A graphics card with its heatsink lifted, exposing the GPU chip, memory modules, and thermal compound.
ARCTIC has launched two thermal putty pads, PX-1 and PX-1 Extreme. They are meant for the awkward spots inside a graphics card or motherboard where pad thickness is hard to match. The pitch is that you mould the material to fit instead of picking a thickness. The reporting also contains a few details that matter for anyone planning a GPU teardown.
A graphics card with its heatsink lifted, exposing the GPU chip, memory modules, and thermal compound. What ARCTIC announced​
ARCTIC says PX-1 and PX-1 Extreme combine a moldable, putty-like texture with reliable thermal performance. They adapt to uneven surfaces, varying component heights and complex hardware layouts, and are pitched as a flexible alternative to conventional thermal pads. The company describes the line as a new approach to thermal interface materials.
The announcement was a press release dated November 17, 2026, and eTeknix covered it the following day. Both outlets describe the same launch, not two separate products or events. In an X post, ARCTIC called these its first-ever thermal putty pads.
The intended uses are GPU VRAM, VRM arrays, MOSFETs, chokes and other PC components. ARCTIC's headline claim is that the putty provides consistent thermal contact without the need for precise pad thickness matching.
PX-1 versus PX-1 Extreme​
The two products are not just a cheap and an expensive version of the same thing.
PX-1PX-1 Extreme
TextureSoft, clay-like, 15 Shore OO hardnessFirmer, high-density, 40 Shore OO hardness
Pads per pack5 (74 × 39 mm)5 (74 × 39 mm)
Thickness1.5 mm1 mm
Elongation60%15%
Special ingredientNone statedArtificial diamond powder
Intended useGeneral PC hardwareHigher cooling demands and higher mounting pressure
Webshop price (40% off)€20.99€61.79
MSRP€34.99€102.99
The specifications in the table come from ARCTIC's product listings. The pricing comes from the launch coverage.
PX-1 is the all-rounder. ARCTIC says its soft texture adapts easily to different component heights and uneven surfaces. It can also be shaped, trimmed and adjusted as needed.
PX-1 Extreme takes a different approach. ARCTIC combines a firmer, high-density composition with artificial diamond powder. The company says the firmer texture gives extra stability during installation. It also says the material is built for applications that need increased mounting pressure.
The Club386 coverage adds a useful caveat. It notes that Arctic rates PX-1 Extreme at 15% elongation, which puts it closer to a thermal pad than thermal putty. In practice, the Extreme is the less putty-like of the two. It is also thinner than PX-1.
The pad-replacement framing needs a caveat​
The eTeknix headline says the putty "replaces GPU thermal pads". That is slightly broader than what ARCTIC itself says.
ARCTIC's own PX-1 Extreme product page draws a clear line. For the processor (CPU or GPU) it recommends thermal paste, and for everything else (VRAM, VRM, NAND) it recommends thermal putty. The page lists paste such as MX-4 and MX-7 as best for CPUs and GPUs. It lists PX-1 putty as best for VRAM, VRM and uneven heights.
So this is not a replacement for the paste on your GPU die. It is aimed at the memory chips and power-delivery components around the die.
What isn't proven yet​
All of the performance language is ARCTIC's own. The coverage I reviewed contains no independent thermal testing. ARCTIC says the diamond powder supports superior thermal conductivity. The Dutch outlet TechTesters points out that ARCTIC's announcement doesn't say how much better the Extreme actually cools.
The sources I reviewed don't establish the following:
  • Lower GPU temperatures.
  • Better performance than any specific competing pad or putty.
  • Compatibility with any particular graphics card model.
  • How long the material lasts before it dries out or hardens.
Readers in the TechPowerUp comments raised the durability question. One commenter quoted ARCTIC's storage-box description. That description says the box and tools help prevent deformation or drying out. This is reader commentary on a manufacturer claim, not a test result.
If you plan to service a card, check what your specific card and cooler need before buying. Some coolers rely on pads of a specific thickness and compression. Putty that squashes too thin, or sheet material that is too firm, could change how the cooler seats on the die. That is general industry knowledge, not something ARCTIC has said about these products.
Price and availability​
Both versions are on sale. TechPowerUp says the series is available in the ARCTIC webshop with a 40% discount, and also on Amazon, eBay and from selected partners. Vortez lists the discounted prices as €20.99 for PX-1 (MSRP €34.99) and €61.79 for PX-1 Extreme (MSRP €102.99).
These are European prices, and the ARCTIC pages say they include VAT and exclude shipping. They are launch-period figures and may change. eTeknix notes the Extreme costs about three times as much as the standard version. It also says ARCTIC's 25th anniversary year may bring further promotions. I can't verify that claim from the other sources I reviewed.
On value, TechPowerUp commenters defended the Extreme's price. They pointed to the quantity of material and the included tools. Per gram, the Extreme costs much more than the standard version. Without independent tests, the extra money buys a manufacturer claim about the diamond powder and a firmer product for high-pressure mounting.
Bottom line​
  • Who it's for: anyone re-padding a GPU, or cooling VRMs and memory where gap heights vary.
  • Which one: PX-1 for general use. PX-1 Extreme if your cooler clamps down hard and you want a firmer material.
  • What to hold off on: treating the Extreme's extra cost as proven performance. Reviews and measured temperatures should settle that.
  • What it isn't: a substitute for thermal paste on the CPU or GPU die.
If independent tests turn up, the key question will be simple. Does the putty outperform a correctly sized pad, or does it just make life easier at the workbench? Convenience has value of its own. But nobody should pay triple for diamond dust on faith.
  1. ARCTIC PX-1 Putty Replaces GPU Thermal Pads - eTeknix eTeknix 2026-11-18T09:05:14+00:00
  2. ARCTIC PX-1 Adaptive Thermal Putty | VRAM & VRM Cooling arctic.de
  3. Arctic's new PX-1 thermal putty pads should make graphics card servicing loads easier club386.com
