A collage showcases RGB-lit gaming PCs, colorful case fans, and a small display monitoring system performance.
ASUS is preparing a Japan launch for two enthusiast PC components: the ROG Cronox ARGB full-tower case and ROG Eurux GR120 ARGB fan series. According to ASCII.jp, both are scheduled for October 9, 2026, with the case pairing a panoramic glass enclosure and adjustable 9.2-inch display with four included fans. The separate Eurux series brings a 30mm-thick design and daisy-chain connectivity—but also a hub requirement builders should understand before buying.
A collage showcases RGB-lit gaming PCs, colorful case fans, and a small display monitoring system performance. Microsoft Defender: No threats detected Scan details Japan launch and pricing​
ASCII.jp reports the following Japanese prices:
ProductReported price
ROG Cronox ARGB case¥105,980
ROG Eurux GR120 ARGB single fan¥6,480
ROG Eurux GR120 ARGB three-pack¥19,980
The case will be offered in black and white. These figures concern the Japanese announcement; the October 9 launch should not be treated as a worldwide release date. ASCII.jp labels its English coverage as AI-translated from Japanese.
Cronox: a showcase with room for cooling​
The Cronox ARGB combines curved tempered glass, aluminum trim, and ambient lighting on its top panel and feet. Its hinged 9.2-inch IPS screen has a 1920 × 462 resolution, 60Hz refresh rate, and, according to ASUS, 400-nit brightness. ASUS describes a customizable dashboard for CPU, GPU, memory, networking, and fan information, alongside clock and notification functions.
The useful distinction is that this is an ASUS-provided monitoring display, not a new Windows feature. Its appeal depends on whether an at-a-glance dashboard is valuable to your setup—or simply another surface demanding a carefully chosen wallpaper.
Cooling capacity reaches 14 120mm fans, with support for two 360mm radiators. ASUS identifies the included arrangement as three reverse-blade side intake fans and one standard rear exhaust fan. A rotatable side bracket lets builders adjust airflow direction. Four fans are included, not fourteen; the larger number describes expansion capacity.
Assembly provisions include a tool-less graphics-card slot clamp and removable PSU bracket. ASCII.jp also reports E-ATX and back-connector motherboard support, graphics cards up to 400mm long, and two USB 20Gbps Type-C ports with up to 60W charging. ASUS qualifies fast charging as available “where compatible,” so that rating is not a universal promise for every connected device.
Eurux fans: the hub is mandatory​
The Eurux GR120 ARGB series uses LCP blades, a 0.6mm blade-to-frame gap, and a CNC-machined brass bearing housing. Lighting consists of 36 LEDs across three zones, configurable through Armoury Crate and compatible with Aura Sync. ASUS presents these construction choices as supporting cooling, stability, and quieter operation; they are manufacturer claims rather than independent comparative findings.
The dedicated ROG hub is required for operation, ASUS explicitly states. It is included with the three-pack and offered separately. The hub supports up to 14 fans, has dual SATA power inputs, and includes an electrical fuse and magnetic mounting. A single fan therefore is not a complete standalone installation unless the builder already has the required hub.
Standard and reverse-blade variants also have different advertised specifications:
ASUS-rated maximumStandardReverse-blade
Speed2,600rpm2,200rpm
Airflow85 CFM70 CFM
Static pressure4.5mm H₂O3.0mm H₂O
Noise33dB(A)32dB(A)
These are published ratings, not measured results from a completed Cronox build. Choosing blade orientation is consequently more than a cosmetic decision.
A clearance detail worth checking​
There is a documentation discrepancy: ASUS describes the separately sold Eurux fans as 30mm thick, while a summary bullet on its Cronox ARGB page calls the included fans 120 × 25mm. Both pages identify them as Eurux GR120 models, but the inspected material does not resolve that thickness difference.
The practical takeaway is straightforward: confirm the exact bundled fan specification and planned radiator clearances before ordering. Do not assume matching model names settle every dimension.
Cronox offers an ambitious combination of display, glass, and cooling flexibility. For PC builders, though, the important questions remain refreshingly unglamorous: does the hardware fit, is the required hub accounted for, and does the chosen airflow layout suit the build? The LCD gets attention; those answers determine whether the project goes smoothly.
  1. ASUS "ROG CRONOX ARGB" Launches October 9th, Featuring PC Case with 9.2-inch LCD and 30mm-Thick ARGB Fans - ASCII.jp ASCII.jp 2026-10-08T02:15:00+00:00
  2. ASUS Announces ROG CRONOX ARGB PC Case with 9.2-inch LCD, Also Introduces 30mm Thick Fans - ASCII.jp ASCII.jp 2026-10-09T00:00:00+00:00
  3. ROG Cronox ARGB | Gaming Cases|ROG - Republic of Gamers|ROG USA rog.asus.com
