The core test: where does the uncertainty live?
Babinchak's rule of thumb is to look at the trigger, the decision path and the outcome. If all three are known, a conventional workflow is usually more predictable and easier to govern. Her three patterns:
- "When this happens, do that." Start with automation.
- "Every month, an accountable person must review this and decide." Start with a recurring task.
- "It depends on what the person means, what the documents say, and which approved action fits." This is where an agent starts to earn its place.
She works through three illustrative scenarios. They are examples, not reported deployments.
Backup-failure review: a recurring task
A team might propose an agent that reads the morning backup report, decides which failures matter, opens tickets and sends notifications. Babinchak splits that into known steps:
- Pull the report on a schedule.
- Identify the failed jobs.
- Compare the failures with a documented threshold.
- Create or update a ticket.
- Notify the right queue or contact.
- Escalate if the ticket stays unresolved.
Her view is that a failed backup must be investigated anyway, so there is no ambiguity for an agent to resolve. She would make one person accountable through a recurring task. The RMM, PSA and Power Automate would handle the predictable supporting work.
Employee onboarding: plain automation
Once HR approves a new hire, the steps are already defined:
- Create the account from approved HR data.
- Assign role-based licenses.
- Add the user to the right groups.
- Create standard tasks for equipment, security training and manager follow-up.
- Notify the manager, or route an exception to a person.
The trigger is reliable, the inputs are defined and the outcomes are predictable. The business needs the same sequence every time, a record of what happened, and exceptions routed to a human.
Service-desk assistant: where an agent fits
Take three requests: "I can't get into the finance system", an invoice app that broke after a phone change, and temporary access for an accountant through Friday. They could involve different apps, policies, identity issues and risk levels. Employees often don't know the right product name or category.
An agent can ask clarifying questions, search approved knowledge and pick the right tool or workflow. Babinchak's key design point is that the agent handles language and context, while deterministic automation performs the consequential action. For example, the temporary-access request goes into a controlled approval flow.
The three options side by side
| Option | Use when | Main risk |
| Recurring task | A person must review, decide or stay accountable on a schedule | The review is skipped, delayed or not escalated |
| Automation | Trigger, rules, inputs and outcomes are known | Exceptions break the flow, or the process changes |
| Agent | Language, context or ambiguity changes the next step | Unexpected responses, excessive access, unpredictable consumption |
These are not mutually exclusive. A good design can combine all three, with work passing between them.
Pricing the whole solution
Power Automate
Babinchak notes that Microsoft 365 licenses include limited Power Automate capabilities, and that premium connectors and advanced scenarios may need more licensing. Microsoft's licensing documentation says the same: Premium connectors are tied to specific entitlements, and licenses across Microsoft 365, Dynamics 365 and Power Platform include only a limited set of Power Automate capabilities. What your tenant actually gets depends on the flow, its connectors and the licenses you hold. Check before assuming a flow is "free."
Copilot Studio
Agent usage is metered in Copilot Credits. Current published rates, as reported by several third-party pricing guides that repeat Microsoft's rate card, are:
- 1 credit for a classic answer, 2 for a generative answer, 5 for an agent action, 10 for tenant graph grounding, and 13 per 100 agent flow actions.
- A prepaid capacity pack is $200 per month for 25,000 credits, and pay-as-you-go via Azure is $0.01 per credit.
Treat those as a snapshot. Microsoft's own billing page points readers to its licensing guide and usage estimator for current figures.
Interactions also stack. Microsoft's example is a tenant-graph-grounded agent that uses 12 credits for one complex prompt: 10 for grounding and 2 for the generative answer. Reasoning models add a premium rate of 10 credits per 1,000 tokens on top of the normal feature rate.
That is the substance behind Babinchak's warning that a high-volume, poorly bounded agent is harder to forecast than a scheduled task or a flow. It is also fair to say that careful design keeps costs predictable. The most avoidable cost is deep reasoning spent on a simple lookup.
Agent flows are not Power Automate cloud flows
Microsoft states that Power Automate cloud flows use Power Automate licensing, not Copilot Credits. Only agent flows managed in Copilot Studio are subject to Copilot Studio enforcement. Don't put the two in the same budget line.
Microsoft also documents what happens when capacity runs out:
- Under the prepaid model, custom agents are disabled once tenant usage reaches 125% of capacity.
- Agent flow enforcement blocks new flow runs when prepaid capacity is exhausted, while the parent agent keeps serving non-flow interactions.
- Pay-as-you-go environments are not subject to that enforcement, because overage is billed to the Azure subscription.
- Employee-facing use by Microsoft 365 Copilot-licensed users can be included at no charge, within fair usage limits. The exception for agent flows applies only to the "When an agent calls the flow" trigger. Computer-using agents are not included.
For an IT admin, the practical point is that an outage on the agent side can come from billing, not from a bug.
The operational burden, and the controls that exist
Babinchak says the larger cost of an agent may be operational. Someone has to maintain knowledge sources, decide what data the agent can reach, test its answers, monitor tool calls and define when a human approves. Microsoft's guidance for Copilot Studio supports that list.
Budget controls. In the Power Platform admin center, admins can:
- View consumption by environment and agent.
- Download reports by environment, agent or user to investigate unexpected usage.
- Set monthly consumption limits per agent. Alerts and a hard stop that turns the agent off are available once a limit is set.
Security and governance. Microsoft's guidance recommends:
- Assigning licenses and environment access through Entra ID groups.
- Applying restrictive data policies to environments, covering connectors, channels, knowledge sources and unauthenticated use.
- Using a gated release process from development to test to production.
- Limiting who can share agents.
Data policies can also restrict knowledge sources such as SharePoint, public websites and uploaded documents. Microsoft says responses are tailored to the permissions of the person asking. It also says sensitivity labels and DLP endpoint filtering are supported for SharePoint knowledge sources. One caveat from Microsoft's FAQ: agent creation itself can't be disabled is not what the docs say, so use their wording instead. Microsoft says you can't disable agent creation and recommends using data policies to block chatting with the agent. Auditing is available through Microsoft Purview.
Monitoring the deterministic side. Power Automate flows get monitoring too. Microsoft documents per-flow analytics, environment-level analytics, an Application Insights integration and flow run history stored in Dataverse. The Dataverse history is retained longer than the history in Power Automate itself, which helps with auditing. It does not, on its own, satisfy an organization's audit obligations. Microsoft also notes some limits. For example, per-flow analytics refresh about every 24 hours and aren't available in government and sovereign clouds.
My take
The framework is sound and slightly contrarian in a useful way. Two caveats apply:
- Real processes are messier than tidy examples. A backup report with thousands of noisy jobs might benefit from AI triage. The author's point holds only when the thresholds and responses are genuinely documented.
- A human approval step doesn't make an agent safe by itself. Permissions, scoped knowledge sources and testing still matter.
A practical checklist before you build:
- Write down the trigger, the decision and the outcome. If you can, you probably want automation or a recurring task.
- Name an owner for any step that requires judgment.
- If an agent is justified, keep it to interpretation and routing, and send consequential actions through approved flows.
- Estimate credits per interaction, then set per-agent limits and alerts before launch.
- Test edge cases and permission boundaries in a non-production environment first.
The agent should do the part that needs language skills. Automation does the repeatable work, and a named person owns the judgment calls.
- Not Every Workflow Needs an Agent: Choosing AI, Automation, or a Recurring Task Petri IT Knowledgebase · 2026-10-08T14:14:44+00:00
- Types of Power Automate licenses - Power Platform | Microsoft Learn learn.microsoft.com
- What AI Agents Actually Cost in Microsoft 365: Copilot Studio Credits and Agent 365 Licensing (2026 Guide) babybots.ai
