A USB flash drive connects to panels illustrating security, offline study, file sharing, gaming, apps, and operating systems.
How-To Geek's Monica J. White published a list of six unusual jobs she gave her USB flash drives in 2026. The ideas are worth a look, and a few come with fine print. Some tasks only carry data. Others change how your PC starts up. That difference decides how careful you need to be.
Every "I did this" claim below is her account. I haven't tested any of it. The tool details come from the projects' own documentation. Her intro blames a RAM shortage "spilling over to every area of the PC market." Nothing I reviewed backs that up, so I'm leaving it out.
A USB flash drive connects to panels illustrating security, offline study, file sharing, gaming, apps, and operating systems. Two ways to think about the list​
  • The drive carries things: USB Raptor, Kiwix, a router file share and PortableApps.com. Your PC still boots normally.
  • The drive changes what boots: Batocera and Ventoy. This is where firmware settings, Secure Boot and wiping the wrong disk come into play.
1. A USB stick as a PC lock key (USB Raptor)​
White describes a free tool that puts an encrypted key file on a flash drive. Pull the drive and the screen locks. Plug it back in and you're in.
USB Raptor's documentation describes a Windows utility. SourceForge lists the supported operating system as Windows only. The documentation says the unlock file is tiny, about 1 KB, and that the drive can still hold ordinary files. It lists backup ways back in: a password, a network command or a master key. It also mentions a delay or cancel option, so a bumped stick doesn't lock you out. It describes optional checks of the drive's serial number and a system-unique key.
Caveats:
  • This is a convenience lock. It is not a replacement for Windows sign-in or your organization's access controls.
  • The project's FAQ says Ctrl+Alt+Delete stays active, though it doesn't grant desktop access.
  • Set up and test a recovery method before relying on it. A lost or dead stick shouldn't strand you.
  • On a managed work PC, check your IT policy before installing anything.
2. Wikipedia on a flash drive (Kiwix)​
Kiwix stores offline content in ZIM files, which a Kiwix reader opens. Kiwix's FAQ says ZIM files come from the app's built-in catalog or its official library.
Kiwix's FAQ says each Wikipedia archive comes in three sizes:
EditionWhat you getSize vs. full
miniArticle introductions plus infoboxesAbout 95% smaller
nopicFull articles, no imagesAbout 75% smaller
maxiThe full versionBaseline
The Kiwix Desktop project says its reader supports Windows 10 and 11 and GNU/Linux.
Practical notes:
  • Check the file size before you download. Leave room for the reader and anything else on the stick.
  • Offline copies don't update themselves. Kiwix's FAQ says incremental ZIM updates aren't currently available, so you replace the whole file.
  • It's a snapshot, which is fine for a flight and wrong for anything breaking.
3. A router's USB port as a small file share​
This one depends on your router. A USB port doesn't guarantee storage sharing. White herself says it works "for routers that support USB storage sharing." She also hedges on calling it a NAS.
Vendor documentation shows how model-specific it is:
  • NETGEAR ReadySHARE: The support page says common USB storage can be shared with wired and wireless users. Drives that need special drivers won't work. On Windows you enter \\readyshare in Run or File Explorer. The drive can take up to two minutes to become ready after you plug it in. A drive that needs its own power supply must use it.
  • TP-Link (guide updated April 17, 2026): It describes local access over SMB or FTP. It recommends turning on Secure Sharing so nobody can reach the drive without logging in. Its internet access option is FTP only. SMB isn't supported remotely.
My advice:
  • Look up your exact router model before you start.
  • Keep access authenticated.
  • Think hard before exposing anything to the internet.
  • Don't treat it as a backup. One flash drive on a router has no redundancy.
4. Turning a PC into a retro console (Batocera)​
Batocera is a Linux-based gaming system you write to a USB drive and boot from. Its install wiki gives the steps:
  1. Download an image flashing tool such as Raspberry Pi Imager or USBImager.
  2. Download the Batocera image that matches your hardware. The wiki says x86_64 suits most PCs.
  3. Write the image to the drive.
  4. Boot the target PC from it.
The wiki says 16 GB is the minimum and 32 GB is recommended. With only 16 GB you can't automatically download updates. On first boot it expands a partition, and you shouldn't power off during that step.
If it won't boot, the wiki points to firmware settings:
  • You may need to disable Secure Boot on a recent PC.
  • You may need to open the boot menu with F10, F11 or F12 and pick the drive.
  • UEFI is preferred, but Legacy can be the only option on some boards.
  • Some office PCs block USB booting entirely.
  • Laptops are often more restrictive than desktops.
The wiki also warns about its internal-drive install option. It overwrites everything on the target drive, including your working OS. If you only want a USB experience, stay on the stick.
White notes you need your own game files and firmware. Use only materials you're legally entitled to. Batocera's documentation covers adding ROMs and BIOS files.
5. A software library in your pocket (PortableApps.com)​
PortableApps.com describes a portable app as one that doesn't need installing into Windows. You can carry it on a USB drive, portable SSD or synced cloud folder.
The project's guidelines say a portable app should keep working when the drive letter changes. They also say it shouldn't leave files or registry entries behind, "except those automatically generated by Windows." So don't assume zero trace on every host PC.
Practical notes:
  • Your personal data lives on the stick, so a lost drive means lost data. Protect it and eject it safely.
  • Don't use it to dodge workplace software rules.
  • White cites "hundreds" of apps. I'm not repeating a fixed number, since the directory changes. Browse it yourself.
6. One drive that boots almost anything (Ventoy)​
Ventoy is the bootable-USB tool that avoids repeated reformatting. SourceForge describes it as a tool for ISO, WIM, IMG, VHD(x) and EFI files. You install Ventoy once, copy images onto the drive and pick one from a menu at boot.
Version notes:
  • SourceForge's file list shows Ventoy 1.1.18 dated October 9, 2026. 1.1.17 came on July 24, 2026.
  • SourceForge describes support for x86 Legacy BIOS, IA32 UEFI, x86_64 UEFI, ARM64 UEFI and MIPS64EL UEFI.
  • One third-party listing says the drive stays usable for normal storage and that data survives version upgrades. Another says Ventoy needs a drive of at least 4 GB.
  • MajorGeeks notes that Ventoy draws several VirusTotal hits and may trigger "not commonly downloaded" warnings. That's worth knowing before you panic or, worse, ignore a real warning.
  • Another page reported a "not all ISOs are guaranteed" caveat. Check the compatibility list for your image.
Before you install:
  1. Back up the drive. Initial setup is still a disk operation.
  2. Double-check you picked the right target drive.
  3. Download from the official site and verify the checksum.
  4. Test your most important images, such as a Windows installer and a recovery tool.
Verdict​
None of these tricks is new. The value is in the reminders: a flash drive is more than a courier for files. It's also a rescue kit, a library and a boot menu.
My rule of thumb is to start with the portable and offline uses. Move to the boot-changing ones only after you've backed up and know your firmware settings. White also advises checking that any software is still trustworthy before you download it, and that's good advice for all six.
  1. The 6 most unusual things I've done with USB flash drives in 2026 How-To Geek 2026-10-25T18:30:17+00:00
  2. Download USB Raptor Documentation v1.11.pdf (USB Raptor) sourceforge.net
  3. Ventoy - Browse Files at SourceForge.net sourceforge.net
