A retro-style mini PC is shown assembled and in exploded view, highlighting its cooling system and circuit board.
If you ever stared at a beige-and-gray 1985 Nintendo Entertainment System and thought, "What this really needs is a neural processing unit and dual 2.5GbE ports," ACEMAGIC has built your fever dream—twice. Earlier in 2026, the company launched the Retro X5 globally with AMD's Ryzen AI 9 HX 370 and upgradeable DDR5 memory slots. Now, a late-2026 hardware refresh reviewed by Neowin swaps the guts for AMD's Ryzen AI 9 365 and 32GB of soldered LPDDR5X-7500 RAM, turning an otherwise stellar Windows 11 Pro mini PC into a fascinating lesson in bandwidth, upgradability, and reading the fine print before you hit checkout.
At a glance, the refreshed Retro X5 looks every bit the nostalgic desk ornament: a 138 × 128 × 45 mm, 650-gram plastic chassis finished in classic gray, black, and white with a bright red power button and mechanical-style cooling grilles. Yet underneath that retro-console disguise sits modern Copilot+ PC hardware capable of driving four displays, running Windows 11 Pro 26H2 cleanly out of the box, and pushing respectable 1080p frame rates without sounding like a hair dryer. Still, Neowin's hands-on testing exposes a trade-off that PC builders and IT pros cannot ignore—and ACEMAGIC's own product page doesn't make it any easier to spot.
A retro-style mini PC is shown assembled and in exploded view, highlighting its cooling system and circuit board. Same 1985 Shell, Different 2026 Silicon: Read the Spec Sheet Twice​
The single biggest takeaway for prospective buyers is that "ACEMAGIC Retro X5" now describes two materially different machines depending on when it was built and which listing you open.
When the Retro X5 first arrived in early-to-mid 2026—as tested by PC Gamer in May and TechPowerUp in June—it packed AMD's 12-core, 24-thread Ryzen AI 9 HX 370, 16-compute-unit Radeon 890M graphics, dual-channel DDR5-5600 SO-DIMM slots supporting up to 128GB, Wi-Fi 7, and Bluetooth 5.4. By contrast, the late-2026 refresh evaluated by Neowin moves to the Ryzen AI 9 365, pairing fewer CPU and GPU cores with significantly faster—but permanently soldered—memory and slightly older wireless silicon.
SpecificationRetro X5 (Early 2026 Launch)Retro X5 (Late-2026 Refresh)
ProcessorAMD Ryzen AI 9 HX 370 (12C / 24T, up to 5.1 GHz)AMD Ryzen AI 9 365 (10C / 20T, 2.0–5.0 GHz)
Integrated GPURadeon 890M (16 CUs, up to 2,900 MHz)Radeon 880M (12 CUs, up to 2,900 MHz)
NPU PerformanceAMD XDNA 2 (up to 50 TOPS)AMD XDNA 2 (up to 50 TOPS; 73 TOPS total)
Memory32GB DDR5-5600 (2× SO-DIMM, up to 128GB)32GB LPDDR5X-7500 (Soldered, non-upgradeable)
Storage2× M.2 2280 PCIe 4.0 ×4 (1TB preinstalled)2× M.2 2280 PCIe 4.0 ×4 (1TB Kimtigo G7000 + 1 empty)
WirelessWi-Fi 7, Bluetooth 5.4Wi-Fi 6E (MT7922), Bluetooth 5.2
Wired LANDual 2.5GbE RJ45Dual 2.5GbE RJ45 (Intel I226-V)
Operating SystemWindows 11 ProWindows 11 Pro (tested on 26H2)
Here is the catch that deserves bold red highlighter: ACEMAGIC's own US product listing for the Retro X5 still retains older HX 370 marketing blocks—citing "DDR5 5600 MT/s," "Dual SO-DIMM Slots," and "WiFi 7 and Bluetooth 5.4"—further down the page, even though the active configuration selector and top description clearly specify the Ryzen AI 9 365, onboard 32GB LPDDR5X memory, Wi-Fi 6E, and Bluetooth 5.2. There is also a slight discrepancy on support coverage: Neowin's spec table lists a three-year warranty, whereas ACEMAGIC's official US store policy states a two-year warranty for products purchased on or after August 1, 2025 (with three-year coverage reserved for earlier purchases). If you are buying this machine for a small office or homelab, verify the exact SKU and warranty terms on your invoice rather than relying on decorative marketing banners.
Section Takeaway: The late-2026 Retro X5 is not a simple CPU swap; it trades upgradeable SO-DIMM slots, two CPU cores, four GPU compute units, and Wi-Fi 7 for a lower price and faster onboard LPDDR5X-7500 RAM.
Memory Bandwidth vs. Upgradability: The Soldered RAM Trade-Off​
Neowin deducted a single point from an otherwise glowing 9/10 verdict for one reason: the 32GB of LPDDR5X-7500 memory is soldered directly onto the motherboard. For longtime Windows tinkerers, soldered RAM on a desktop mini PC feels like buying a pickup truck with the hood welded shut. If a workload outgrows 32GB three years from now—say, running larger local language models or multiple heavy virtual machines—you cannot pop in a 64GB kit.
Yet Neowin's benchmark table proves there is a genuine engineering rationale behind ACEMAGIC's decision. In integrated-graphics mini PCs, memory bandwidth is oxygen. When Neowin tested the Retro X5 alongside two newer AMD Ryzen AI 9 HX 470 ("Gorgon Point") mini PCs—the ACEMAGIC F2A and a stock GEEKOM A9 Max—the results showed just how badly starved memory can cripple faster silicon.
Benchmark (Neowin Testing)Retro X5 (Ryzen AI 9 365, 32GB LPDDR5X)ACEMAGIC F2A (Ryzen AI 9 HX 470, 32GB)GEEKOM A9 Max (HX 470, Single-Channel 32GB)
3DMark Time Spy3,3734,2622,295
3DMark Steel Nomad Light3,2473,5932,042
3DMark Fire Strike8,6599,2954,928
3DMark Night Raid (1080p)31,14430,706—
PCMark 10 Extended8,5768,6197,342
Geekbench 6 (Single / Multi)2,871 / 14,5292,919 / 14,5352,922 / 11,706
Cinebench 26 (Single / Multi)645 / 4,373639 / 4,973652 / 4,472
7-Zip105,781119,940110,999
Procyon CV 2.0 (Windows ML NPU)1,1301,167866
Look at those numbers closely. On paper, AMD's Ryzen AI 9 HX 470 (launched in January 2026) enjoys clear advantages over the Ryzen AI 9 365: 12 cores (four Zen 5 plus eight Zen 5c) instead of 10 (four Zen 5 plus six Zen 5c), a 5.2 GHz peak boost versus 5.0 GHz, a 16-CU Radeon 890M clocked up to 3,100 MHz versus the 12-CU Radeon 880M at 2,900 MHz, and an XDNA 2 NPU rated up to 55 TOPS versus 50 TOPS. Against the properly configured ACEMAGIC F2A, the HX 470 pulls ahead in heavy multithreaded rendering and 1440p/4K graphics tests exactly as expected.
Against the stock GEEKOM A9 Max, however, the supposedly "lesser" Retro X5 wins handily across gaming, productivity, and AI inference—even beating the F2A slightly in 1080p Night Raid. Why? Because GEEKOM shipped that 32GB A9 Max configuration with a single-channel SO-DIMM stick, starving the Radeon 890M of bandwidth until the reviewer manually installed a second stick. Soldered LPDDR5X-7500 removes user upgradability, which remains a valid strike against longevity, but it guarantees full multi-channel bandwidth right out of the box.
Section Takeaway: Thirty-two gigabytes of fast, multi-channel LPDDR5X-7500 is enough for most productivity, casual gaming, and entry-level local AI workflows today—and beats a badly configured SO-DIMM rival—but buyers who need 64GB+ down the road should look elsewhere.
Windows 11 Pro, Copilot+ PC Status, and Local AI Reality​
Out of the box, the Retro X5 ships with an activated Windows 11 Pro license and—refreshingly for budget-conscious boutique mini PCs—zero third-party bloatware. Neowin notes that the Out-of-Box Experience pulled down minimal updates to reach Windows 11 Pro 26H2, and benchmarking proceeded on the November 2026 Patch Tuesday build with AMD graphics driver 26.8.1 and chipset driver 8.09.28.1124. (The only Windows Security warnings encountered during setup stemmed from disabling OneDrive and signing in locally without a Microsoft Account.)
Does it qualify as a Copilot+ PC? On hardware specifications, yes. Microsoft's published Copilot+ PC requirements call for Windows 11 version 24H2 or newer, at least 16GB of RAM, a 256GB SSD, and an NPU exceeding 40 trillion operations per second (TOPS), with AMD Ryzen AI 300-series processors explicitly listed among supported silicon. The Ryzen AI 9 365's XDNA 2 NPU is rated at up to 50 TOPS on its own and up to 73 TOPS when combined with the CPU and Radeon 880M GPU, though Microsoft notes that individual Copilot+ features can still vary by Windows build, region, and language availability.
For developers and IT administrators evaluating local AI on Windows, there are two practical wrinkles worth noting:
  • Windows ML over legacy frameworks: Microsoft's developer guidance now points apps away from DirectML toward Windows ML (WinML) on top of ONNX Runtime so Windows can automatically discover hardware Execution Providers rather than bundling vendor libraries manually. Neowin observed that Geekbench AI 1.7.0 and 1.8.0 failed to detect the Ryzen AI 9 365's XDNA 2 NPU directly, whereas UL's Procyon Computer Vision 1.0 and 2.0 tests measured strong NPU throughput (1,809 and 1,130 respectively). Real-time NPU load can also be inspected directly inside Windows 11 Task Manager.
  • BIOS freedom vs. support-page quirks: Enthusiasts get an unlocked AptiBIOS with full tuning access. However, ACEMAGIC's support page for the Retro X5 offered no standalone BIOS updates or clean individual driver installers during Neowin's testing—only a 1.8GB "Driver" archive that turned out to be a full Windows 11 driver-repository export. That works for clean Windows reinstalls, though anyone maintaining fleet images will want to pull WHQL chipset and Radeon drivers directly from AMD.
Section Takeaway: You get a clean, unbloated Windows 11 Pro installation with genuine 50 TOPS Copilot+ hardware and an unlocked BIOS, paired with minimal OEM software support tools.
Gaming, eGPU Expansion, Storage, and Thermals​
ACEMAGIC's marketing tagline—"Looks Like 1985, Works Like 2027"—leans heavily into gaming nostalgia, even advertising support for classic console emulation and local LLMs. Let's keep expectations firmly grounded in reality: a Radeon 880M with 12 RDNA 3.5 compute units is no substitute for a discrete gaming card. Neowin pegs its real-world muscle at roughly NVIDIA GeForce GTX 1650 class.
Still, when Neowin threw Cyberpunk 2077 at it using 1920 × 1080 Low settings, ray tracing disabled, frame generation off, and AMD FSR 4 set to Quality, the Retro X5 delivered a playable 41.94 FPS minimum and 50.48 FPS average. In Speedometer 3.1 web benchmarks, it also turned in snappy browser responsiveness across Microsoft Edge 158.x (31.7–33.5), Google Chrome 158.x (31.7–32.8), and Firefox 160.0 (30.2–31.8).
More importantly, if you outgrow integrated graphics, ACEMAGIC built in an upgrade path that many compact desktops omit: a dedicated side OCuLink port, backed up by two 40Gbps USB4 ports (one front, one rear). Both interfaces support external discrete GPUs (eGPUs), with OCuLink avoiding the steeper PCIe tunneling overhead of USB4 when paired with a desktop graphics dock.
Storage, Teardown, and Thermal Behavior​
Unlike the soldered RAM, storage access is surprisingly builder-friendly:
  1. Slide the left-side lock switches to the unlock position and pull off the cover.
  2. Unscrew four Phillips screws securing the internal metal plate.
  3. Gently pry the plate loose (the preapplied thermal pad creates light suction).
Inside sits easy access to the Wi-Fi card, CMOS battery, the occupied M.2 2280 PCIe 4.0 ×4 slot, and a second empty M.2 2280 PCIe 4.0 ×4 slot. The factory 1TB Kimtigo G7000 SSD hit 7,100 MB/s sequential read and 5,995 MB/s sequential write in CrystalDiskMark (near its 7,400/6,600 MB/s rating), before dropping to 5,180 MB/s read and 2,792 MB/s write in AS SSD. That gap reflects both queue-depth differences (QD8 vs. QD1 incompressible data) and the drive's DRAM-less Host Memory Buffer (HMB) architecture—completely fine for Windows boot times and game loading, though heavy 4K video editors will eventually want to populate that second slot with a DRAM-cached SSD.
Thermally and acoustically, the single high-pressure radial fan and dual copper heat pipes punched well above their weight. Using a FLIR ONE Gen 3 thermal camera during PCMark 10 Extended, Neowin measured:
  • Top shell: 27.4°C
  • Bottom rear: 32.8°C
  • Left exhaust vent hotspot: 40.5°C
  • Peak CPU core temperature: 85.1°C
Power draw remained remarkably miserly throughout: under 1.0W powered off, roughly 4.8W idle at the Windows 11 desktop, up to 32.8W during PCMark 10 Extended's video conferencing test, and around 80W wall power while running Cyberpunk 2077.
Section Takeaway: Quiet cooling, sub-5W Windows idle draw, tool-assisted dual-M.2 access, and a side OCuLink port make the Retro X5 far more versatile than a novelty emulator box.
Connectivity, Pricing, and the Verdict for Windows Users​
Where most mini PCs force you to crawl behind the desk for fast ports, the Retro X5 puts real I/O right on the front panel: two 10Gbps USB 3.2 Gen 2 Type-A ports, a 3.5mm audio jack, and a full-featured 40Gbps USB4 port supporting DisplayPort Alt Mode, S5 Power Delivery, 15W PD-out for portable monitors, and 100W PD-in. Around the back sit a second 40Gbps USB4 port, HDMI 2.1, DisplayPort (listed as 2.1 in Neowin's table and 2.0 on ACEMAGIC's store description), USB 3.2 Gen 2 Type-A, USB 2.0 Type-A, dual 2.5GbE RJ45 LAN ports, and a 120W barrel DC input—enough to drive four monitors simultaneously. On the downside, there is no SD card reader and no Kensington security lock slot, two omissions worth noting for creators and office IT buyers.
At the time of Neowin's review, ACEMAGIC listed the Retro X5 in the U.S. at $899 (40% off its $1,499 official MSRP, or $1,199 listed reference price on Amazon), and €999.99 in Germany (23% off €1,299.99), while U.K. official store stock was sold out. Buyers looking solely for the NES-style case on a tighter budget can also look at the Retro X3 variant, which drops to $509 ($899 MSRP) with an older AMD Ryzen 7 H 255, 16GB of LPDDR5-6400 memory, and a 512GB SSD.
So, who should actually buy the refreshed Retro X5?
  • Great fit for: Windows 11 Pro users who want a quiet, sub-5W-idle compact desktop with quad-display support, dual 2.5GbE networking, Copilot+ 50 TOPS NPU hardware, clean OS provisioning, and OCuLink/USB4 room for an external GPU later.
  • Skip if: You demand upgradeable SO-DIMM memory past 32GB, need native high-settings AAA gaming out of the box without an eGPU, or deploy fleets that require Kensington lock slots and curated enterprise driver packs.
The Retro X5 stops just short of perfection solely because its 32GB of RAM is locked down forever. Even so, between its smart thermal engineering, front-and-rear USB4, OCuLink expandability, and multi-channel LPDDR5X-7500 performance, ACEMAGIC has built a tiny Windows 11 desktop with far more substance than its 1985 costume lets on.
  1. ACEMAGIC Retro X5 review: My new favorite mini PC is just shy of perfection Neowin 2026-11-28T16:00:01+00:00
  2. ACEMAGIC Retro X5 AMD Ryzen™ AI 9 365/X3 AMD Ryzen™ 7 H 255 Mini PC acemagic.com
  3. techpowerup.com techpowerup.com
