Debug session time: Fri Jul 5 12:39:22.167 2013 (UTC - 4:00)
Loading Dump File [C:\Users\jcgriff2\SysnativeBSODApps\070513-17160-01.dmp]
Built by: 7601.18113.amd64fre.win7sp1_gdr.130318-1533
System Uptime: 0 days 0:02:49.057
Probably caused by : win32k.sys ( win32k!SetWakeBit+f8 )
BugCheck A, {2b, 2, 0, fffff80001c91279}
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000000A"]IRQL_NOT_LESS_OR_EQUAL (a)[/URL]
Bugcheck code 0000000A
Arguments:
Arg1: 000000000000002b, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff80001c91279, address which referenced memory
BUGCHECK_STR: 0xA
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: csrss.exe
FAILURE_BUCKET_ID: X64_0xA_win32k!SetWakeBit+f8
BiosVersion = 1301
BiosReleaseDate = 07/05/2011
SystemManufacturer = System manufacturer
SystemProductName = System Product Name
Debug session time: Fri Jul 5 10:48:05.723 2013 (UTC - 4:00)
Loading Dump File [C:\Users\jcgriff2\SysnativeBSODApps\070513-17534-01.dmp]
System Uptime: 0 days 1:34:04.284
Probably caused by : Pool_Corruption ( nt!ExDeferredFreePool+c96 )
BugCheck 19, {3, fffffa8007560540, fffffa8007560440, fffffa8007560540}
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x00000019"]BAD_POOL_HEADER (19)[/URL]
Bugcheck code 00000019
Arguments:
Arg1: 0000000000000003, the pool freelist is corrupt.
Arg2: fffffa8007560540, the pool entry being checked.
Arg3: fffffa8007560440, the read back flink freelist value (should be the same as 2).
Arg4: fffffa8007560540, the read back blink freelist value (should be the same as 2).
BUGCHECK_STR: 0x19_3
PROCESS_NAME: chrome.exe
FAILURE_BUCKET_ID: X64_0x19_3_nt!ExDeferredFreePool+c96
BiosVersion = 1301
Debug session time: Sun Jun 30 07:01:55.958 2013 (UTC - 4:00)
Loading Dump File [C:\Users\jcgriff2\SysnativeBSODApps\063013-19281-01.dmp]
System Uptime: 0 days 1:04:19.407
Probably caused by : Pool_Corruption ( nt!ExDeferredFreePool+cbb )
BugCheck 19, {3, fffffa8006accd00, fffffa8006accd00, fffffa800783fa50}
Arguments:
Arg2: fffffa8006accd00, the pool entry being checked.
Arg3: fffffa8006accd00, the read back flink freelist value (should be the same as 2).
Arg4: fffffa800783fa50, the read back blink freelist value (should be the same as 2).
PROCESS_NAME: uTorrent.exe
FAILURE_BUCKET_ID: X64_0x19_3_nt!ExDeferredFreePool+cbb
BiosVersion = 1301
Debug session time: Mon Jun 24 10:13:41.888 2013 (UTC - 4:00)
Loading Dump File [C:\Users\jcgriff2\SysnativeBSODApps\062413-17862-01.dmp]
System Uptime: 0 days 7:23:42.452
Probably caused by : ntkrnlmp.exe ( nt!PoIdle+52a )
BugCheck 7E, {ffffffffc0000005, fffff880058212ed, fffff880042d4028, fffff880042d3880}
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000007E"]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e)[/URL]
Bugcheck code 0000007E
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff880058212ed, The address that the exception occurred at
Arg3: fffff880042d4028, Exception Record Address
Arg4: fffff880042d3880, Context Record Address
BUGCHECK_STR: 0x7E
PROCESS_NAME: System
*** WARNING: Unable to verify timestamp for Unknown_Module_00000000`00000001
*** ERROR: Module load completed but symbols could not be loaded for Unknown_Module_00000000`00000001
FAILURE_BUCKET_ID: X64_0x7E_nt!PoIdle+52a
