not responding due to a long running script
Discussion in 'Windows 7 Help and Support' started by lostsoul65, Feb 9, 2013.
  1. lostsoul65
    lostsoul65 New Member
    May 3, 2012
    165
    "not responding due to a long running script"
    This is the message I get just about everytime I go from one site to another site using IE9 on Windows 7 which makes my computer almost useless because it freezes all the time. It's not a virus. Can anyone help solve this problem?
  2. patcooke
    patcooke Microsoft MVP Staff Member Premium Supporter Microsoft MVP
    May 16, 2010
    5,368
    North Lincolnshire, England
    Have you any add-onds which may be causing the problem? If unsure try disabling any you have then re-enabling one at a time.
  3. lostsoul65
    May 3, 2012
    165
    No add-ons
  4. patcooke
    May 16, 2010
    5,368
    Have you tried another browser? If another browser is ok then it points to something attached to IE. You say it's not a virus - what AV action have you tried? If not already done I'd run malwarebytes.
  5. DTR
    DTR Well-Known Member
    Jan 25, 2011
    14
    I too have this problem and it started some months ago when windows did one of it's interminable ffffff ing updates....
    I have run all the MS so called fixes and still it persists............... FIXYA from MS is useless......... and why should I have to BUY some 3rd party app to fix MS screw ups/
  6. patcooke
    May 16, 2010
    5,368
    Is this a comment or a request for help? If the latter you should start a new thread rather than hijack an existing thread which is three months old.
Share This Page
