An open laptop sits on a marble desk overlooking Dubai’s skyline, with the Burj Khalifa visible through the window.
The ASUS ExpertBook A7 is a handsome, light Windows 11 Pro laptop with a very good matte OLED screen. In the UAE it costs AED 7,599. Tbreak UAE reviewed the 14-inch Intel model on November 8, 2026, gave it 7 out of 10, and concluded that the price is the main obstacle. Its other complaints are battery life, an imprecise trackpad, a hazy webcam and fans that start at odd moments.
The price needs one caveat. That figure is for the configuration Tbreak tested: Core 7 350, 16GB of RAM and a 512GB SSD. It isn't a confirmed price for every retailer or variant. When Tbreak covered the UAE launch on October 15, ASUS had said the laptop would be 1cm thin and start at 1.2kg. That earlier report said ASUS had not yet announced a UAE price or retailers.
An open laptop sits on a marble desk overlooking Dubai’s skyline, with the Burj Khalifa visible through the window. What was tested​
ItemReviewed configuration
OSWindows 11 Pro 64-bit
CPUIntel Core 7 350, 6 cores / 6 threads, up to 4.8GHz
Memory / storage16GB LPDDR5X, 512GB PCIe 4.0 SSD
Display14-inch 2880 × 1800 OLED, 16:10, 120Hz, matte, 500 nits, 100% DCI-P3
Battery / charging65Wh, 65W USB-C
Ports2× USB-C (USB 3.2 Gen 2, charging and display output), USB-A, HDMI, 3.5mm jack
Size / weight311 × 214 × 9.9–11.9mm, about 1.2kg
The review says there is no Thunderbolt. That fits Intel's own listing of the chip, which shows Thunderbolt 4 as a platform capability. Whether a laptop uses it is up to the maker. In this case ASUS used plain USB-C ports.
Where the review is strongest​
The display. Tbreak calls the 120Hz matte OLED the star of the machine. The reviewer found colours vibrant without being oversaturated, blacks deep and viewing angles excellent. He also found the matte coating cut reflections without much loss of contrast. The one exception was a very bright light, such as a window, shining directly on the screen. Most OLED laptops are glossy, so a matte panel is a real selling point for people who work in bright rooms.
Build and portability. The CNC-machined aluminium unibody felt sturdy, with no flex or creaking. The hinge opens with one finger and holds the screen steady. Tbreak says that is better than the looser hinge on the pricier ExpertBook Ultra it reviewed earlier this year. The reviewer did find the edges slightly sharp and missed the Ultra's ceramic-style finish.
Everyday speed. In the reviewer's use, tabs, app switching and light image editing ran without stutter, on battery or plugged in. Tbreak's measured results:
  • Geekbench CPU: 2,231 single-core and 7,489 multi-core
  • Geekbench GPU: 12,415
  • Geekbench AI (ONNX, CPU): 4,676
  • PCMark 10: 6,480 overall, with Productivity at 12,861
  • CrystalDiskMark: 6,657MB/s sequential read and 4,640MB/s sequential write
One inconsistency matters if you compare these numbers. Tbreak's text calls the CPU tests Geekbench 7, but its results table labels them Geekbench 6. Treat the version as unconfirmed before setting these scores against other sites' results. Tbreak itself says its Apple M5 figures (4,155 single-core and 16,928 multi-core) came from Geekbench 6 and aren't directly comparable. Another reviewer, Ultrabookreview, reported Geekbench 6.6.0 scores of 7,354 multi-core and 2,506 single-core for the same chip. Those figures are in the same range for multi-core. Single-core differs noticeably, as you'd expect from different units and test conditions.
The Core 7 350 is not a fast chip​
The "Core 7" name suggests more than the chip delivers. Intel lists the Core 7 350 as a mobile Core Series 3 part, formerly Wildcat Lake. It has 2 Performance cores and 4 Low-Power Efficiency cores, with 6 threads. Intel also says processor numbers are not a measure of performance. Notebookcheck's early hands-on put it plainly: good efficiency, but relatively low raw performance, so it suits everyday office tasks without heavy multitasking.
Tbreak's own comparisons point the same way:
  • It is about 26% faster in multi-core than the cheaper Core 5 320 in the Acer Swift Air 14, with GPU performance nearly identical.
  • It is well behind the Snapdragon X in the Zenbook 14, which scored 11,304 multi-core against 7,489 for the A7. Tbreak says the Zenbook is considerably cheaper.
  • It is in a different class from the Apple M5, which Tbreak says makes the price harder to justify.
Battery life: 5–6 hours against a claim of 26​
ASUS advertises up to 26 hours. Its test notes say that figure comes from a 350-equipped unit with 16GB RAM, 512GB SSD and 65Wh battery, with display brightness at 50% and 50% volume on wired earphones. Tbreak's FAQ describes it as a local video-playback test. Tbreak got about 5–6 hours of mixed work with the screen at 120Hz and brightness following the room.
Those two numbers measure different things, so neither is wrong. Even so, the gap is wide, and Tbreak says a couple more hours may be possible at 60Hz with sensible brightness. That is the reviewer's estimate, not a test result. Tbreak's other battery figures, for context:
  • Acer Swift Air 14: around 8–10 hours
  • Zenbook 14: around 6–7 hours
  • MacBook Air M5: roughly 11–12 hours
These come from different machines and different screens, so they are a rough guide only.
Fans, keyboard, trackpad and webcam​
  • Fans: Quiet and cool under benchmarks, but they spun up during light browsing and soon after boot. The reviewer guessed at a background Windows process or ASUS fan management. He did not establish a cause or test a fix, so this shouldn't be treated as a known defect.
  • Keyboard: Shallow 1.1mm travel. It is fast and tiring-free once learned, but the key spacing caused typos at first.
  • Trackpad: Large glass haptic pad. Good for gestures and browsing, but the cursor feels slightly loose for precise work.
  • Webcam: 2MP Full HD with IR for Windows Hello. Image quality is hazy and grainy, and there is no privacy shutter.
  • Security: A fingerprint reader sits in the power button.
Discrepancies to check before you buy​
  • Wi-Fi: Tbreak's spec table says Wi-Fi 7 and Bluetooth 5.4. ASUS's own product page says Wi-Fi 6E, as did Tbreak's earlier launch report. Treat Wi-Fi 6E as the manufacturer's stated spec.
  • USB-A speed: Tbreak lists USB 3.2 Gen 2, but the ASUS model listing labels it Gen 1. Check the exact SKU.
  • Anti-glare: ASUS describes the anti-glare coating as optional. The reviewed unit had it. Confirm your configuration includes it.
  • Specs: Tbreak lists 2 Xe3 cores, while Intel's page lists 2 Xe-cores. Don't read much into the generation label.
Business features, as claimed by ASUS​
Tbreak's launch report lists the following, all of them manufacturer claims:
  • Windows 11 Secured-core PC support
  • A discrete TPM 2.0 chip
  • FIDO2 fingerprint sign-in
  • NIST SP 800-193-compliant BIOS protection
  • A Kensington Nano Security Slot
  • Five years of BIOS and driver security updates
  • MIL-STD-810H durability testing, which ASUS notes is done under laboratory conditions
The ASUS MyExpert AI suite handles document search, summaries, translation, writing help and meeting transcription. ASUS says availability can vary by country and model. For IT admins, the five-year update promise is probably the most useful item on that list, though the review didn't test it.
The price comparison​
Tbreak sets the A7 against the 15-inch MacBook Air M5 with the same 16GB and 512GB, listed at AED 6,299. That is AED 1,300 less, for a bigger screen and much more speed. The review's own buying advice is conditional:
Buy it if you want a light Windows laptop, work in bright rooms and want a matte OLED, or plug into projectors and monitors often. HDMI and USB-A help there.
Skip it if you need battery life well past a working day, you can use macOS, you need a precise trackpad, or you want a webcam shutter.
Is the price out of line?​
AED 7,599 looks steep against what the A7 delivers. Other markets show how much room there is. In the US, ASUS launched the A7 at $1,299.99 with the Core 5 320 and Windows 11 Home. A Core 7 350 with Windows 11 Pro costs $1,599.99. The UAE price is for a Core 7 350 with Windows 11 Pro. Currency conversion and local taxes make a direct comparison unreliable. Still, the US pricing suggests the A7 mostly works as a design-and-display play and not a performance one. Buyers who don't need the Core 7 350 or Windows Pro may find the cheaper configurations better value, where they are sold.
Tbreak's verdict is fair on the evidence it presents: a very good screen and body, held back by price, endurance and a few rough edges. The fan oddity may be fixable in software, but nobody has shown that yet, and a review can only judge the laptop as it ships.
  1. ASUS ExpertBook A7 Review: Great OLED, Tough AED 7,599 Sell - Tbreak UAE Tbreak UAE 2026-11-08T09:12:33+00:00
  2. ASUS ExpertBook A7 UAE: 3K OLED, 1.2kg, November tbreak.com
  3. ASUS ExpertBook A7 (14” Intel) | Thin, Light, Refined | ASUS asus.com
