RMClock Utility =/
Discussion in 'Windows 7 Software' started by Aceadam, Jan 18, 2009.
  1. Aceadam
    Aceadam New Member
    Jan 18, 2009
    6
    Well i kinda need this program runnning as my laptop can overheat quite fast... Any Ideas?
  2. ArthurDent
    ArthurDent New Member
    Jan 12, 2009
    38
  3. minger
    minger New Member
    Jan 20, 2009
    6
    I upgraded from Vista and RMClock works fine for me.
  4. Aceadam
    Aceadam New Member
    Jan 18, 2009
    6
    i got that exact one.
  5. ren274u
    ren274u New Member
    Jan 17, 2009
    10
    Copy this file over the original in the RMClock folder, this has signed drivers. I had the same problem last night.
  6. ArthurDent
    Jan 12, 2009
    38
    Ah right, that explains it then.....
    The one I'm using probably hasn't got the signed driver(s), but works because I've disabled driver signing.
    You can disable driver signing by pressing F8 at Boot and select the relevant option from the menu that comes up.
  7. ren274u
    ren274u New Member
    Jan 17, 2009
    10
    But dont you have to do that every restart?
  8. ArthurDent
    Jan 12, 2009
    38
    Not sure to be honest. But what I do know is that I've restarted my system quite a few times now and not had to alter my boot time settings (via F8) at all. RMClock works just fine.
  9. zomby4245
    zomby4245 New Member
    May 8, 2009
    2
    RMClock on Windows 7
    I use RMClock to get rid the "high pitched noise" of my laptop (HP DV5-1130ca). It was running quite smoothly on Vista SP1. I recently made a Windows 7 (32 bits) clean install. An I can't get rid of this noise anymore but RMClock is running correctly. Any Ideas?
    To get rid of the noise I had to disable the x6 FID in the profile tab and then select "P-State transitions".
  10. cniggeler
    cniggeler New Member
    May 2, 2010
    2
    If temp is the issue, try CPUgenie
    I note that Aceadam didn't reply whether he's running with RMClock. If not, and your goal is temp management, check out CPUgenie, which IMO is better at managing voltages and thus temperature than RMClock. They actually have a voltage test utility that runs a minimum of 14 hours to establish voltages for each P-state of your machine. Cons:
    - My Win7 laptop rebooted periodically after a few days using CPUgenie. I suppose I could rerun the voltage utility, but I really want a better performance manager than what CPUgenie has.
    - Not free (US$14.95) but a 30-day eval window
Share This Page
