For some reason the 2nd time I plub in an exernal USB3 HD to my USB3 4 port hub, I get the dreaded BSOD!!! I do eject the drive by right clicking on the "Safely remove hardware and eject media" and choosing the drive.
When i connect a USB 3 HD or flash drive to my hub later on, I end up getting the BSOD and it reboots the computer. It doesn't necessarily have to be the same device either. I have tired different ports as well. I also have noticed that if I connect a USB2 device after ejecting a USB3 device I do not have the same problems.
Any suggestions?
thanks in advance!
Any suggestions?
thanks in advance!
