A 14-Inch Windows Studio Without the Dongle Circus
According to Tom’s Guide, the ProArt P14 nails nearly every ergonomic and hardware fundamental that makes a mobile workstation enjoyable to live with. Measuring 0.55 inches thin (0.55 to 0.63 inches per Asus’s official dimensions) and weighing 3.26 pounds, the CNC-crafted chassis—available in Neo White and Nano Black—matches the footprint of a 14-inch MacBook Pro closely enough that Tom’s Guide previously described it as rolling tanks onto Apple’s turf.
Where many ultra-thin laptops celebrate minimalism by forcing users into a tangle of USB-C hubs, Asus kept a full creator toolkit intact. Official specifications for the H7407BA confirm three 40Gbps USB4 Type-C ports (supporting display output and power delivery), one USB 3.2 Gen 2 Type-A port, HDMI 2.1, a 3.5mm combo audio jack, and a full-size SD 4.0 card reader, alongside Wi-Fi 7 and Bluetooth 5.4. Tom’s Guide also highlighted the snappy keyboard, responsive Asus HapticPad (notably dropping Asus’s older physical dial), and surprisingly punchy Smart Amp speakers that rival Apple’s 14-inch MacBook Pro.
The centerpiece is the 14-inch 3K (2880 × 1800) Lumina Pro OLED touchscreen running at 120Hz with 100% DCI-P3 coverage and VESA DisplayHDR True Black 1000 certification. Tom’s Guide praised the panel’s outdoor visibility, color precision in Photoshop and Premiere Pro, and fluid motion in titles like Forza Horizon 6. Prospective buyers should note one subtle wrinkle in Asus’s official spec sheet, however: H7407BA configurations ship with two different 3K Lumina Pro OLED tiers—a standard OLED rated at 500 nits SDR (1,100 nits HDR peak) and a Tandem OLED panel rated at 700 nits SDR (1,600 nits HDR peak). Checking the exact sub-model code before ordering matters.
Battery Stamina Beats Its RTX Spark Rivals
Cramming a 90Wh battery into a 14-inch frame paid off in Tom’s Guide’s testing. In its web-browsing battery benchmark, the ProArt P14 lasted 12 hours and 32 minutes—easily clearing a full workday or long-haul flight and outlasting several larger or similarly pitched Windows competitors.
| Laptop & Platform | Measured Web-Browsing Battery Life (Tom’s Guide) |
| Asus ProArt P14 (Nvidia RTX Spark) | 12:32 |
| Microsoft Surface Laptop Ultra (Nvidia RTX Spark) | 10:15 |
| Asus ProArt PX13 GoPro Edition (AMD Ryzen AI Max 395+) | 11:12 |
| Asus Zenbook A16 (Snapdragon X2 Elite) | 10:26 |
| 16-inch MacBook Pro (Apple M5 Pro) | 21:25 |
While Apple’s M5 Pro 16-inch MacBook Pro still sits in another stratosphere for endurance, clearing 12.5 hours on a Windows laptop packing RTX-class graphics is an impressive feat. That longevity, however, is directly tied to how Asus manages power limits out of the box.
Section Summary: In physical design, port selection, display quality, and measured endurance, the ProArt P14 delivers one of the most cohesive 14-inch Windows creator packages on the market.
Where Physics Collects Its Debt: The 80W Ceiling and Lap Heat
To keep that slim 14-inch chassis from melting—and to hit 12.5 hours off the charger—Asus had to rein in total system power. Tom’s Guide benchmarks laptops in their default out-of-the-box power profile, noting that turning up power settings improves speed at the expense of battery life. Even when switched to manual mode, the ProArt P14 tops out at an 80-watt TDP, well below the 135W combined CPU/GPU thermal design of its larger sibling, the ProArt P16, and the 140W sustained TDP available in desktop RTX Spark mini PCs like the Asus ProArt GR1X tested by Windows Central.
Independent testing from Notebookcheck on the 20-core P14 variant similarly observed power draw settling around 75W down to 58W under sustained loads. That power ceiling shows up clearly when Tom’s Guide’s benchmark numbers are stacked against the larger Microsoft Surface Laptop Ultra:
| Benchmark (Tom’s Guide Out-of-Box Testing) | Asus ProArt P14 (RTX Spark) | Microsoft Surface Laptop Ultra (RTX Spark) | MacBook Pro 16-inch (M5 Pro) |
| Geekbench 7 Single-Core | 2,672 | 2,704 | 3,690 |
| Geekbench 7 Multi-Core | 22,027 | 23,610 | 29,659 |
| 3DMark Fire Strike Ultra (x64) | 6,480 | 7,492 | N/A |
| 3DMark Time Spy Extreme (x64) | 4,760 | 6,060 | N/A |
| 3DMark Steel Nomad | 2,340 | 2,912 | 2,335 |
| 3DMark Solar Bay Extreme | 8,716 | 10,594 | 9,108 |
Note also that Asus builds the ProArt P14 with two distinct RTX Spark N1X silicon tiers: an entry 18-core Grace CPU with a 5,120-core Blackwell GPU, and an upper-tier 20-core Grace CPU with a 6,144-core Blackwell GPU. Tom’s Guide’s spec table lists the 18-core/5,120-core chip for the base model while noting its reviewed unit packed 32GB of unified memory and a 1TB SSD, underscoring that performance comparisons across RTX Spark laptops depend heavily on both SKU tier and thermal envelope.
Even at 80 watts, heavy workloads generate unmistakable heat. Tom’s Guide warns that the P14’s large, exposed bottom intake vents push warm air onto the user and are far too easy to choke on soft surfaces like blankets or duvets. For light web browsing, UltrabookReview noted that Asus’s Whisper and Standard modes keep the fans quiet or completely idle, though fan noise ramps toward 48 to 50 dBA when pushing maximum power. For rendering, local AI inference, or gaming, Tom’s Guide’s practical advice is blunt: keep the ProArt P14 on a flat desk or table.
Section Summary: An 80W power cap and exposed bottom vents leave measurable GPU and multi-core performance on the table compared with larger RTX Spark systems, turning the P14 into a desk-bound workstation whenever heavy loads kick in.
The Windows 11 on Arm & Local AI Reality Check
For Windows power users and IT buyers, evaluating the ProArt P14 requires understanding what makes RTX Spark N1X fundamentally different from a standard x86 Intel or AMD laptop with a discrete GeForce RTX GPU.
- Unified Memory for Massive Local Models: Rather than splitting system RAM and 8GB–16GB of discrete VRAM, RTX Spark pairs an Arm-based Nvidia Grace CPU with a Blackwell RTX GPU sharing soldered LPDDR5X-9400 unified memory in 24GB, 32GB, 48GB, or 128GB capacities. Asus notes that 128GB configurations can run large language models up to 120 billion parameters locally without cloud token fees, with up to 96GB allocatable to the GPU—a workflow Asus pairs with preloaded tools like MuseTree, StoryCube, ComfyUI, and Nous Research’s Hermes Agent.
- Strict Windows 11 Version Requirements: According to Asus’s official H7407BA specification disclaimer, drivers for the ProArt P14 are only compatible with Windows 11 version 24H2 or later, and attempting to downgrade to Windows 10 or older builds will cause compatibility issues.
- No Post-Purchase Memory Upgrades: Because the unified memory is soldered directly to the board, buyers cannot upgrade RAM later. Only storage can be expanded via the single M.2 2280 PCIe slot (listed as PCIe 5.0 x4 on Asus’s spec sheet, typically shipped with a 512GB or 1TB PCIe 4.0 drive).
- Gaming and Emulation Caveats: While native Windows on Arm and well-supported CUDA creative apps run briskly, broader testing across RTX Spark laptops indicates that x86/x64 games relying on translation layers—such as Cyberpunk 2077—can suffer noticeable frame-rate drops and uneven 1% lows compared with conventional RTX 50-series gaming laptops.
Clearing Up the Pricing Confusion
If you are cross-shopping the ProArt P14, watch the price tags closely—including within Tom’s Guide’s own review. Tom’s Guide cites $3,699 in its verdict and "Reasons to avoid" summary, yet earlier in the same review states its tested 32GB/1TB unit costs $3,099 (£3,199 in the U.K.) while listing the base P14 at $2,699 alongside a $3,699 Microsoft Surface Laptop Ultra in its comparison table.
Official launch documentation and retail listings help clarify the picture: Asus’s October 16, 2026 U.S. availability announcement lists the ProArt P14’s starting MSRP at $2,599.99, matching Best Buy’s launch listing of $2,599 for the 24GB/512GB entry configuration. Meanwhile, UltrabookReview’s October 16 coverage places the step-up 20-core/32GB/1TB model at $3,099, with 48GB and flagship 128GB memory tiers climbing significantly higher. Regardless of which tier you eye, early-adopter RTX Spark pricing carries a steep premium—and on the 14-inch P14, you are paying a miniaturization tax on top of it.
Verdict: Who Should Actually Buy the ProArt P14?
Tom’s Guide’s verdict sums up the dilemma cleanly: the Asus ProArt P14 is arguably the most likable portable Windows creator laptop of its generation, yet it is not the fullest expression of what Nvidia’s RTX Spark silicon can deliver.
- Buy the ProArt P14 if you are a traveling developer, designer, or video editor who refuses to carry a 16-inch brick, demands a color-accurate 14-inch 3K OLED display with a real SD card slot, needs 12+ hours of light productivity away from a wall outlet, and specifically wants local CUDA acceleration or high-capacity unified memory in a MacBook Pro 14-sized shell.
- Skip it for a larger chassis if raw GPU throughput, sustained multi-hour rendering, or peak tokens-per-second matter more than shaving half a pound out of your backpack. Stepping up to the Asus ProArt P16 unlocks up to 135W of thermal headroom, while systems like the Microsoft Surface Laptop Ultra or desktop ProArt GR1X extract noticeably higher performance from the exact same Nvidia silicon.
For Asus’s next iteration, Tom’s Guide has a simple request: add a couple of millimeters of thickness for extra cooling headroom. Until then, the ProArt P14 remains a dazzling, long-lasting travel companion—just remember to give those bottom vents a solid desk when it’s time to put the silicon to work.
- I really wanted the Asus ProArt P14 to be my favorite RTX Spark laptop — and it’s painfully close - Tom's Guide Tom's Guide · 2026-11-23T13:00:00+00:00
- ASUS ProArt RTX Spark Laptops Now Available for Purchase asus.com
- notebookcheck.net notebookcheck.net
