The change does not appear to remove the restriction. Instead, Android Auto 17.2 makes the failure mode less mysterious. If a user connects a phone to a vehicle with a USB cable while the device is locked and Advanced Protection is blocking USB data access, Android Auto can now tell the user that the phone must be unlocked before the session can start.
That matters because the older behavior looked like a broken cable, a bad head unit, or another Android Auto compatibility failure. In reality, the phone was doing what Android’s newer security controls were designed to do: limit USB data access while the device is locked.
What changes for USB users
The practical change is messaging. Android Auto 17.2 adds clearer on-device language around the conflict between “start Android Auto while locked” and Android’s Advanced Protection behavior.
Android Authority, citing an APK teardown of Android Auto 17.2.662614, reported that Google added strings describing the issue and warning that a phone unlock is required to start Android Auto when Advanced Protection is on. Google’s Android support documentation says Advanced Protection can require the user to unlock the screen before allowing USB data transfer, including when using Android Auto over USB.
That distinction is important. Android Auto may still be allowed to start while the phone is locked in normal circumstances, but USB data restrictions can override that convenience feature. For drivers, the visible result is simple: plug in the cable, Android Auto does not start, unlock the phone, and the connection proceeds.
Not a security rollback
This is not Google making Android Auto less strict. It is Google explaining the security block more clearly.
Advanced Protection is meant to reduce the risk of malicious or unauthorized USB access. A car’s infotainment system is still a USB-connected device from Android’s point of view, so Android may refuse to pass data until the owner unlocks the phone. That can be annoying in a vehicle, but it is consistent with the security model.
For users who connect wirelessly, this particular USB lock-screen issue should not be the main concern. For users who rely on a cable, especially in older vehicles without wireless Android Auto, the update should reduce the troubleshooting loop of swapping cables, rebooting the head unit, clearing cache, or assuming Android Auto itself has failed.
How to get it
Android Auto 17.2 is rolling out through the Google Play Store, so not every phone will see the update at the same time. Users can check the Play Store listing for Android Auto and install the update when it appears. Some users may sideload the APK from third-party repositories, but that remains a higher-risk route and is better left to people who are comfortable verifying app sources and versions.
If wired Android Auto still will not start, the useful first checks are now straightforward:
- Unlock the phone after plugging it into the car.
- Check whether Android’s Advanced Protection or USB protection setting is enabled.
- Try a known-good data-capable USB cable if the warning does not appear.
- Update Android Auto from the Play Store when version 17.2 is offered.
For most affected drivers, the fix is not a new cable or a reset: it is knowing that the phone must be unlocked before Android will allow the wired Android Auto session to begin.
- Android Auto 17.2 now available: what changes for users connecting with a USB cable? - Modernet Digital Modernet Digital · Tue, 07 Jul 2026 21:49:03 GMT
- support.google.com support.google.com
