c8c000 fffff880`00cd0000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
    fffff880`00c10000 fffff880`00c2a000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
    fffff880`02d55000 fffff880`02d82000   MpFilter MpFilter.sys Sat Mar 20 01:58:08 2010 (4BA463F0)
    fffff880`00c54000 fffff880`00c5f000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
    fffff880`02df0000 fffff880`02dfb000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
    fffff880`00ff2000 fffff880`00ffc000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
    fffff880`01000000 fffff880`0105e000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
    fffff880`03dd0000 fffff880`03ddb000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
    fffff880`0198c000 fffff880`0199e000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
    fffff880`01097000 fffff880`01123000   mv91xx   mv91xx.sys   Fri Dec 25 01:45:39 2009 (4B345F93)
    fffff880`01152000 fffff880`0115a000   mvxxmm   mvxxmm.sys   Fri Dec 25 01:45:15 2009 (4B345F7B)
    fffff880`014f6000 fffff880`015e8000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
    fffff880`03d35000 fffff880`03d44000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
    fffff880`03cab000 fffff880`03cf0000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
    fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
    fffff880`02c00000 fffff880`02c11000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
    fffff880`03dc4000 fffff880`03dd0000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
    fffff800`03012000 fffff800`035ee000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
    fffff880`01228000 fffff880`013cb000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
    fffff880`02d82000 fffff880`02d8b000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
    fffff880`042ff000 fffff880`0432f000   nusb3xhc nusb3xhc.sys Tue Feb 23 21:10:16 2010 (4B848A88)
    fffff880`10b34000 fffff880`10b35180   nvBridge nvBridge.kmd Fri Jul 09 17:07:54 2010 (4C378FAA)
    fffff880`0fea2000 fffff880`10b33e00   nvlddmkm nvlddmkm.sys Fri Jul 09 17:15:58 2010 (4C37918E)
    fffff880`03cf9000 fffff880`03d1f000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
    fffff880`00d75000 fffff880`00d8a000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
    fffff880`00d42000 fffff880`00d75000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
    fffff880`00e0d000 fffff880`00e14000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
    fffff880`00c00000 fffff880`00c10000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
    fffff880`014db000 fffff880`014ec000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
    fffff880`00cd0000 fffff880`00ce4000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
    fffff880`03d73000 fffff880`03dc4000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
    fffff880`02dd5000 fffff880`02dde000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
    fffff880`02dde000 fffff880`02de7000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
    fffff880`02de7000 fffff880`02df0000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
    fffff880`01952000 fffff880`0198c000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
    fffff880`01123000 fffff880`01152000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
    fffff880`0194a000 fffff880`01952000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
    fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
    fffff880`02c2f000 fffff880`02c3c000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
    fffff880`02c11000 fffff880`02c2f000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
    fffff880`03d5f000 fffff880`03d73000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
    fffff880`042c3000 fffff880`042e9000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
    fffff880`0432f000 fffff880`04330f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
    fffff880`045c9000 fffff880`045d6000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
    fffff880`00e00000 fffff880`00e0d000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
    fffff880`02d92000 fffff880`02da0000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
    fffff880`02da0000 fffff880`02dc5000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
    fffff880`018ee000 fffff880`018fe000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
    fffff880`00d8a000 fffff880`00d9f000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
    fffff880`00d9f000 fffff880`00dfb000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
    fffff880`018fe000 fffff880`0194a000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
    fffff880`03d1f000 fffff880`03d35000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
    fffff880`03d44000 fffff880`03d5f000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
    fffff880`02dc5000 fffff880`02dd5000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
    fffff880`00edf000 fffff880`00f83000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
    fffff880`00f83000 fffff880`00f92000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
    fffff880`03cf0000 fffff880`03cf9000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
    fffff880`00fe9000 fffff880`00ff2000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
  13. NeverWinner
    Dec 30, 2010
    20
    I've disabled Driver Verifier now.
    My memory settings are all set to 'default' and 'auto' in BIOS. Should I change them to what you suggest?
    I managed to find a newer version of the Marvell driver (with huge difficulty). ASUS don't have the driver listed and neither does Marvell.
    Source
    I also updated my NEC USB 3.0 Driver which was extremely confusing.
    Updated from
    NEC Electronics USB 3.0 Controller v.1.0.20.0
    to
    Renesas Electronics USB 3.0 Controller v2.0.32.0.
    I restarted and ran Windows Backup (my trusted testing tool) and it completed successfully! So it can be said that progress has been made, but I'm going to give it a week.
    I will be sure to update this thread next weekend!
    Thanks a bunch to cybercore and Captain Jack!
  14. cybercore
    Jul 7, 2009
    15,826
    "Auto" should set them right. If it crashes again though, go into bios and adjust THE TIMINGS only.9-9-9-24.
    Confusing indeed. Should have checked downloads at your motherboard support site.
  15. NeverWinner
    Dec 30, 2010
    20
    Yeah, motherboard downloads page had NEC Electronics USB 3.0 Controller v.1.0.19.0 (even older).
    I don't remember ASUS being this bad. They've changed :(
    Thanks again. I'll confirm system stability next week.
  16. cybercore
    Jul 7, 2009
    15,826
    Thanks and good luck. : )
    [​IMG]
  17. NeverWinner
    Dec 30, 2010
    20
    All is good now. That one driver update seems to have solved everything.
    Thanks for all your help!
  18. cybercore
    Jul 7, 2009
    15,826
    NEC USB 3.0 you're talking about, right?
  19. NeverWinner
    Dec 30, 2010
    20
    It could well have been the NEC USB 3.0 driver (now Renesas USB 3.0), but I think the main culprit was the Marvell driver.
    I did some more research on the issue and don't understand how this problem isn't being looked at more seriously. The joint (lack of) efforts of Marvell and, surprisingly, Asus made this problem a massive headache to resolve.
    Marvell don't actually offer any support for this product. Their website is extremely poor for support and doesn't even have this SATA Controller part (88SE9128) listed anywhere. Emailing Marvell would get you nothing but a bot-reply, advising you to contact Asus about the issue. Disgraceful.
    So Asus...
    You'd think they would keep the download page up to date. All of the listed driver downloads available for my motherboard on the Asus site are old and some unstable (at the time of writing).
    During my research, I landed on pages that I thought would help other people in my situation (so I bookmarked it straight away in case I BSODed).
    Here is a good read for anyone interested (Summary in posts 4,5 and 6). And another (ie. post 12).
    After further reading, I learnt that others with the same problem ended up ditching the Marvell Controller and switching to SATA2. I, however, kept at it.
    Solution (I hope) : Download your drivers for Asus P6X58D-E from here. They appear to update the listing extremely quickly (I can currently see one with yesterday's date).
    IMO, Asus should be helping out and Marvell should be hiding. Marvell produced a chip that didn't really work. Asus brought out a motherboard and used "SATA3 6Gbps" as a selling point. I'm glad Marvell managed to push out the new driver last month but believe the lack of service from the two companies is far from applaudable.
    As with the NEC USB 3.0 Controller Driver:
    Seems like NEC's 'USB department' has very subtly changed to Renesas. Therefore, searching for 'NEC usb 3 driver' wouldn't quite work. I read the release notes history that came with the latest download and found, under Version 2.0.4.0 May 14th, 2010:
    - Driver Provider Name in the INF file was changed from NEC Electronics
    to Renesas Electronics.
    This isn't a rant of any kind. I just thought I'd take the time to document the results somewhere. Let's hope that people will land here during their frustrating online searches.
    Thanks! :)
    2 people like this.
Share This Page
