Hands-on testing by Philipp Briel at Basic Tutorials, corroborated by ASUS’s official ROG hardware specifications and independent testing from Absolute Geeks, paints a clear picture of who this €169.90 ($169.99 on the US ASUS Store) flagship is actually built for—and where its sky-high specifications run into practical limits on a Windows 10 or Windows 11 desktop.
ASUS ROG Gladius IV Ace: Core Specifications
Before diving into how the mouse behaves on a desk pad, here is how ASUS configures the hardware on paper and in the box:
| Specification | Details |
| Form Factor | Right-handed ergonomic |
| Dimensions | 127.5 × 67.7 × 44.15 mm (L × W × H) |
| Weight | 56 g base; adjustable in 8 steps up to 71 g (includes 3 g, 5 g, and 7 g weights) |
| Sensor | ROG AimPoint Pro 65K optical (up to 65,000 DPI, 800 IPS, 70 G acceleration, up to 20,000 FPS scan rate) |
| Lift-Off Distance | 11 selectable levels |
| Main Switches | ROG 100M Optical Micro Switches (rated for 100 million clicks) |
| Buttons | 6 programmable top/side buttons + scroll wheel (bottom pairing and DPI buttons are not programmable) |
| Connectivity | 2.4 GHz ROG SpeedNova 8K Gen II Wireless, Bluetooth 6.0, Wired USB 2.0 (2 m ROG Paracord, USB-C to USB-A) |
| Polling Rate | Up to 8,000 Hz over both USB wired and 2.4 GHz wireless |
| Onboard Memory | 5 hardware profiles |
| Lighting | None (No RGB / No Aura Sync support) |
| Software & OS | ROG Gear Link (web-based) for Windows 10 and Windows 11 |
| Color Options | Black, Moonlight White, Aqua Blue, Lava Red |
| Retail Pricing | €169.90 European MSRP / $169.99 ASUS US Store listing |
Section Summary: The Gladius IV Ace combines a full-sized right-handed shell with an ultralight 56 g starting weight, an 8,000 Hz wireless and wired polling ceiling, and zero RGB lighting.
Ergonomics, Build Quality, and Precision-Matched Clicks
The Gladius line has always catered to right-handed players who want an asymmetrical contour rather than an ambidextrous potato. According to ASUS, the Gladius IV Ace’s shell was shaped through sports-science evaluations with esports players to feature a wider palm rest and a taller dorsal rise aimed at reducing muscle strain during repetitive lifting and swiping.
In practical use, dimensions dictate compatibility more than marketing claims. At 127.5 mm long and 44.15 mm tall, the mouse has a pronounced rear curve and an elongated silhouette. In Basic Tutorials’ testing, that contour provided strong support for a full palm grip and remained easy to control in a claw grip, noticeably reducing hand and forearm fatigue during both gaming and long office or video-editing sessions. Absolute Geeks similarly reported that the shape eased hand strain during repetitive timeline work in Adobe Premiere Pro. However, both publications warn that the elongated body and full rear hump make the mouse unsuitable for small hands, and Basic Tutorials found it too long and bulky for a pure fingertip grip.
Structurally, the matte plastic chassis exhibits no creaking or button play, and the box includes pre-cut grip tape (which adds roughly 1.5 grams when applied), a 2-meter paracord cable, replacement 100% PTFE glides, a silicone receiver skin, a pick tool, and a travel carry case.
One standout manufacturing detail is how ASUS handles the main left and right ROG 100M Optical Micro Switches. Because optical actuation avoids physical metal-leaf debounce delays, it eliminates traditional mechanical double-click wear. To prevent the hollow or mismatched click feel that sometimes plagues optical designs, ASUS sorts its switches by actuation force prior to assembly and machine-tests each finished unit so the left and right buttons stay within a 5-gram-force (5 gf) tolerance of one another. In Basic Tutorials’ hands-on evaluation, the two primary triggers felt crisp and indistinguishable from each other.
Section Summary: Built for medium-to-large right hands using palm or claw grips, the Gladius IV Ace pairs a rigid matte shell with factory-sorted optical switches that deliver uniform click tension.
The Central Weight System: Eight Steps from 56g to 71g
Most modern esports mice glue in the smallest battery they can get away with and leave the weight permanently fixed. ASUS instead gives the Gladius IV Ace a 56-gram default mass and includes three stackable metal weights—3 g, 5 g, and 7 g—that install into a central chamber in the base. Because the mass sits near the mouse's center of gravity, adding weight increases overall inertia without throwing off the front-to-back balance when you lift the mouse off the pad.
By mixing and matching those three inserts, users can tune the mouse across eight distinct weight tiers:
- Default (no weights): 56 g
- +3 g weight: 59 g
- +5 g weight: 61 g
- +7 g weight: 63 g
- +3 g + 5 g weights: 64 g
- +3 g + 7 g weights: 66 g
- +5 g + 7 g weights: 68 g
- All three weights (+3 g, +5 g, +7 g): 71 g
While the granularity is a genuine differentiator for players transitioning from heavier mice—or those who want a steadier feel for precision design work—both Basic Tutorials and Absolute Geeks noted that the physical installation is somewhat fiddly. Basic Tutorials specifically pointed out that the tiny retaining screw used to lock the weights in place is tricky to thread the first time. Still, because most users settle on a preferred weight and leave it alone, it is a minor setup annoyance rather than a daily flaw.
Section Summary: Central modular weights allow eight balanced configurations between 56 g and 71 g, though threading the small retaining screw takes patience during initial setup.
Sensor Headroom, 8,000 Hz Wireless, and the Battery Reality
Under the hood sits the ROG AimPoint Pro 65K optical sensor, rated up to 65,000 DPI, 800 inches per second (IPS) tracking speed, 70 G acceleration, and a scan rate up to 20,000 frames per second. It also carries official verification for the NVIDIA Reflex Latency Analyzer.
Does any human being actually need 65,000 DPI on a Windows desktop? Of course not. Even in Basic Tutorials’ multi-day testing, cranking the mouse to 65,000 DPI turned the Windows cursor into an uncontrollable blur where human motor skills became the bottleneck just trying to click desktop icons. Basic Tutorials found the sensor remained surprisingly controllable even at unusually high settings between 30,000 and 50,000 DPI, and tracked without skipping, jitter, or unwanted correction across standard pads and bare glass surfaces alike. From an engineering standpoint, a 65K ceiling is best understood as proof of sensor headroom and high-FPS scan stability rather than a usable sensitivity target.
Where competitive players will pay closer attention is the wireless pipeline:
- ROG SpeedNova 8K Gen II: Operating over 2.4 GHz RF, ASUS claims its upgraded microcontroller unit (MCU), larger desktop receiver antenna, and Active Dynamic Hopping architecture cut wireless latency by 40% compared to the prior generation while scanning for clear radio channels in congested environments. The rubberized desktop dongle includes two customizable LEDs that display real-time RF signal quality, battery status, or active profiles.
- Zone Mode & Dynamic TX Power: Ditching RGB lighting completely, ASUS includes a hardware "Zone Mode" toggle that locks in competitive sensor framing, sampling, and radio settings. Users can also switch the wireless transmitter between Full TX Power (maximizing anti-interference strength for tournament or crowded RF rooms) and Environment Adaptive mode (scaling radio power to save battery).
The High-Polling Battery Trade-Off
Running an optical sensor at maximum scan rates while transmitting 8,000 packets per second over 2.4 GHz wireless takes a heavy toll on battery life. In Basic Tutorials’ continuous test at an 8,000 Hz polling rate and maximum sampling rate, the battery lasted approximately 17 hours—a figure echoed by Absolute Geeks, which recorded about 16 hours at maximum polling. Switching to Bluetooth 6.0 extends runtime substantially for everyday work, and the mouse recharges over its 2-meter USB-C paracord cable (no wireless charging dock is included).
For Windows 11 gamers, it is also worth noting from general PC hardware experience that 8,000 Hz polling demands extra CPU interrupt processing and only shows its visual smoothing benefits on high-refresh-rate monitors (240 Hz and above). Dropping the polling rate to 1,000 Hz or 2,000 Hz for casual play or desktop work is the easiest way to avoid plugging the cable in every second day.
Section Summary: The AimPoint Pro 65K sensor tracks cleanly even on glass and delivers true 8,000 Hz wireless polling, but running flat-out drains the battery in roughly 16 to 17 hours.
Leaving Armoury Crate Behind: ROG Gear Link on Windows
Perhaps the most welcome news for longtime Windows enthusiasts is what you don't have to install. Rather than forcing users to download the sprawling, background-service-heavy Armoury Crate suite just to change DPI steps, the Gladius IV Ace uses ROG Gear Link, a streamlined web-based configuration interface supported on Windows 10 and Windows 11.
Through Gear Link, users can configure the five onboard profiles, remap buttons, adjust polling rates, customize the receiver LEDs, and access deep sensor calibration controls. Those sensor tweaks include:
- 11-level lift-off distance (LOD) and manual/asymmetric cutoff calibration
- Dedicated glass-surface mode and manual surface calibration
- Angle snapping/detection and angle offset adjustment (useful for players who naturally hold their mouse at a slight tilt)
- Motion Synchronization and debounce timing controls
However, Basic Tutorials uncovered three practical caveats with the Gear Link ecosystem that buyers should keep in mind:
- Motion Sync Cap: Motion Sync—which aligns sensor data reads with USB polling intervals—can only be enabled up to 4,000 Hz; it is unavailable when running at the full 8,000 Hz polling rate.
- Connection Requirements: Gear Link only detects the mouse when connected via the USB cable or the 2.4 GHz SpeedNova receiver. You cannot configure the mouse while connected over Bluetooth.
- Companion App for Macros: While basic hardware tuning works entirely in the browser, assigning complex button macros or OS shortcuts requires installing the supplemental Gear Link Companion software.
Section Summary: Web-based ROG Gear Link is a fast, low-bloat alternative to Armoury Crate with deep sensor calibration, though Bluetooth connections aren't supported for configuration and Motion Sync tops out at 4,000 Hz.
Final Verdict: Who Should Buy the ROG Gladius IV Ace?
At €169.90 ($169.99 in the US), the ASUS ROG Gladius IV Ace sits firmly in flagship territory alongside top-tier wireless offerings from Razer and Corsair. It is not a one-size-fits-all peripheral: finger-tip grippers, left-handed users, and players with smaller hands should look elsewhere, and anyone planning to leave the mouse locked at 8,000 Hz 24/7 will need to keep the USB-C paracord within easy reach for frequent charging.
Yet for right-handed Windows users with medium-to-large hands who favor a supportive palm or claw grip, the Gladius IV Ace nails the fundamentals that actually matter in daily use. Its factory-matched optical switches feel identical under both fingers, the web-based Gear Link utility respects your Windows system resources, and the central weight system lets you dial in anything from a featherweight 56-gram flick mouse to a planted 71-gram workhorse without ruining its balance.
- ASUS ROG Gladius IV Ace Review: High-End Gaming Mouse for Right-Handed Users - Basic Tutorials Basic Tutorials · 2026-10-17T08:00:39+00:00
- ROG Gladius IV Ace Gaming Mouse | Wireless | Gaming GAMING MOUSE|ROG - Republic of Gamers|ROG Global rog.asus.com
- ROG Gladius IV Ace Gaming Mouse | Wireless | Gaming Mice|ROG - Republic of Gamers|ROG USA rog.asus.com
