Root element is missing error
Discussion in 'Windows 7 Help and Support' started by ravi raj, Aug 30, 2013.
  1. ravi raj
    ravi raj New Member
    Aug 30, 2013
    1
    I am getting this error when trying to connect internet and have no idea how to fix it. Please help me to solve this problem.
    Pop up : Microsoft >NET Framework
    Unhandled exception has occurred in your application. If you click continue, the application wll ignore this error and attempt to continue. If you click Quit,the application will close immediately.
    These are the further details :
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.Xml.XmlException: Root element is missing.
    at System.Xml.XmlTextReaderImpl.Throw(Exception e)
    at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
    at System.Xml.XmlTextReaderImpl.Read()
    at System.Xml.XmlTextReader.Read()
    at Module3.ModuleValidator.client_FirstDownloadFileCompleted(Object sender, AsyncCompletedEventArgs e)
    at System.Net.WebClient.OnDownloadFileCompleted(AsyncCompletedEventArgs e)
    at System.Net.WebClient.DownloadFileOperationCompleted(Object arg)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.18052 built by: FX45RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    Module3
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/temp1/Module9.exe
    System.Windows.Forms
    Win32 Version: 4.0.30319.17929 built by: FX45RTMREL
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Configuration
    Win32 Version: 4.0.30319.18060 built by: FX45RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  2. Pauli
    Pauli Extraordinary Member Premium Supporter
    Mar 1, 2012
    2,434
    Helsinki, Finland, Europe
Share This Page
