A handheld gaming console displays a futuristic adventure game on a desk beside a tag showing rising costs.
Acer's Predator Atlas 8 is a Windows 11 handheld with an Intel Arc G3 Extreme chip. Windows Central's Cale Hunt has made it his primary handheld in place of a Steam Deck. His review rates the chip highly and the price better than its rivals. It also has real caveats, including a $150 price hike that arrived less than two weeks after launch.
A handheld gaming console displays a futuristic adventure game on a desk beside a tag showing rising costs. What the review does and doesn't establish​
Hunt says he has been a handheld gamer since the original Steam Deck. This is one reviewer's experience of switching his daily driver. It is not a controlled Atlas 8 versus Steam Deck test. The review gives no matched-settings numbers for the two devices, so "better than a Steam Deck" is not something the evidence supports. Its comparisons are against the MSI Claw 8 EX AI+ and the Ryzen Z2 Extreme.
Windows Central's own headline for the review is stronger than the version syndicated elsewhere. It reads "I ditched my Steam Deck for Acer's Predator Atlas 8, and I'm not going back." The review carries a 4.5 rating. Hunt also says Acer and Intel had no input into the review and did not see it before publication.
Price: the part that moved​
The Atlas 8 launched at $1,299.99, $500 below MSI's Claw 8 EX AI+, which uses the same Arc G3 Extreme chip. On November 10, less than two weeks after the November 1 launch, the price rose to $1,449.99.
Pricing across the three Arc G3 Extreme handhelds in the review:
DevicePrice cited
Acer Predator Atlas 8$1,449 (launched at $1,299.99)
OneXPlayer 3$1,699
MSI Claw 8 EX AI+$1,799
Other outlets give a similar picture, with some uncertainty about the current price:
  • A third-party tracker reported that Acer's own US store listed the Atlas 8 at $1,449.99 when checked on November 12. Treat that as a dated observation.
  • Earlier coverage said Acer told Windows Central that $1,299.99 was the original MSRP after pre-orders sold out and Best Buy pulled its listing. No confirmed explanation for the increase appears in the evidence.
  • PC Gamer says the Atlas 8 offers perhaps the best price-to-performance ratio above $1,000. It also calls the pricing "both a boon for Acer and an indictment of the memory crisis."
Check the live price before you buy. The premium over the MSI is now about $350, not $500.
Configuration: don't assume every unit matches​
The review unit has these specs:
  • Intel Arc G3 Extreme, up to 4.7GHz and 14 cores
  • Arc B390 graphics with 12 Xe cores
  • 24GB LPDDR5x and a 512GB PCIe 4.0 SSD
  • An 8-inch 1920x1200 IPS touchscreen with a 120Hz refresh rate and 500 nits
  • An 80Wh battery
  • Two Thunderbolt 4 ports, a UHS-II microSD slot, Wi-Fi 7 and Bluetooth 5.4
Storage varies by market. PC Gamer lists 1TB storage for the model, with 512GB in America. That makes the US unit's storage a real limitation for big modern games. PC Gamer's complaint is that the chip could handle large games, but the drive can't hold many of them.
Performance: strong, with the frame-generation caveat​
Hunt's 3DMark and storage results put the Atlas 8 slightly behind the MSI:
TestAtlas 8MSI Claw 8 EX AI+
3DMark Fire Strike12,93513,340
3DMark Time Spy6,4136,726
CrystalDiskMark read6,598 MB/s6,997 MB/s
The gaps are roughly 3 to 6 percent. Hunt says the Atlas 8 easily beats the Ryzen Z2 Extreme in Time Spy, but the text doesn't include that table.
His Cyberpunk 2077 numbers all depend on frame generation:
  • Balanced mode on battery: a 99.4 FPS average in the in-game benchmark, with basic ray tracing and native XeSS 2 frame generation.
  • Turbo mode on AC power: a 105 FPS average.
  • Forced 4x XeSS 3 multi-frame generation: 167 FPS. This uses a PredatorSense option that applies to games without official support.
Generated frames are not the same as natively rendered frames, so don't compare these figures to native-rendering handheld results. PC Gamer's separate testing used different settings and gave lower numbers. It reported 52 average FPS in Cyberpunk at 1080p Medium without upscaling and 71 with it. Different reviewers, settings and power modes produce different numbers, which is why none of these results should be merged into one ranking.
Thermals and noise​
In Hunt's stress test, the CPU and GPU levelled off at about 62°C and 68°C, and the fans stayed reasonable. His FLIR camera was out of order, so there are no surface-temperature readings. Air enters at the back and exhausts along the top, away from your hands.
Acer says the cooling uses a metal fan with 89 blades and a second plastic fan. Acer's own release says the metal fan delivers up to a 10 percent airflow increase. That figure is Acer's claim from internal testing.
Battery: set the power limits yourself​
This is the review's most practical lesson. Hunt measured the following:
  • PCMark 10 Gaming: 2 hours in Acer's Quiet preset, which runs at 25W. The MSI lasted 3 hours 23 minutes in its 15W Endurance preset.
  • Real-world estimates: about an hour of Cyberpunk 2077 with ray tracing, and four to five hours of indie games.
Both handhelds have an 80Wh battery and the same chip, so Hunt attributes the gap to the TDP difference rather than to the hardware. The two runs used different power settings, so they are not a like-for-like battery test.
PredatorSense's manual mode allows PL1 between 10W and 40W and PL2 between 15W and 60W. The steps below follow the review's description of PredatorSense. Exact menu labels may differ on your unit.
  1. Open PredatorSense. Hunt notes it sometimes refuses to launch until you restart.
  2. Switch from a preset to manual mode.
  3. Lower PL1 and PL2 for lighter games. Hunt says lower manual limits only improve runtimes.
  4. Raise them again for demanding titles. The review doesn't quantify the performance cost of lower limits.
Controls, display and build​
  • Display: Hunt calls the IPS panel bright and crisp and says the 120Hz VRR leaves headroom for frame generation. He is an OLED fan but says he'd still choose Intel's performance over OLED. He also says he never needed the included anti-glare protector.
  • Sticks and triggers: TMR sticks, Hall-effect triggers and no drift. Small switches on each side adjust trigger travel between a short pull and the full range.
  • D-pad: his main complaint. It has a scooped face with small raised lines and no prominent markers. PC Gamer also calls it mushy.
  • Ergonomics: the fused grip feels familiar after the Steam Deck. The body has no flex and the controls are within reach.
  • Speakers: loud, but thin at low volume and distorted when pushed. Hunt improved them with the onboard audio presets.
  • Haptics: he finds the rumble plain and turns it off.
  • Storage upgrade: the rear panel comes off after removing 8 screws, giving access to the SSD. That is Hunt's description, not a warranty or repairability statement.
Software: the weak link​
PredatorSense covers performance, audio, cooling and battery settings, but Hunt reports these problems:
  • It sometimes won't open until you restart.
  • Joystick RGB lighting turns off when other settings change.
  • Its sliders occasionally interfere with Windows, so adjustments can't be made.
He enjoys Windows 11's Xbox mode for navigating libraries but says it isn't yet as good as SteamOS. These are observations from one review unit, and a later update may fix them. If you're coming from a Steam Deck, expect more tinkering than you're used to.
Who should buy it​
It suits you if:
  • You want the fastest handheld silicon available at the lowest price for it, even after the hike.
  • You're happy to tune power limits manually.
Look elsewhere if:
  • You insist on OLED.
  • You need lots of storage out of the box in the US.
  • You want the polish of SteamOS.
Hunt's separate Atlas 8 versus MSI Claw 8 EX AI+ comparison was said to be coming that week. It should show whether the remaining $350 gap makes sense.
  1. I quit my Steam Deck for Acer's new Predator Atlas 8. Here's what I learned. Windows Central 2026-11-16T16:35:41+00:00
  2. I wasn't expecting a $1,449 Predator Atlas 8 price hike just 10 days after launch — Here's what it means for gaming handhelds if the increase sticks | Windows Central windowscentral.com
  3. Acer Predator Atlas 8 (G3 Extreme) review pcgamer.com
