As reported by Tom's Hardware, TrashBench chronicled the experiment in a 10-minute video titled "I Replaced Water Cooling With BABY OIL," pitting a diminutive Minisforum system's stock air cooler against an improvised DIY water loop and a five-liter baby-oil bath. Far from outperforming water, the baby-oil setup ran 12.5°C hotter in 3DMark Time Spy and slammed straight into thermal throttling during Cinebench.
Inside the Pint-Sized Test Rig (and a Spec Clarification)
To make the test genuinely challenging, TrashBench didn't sacrifice an ancient office thin client. He used a compact Minisforum mini-PC packing a 16-core Intel "Panther Lake" processor configured in a 4+8+4 layout (four Performance cores, eight Efficient cores, and four Low-Power Efficient cores) alongside integrated Intel Arc B390 graphics with 1,536 shader units and a package power budget hovering around 80 W.
There is one minor model-number wrinkle worth clearing up for hardware purists. Tom's Hardware identifies the chip as an Intel "Core Ultra X7 385H" with Performance cores hitting 4.6 GHz—a transposed model string that has popped up in a few retail and tech listings. However, Intel's official Core Ultra Series 3 documentation and independent reviews from Phoronix and Notebookcheck confirm that the actual 16-core (4+8+4), Arc B390-equipped Panther Lake SKU with an 80 W turbo power ceiling is the Core Ultra X7 358H, built on Intel's 18A node with a maximum turbo frequency of 4.8 GHz. Either way, stuffing 16 modern cores and 12 Xe3 GPU cores capable of entry-level discrete gaming performance into a palm-sized chassis gives any cooler plenty to chew on.
The $6 Supermarket Gambit vs. DIY Water
For his baseline, TrashBench first strapped a rough-and-ready DIY water-cooling loop onto the Minisforum machine—prioritizing thermal data over aesthetics or long-term practicality. That makeshift water setup worked wonders, slashing 3DMark Time Spy temperatures from 70.3°C on the stock cooler down to 42.5°C, and trimming Cinebench temperatures from a scorching 88.6°C to 80.2°C, pulling the chip safely back from the edge of thermal throttling.
Next came the audience-requested oil bath. Pure, purpose-engineered immersion cooling fluids can run several thousand dollars per drum, and even clean industrial mineral oil would have cost TB AUD $23 for five liters. Instead, guided by pure scrapyard economics, he picked up five liters of supermarket baby oil for just AUD $6—earning what he described as "some weird looks" at the checkout counter.
Once the mini-PC hit the tub, the complications started immediately:
- Stalled stock fans: TB checked whether the mini-PC's built-in fans would spin while submerged in oil. They wouldn't budge under the thicker fluid, forcing him to remove the fans, keep the metal heatsink attached, and wire up a much larger external pump to push oil through the basin.
- Heatsink-on baby-oil results: Even with the larger pump circulating five liters of baby oil over the heatsink, Time Spy settled at 55°C—a full 12.5°C warmer than the DIY water loop. Under Cinebench's heavier all-core load, the processor climbed to 85.7°C and began thermal throttling.
- The heatsink-free disaster: Curious whether direct liquid contact with the chip package might help, TB stripped the heatsink off completely. The mini-PC promptly idled at 55°C and instantly throttled the moment he opened the HWiNFO monitoring utility, ending that test on the spot.
- Extra agitation didn't save it: Adding two large fans inside the oil basin alongside the pump to churn the fluid faster produced no meaningful improvement.
| Cooling Configuration (Reported by TrashBench / Tom's Hardware) | 3DMark Time Spy | Cinebench | Behavior / Notes |
| Stock Mini-PC Cooler | 70.3°C | 88.6°C | Near thermal throttling limit under Cinebench |
| DIY Water Cooling | 42.5°C | 80.2°C | Pulled system back from throttling |
| 5 L Baby Oil (Heatsink On + Large Pump) | 55.0°C | 85.7°C | +12.5°C vs. water in Time Spy; throttled in Cinebench |
| 5 L Baby Oil (No Heatsink) | — | — | Idled at 55°C; throttled instantly when opening HWiNFO |
(Note: These figures reflect TrashBench's single-system YouTube demonstration as relayed by Tom's Hardware; ambient room temperatures, run durations, power limits, and benchmark scores were not published, so they should be read as an empirical showcase of this specific build rather than a controlled laboratory ranking.)
Why Oil Runs Hotter Than Water: The Physics Behind the Mess
If both water and oil are liquids, why did a five-liter bath lose so decisively to a basic water loop? The answer comes down to three unyielding thermophysical bottlenecks where water dominates hydrocarbon oils:
- Thermal conductivity: Water transfers heat energy at roughly 0.6 W/m·K. By contrast, mineral and transformer-style oils typically measure around 0.12 to 0.16 W/m·K. Heat simply moves out of a copper cold plate or aluminum fin stack and into oil four to five times more slowly than it moves into water.
- Specific heat capacity: Water's specific heat capacity is 4.18 kJ/kg·K, roughly double that of thermal and mineral oils (around 2.0 kJ/kg·K). Every kilogram of water circulating past the CPU carries away roughly twice as much thermal energy per degree of temperature rise.
- Viscosity and boundary layers: Baby oil is dramatically more viscous than water, especially at room temperature. That syrupy drag stalls low-torque PC fans, forces pumps to work harder, slows fluid velocity across heatsink fins, and creates a sluggish thermal boundary layer that traps heat near the processor.
That physics also explains why ditching the heatsink was catastrophic. Without a fin array to multiply contact surface area, an 80 W modern SoC concentrates huge heat flux into a tiny silicon footprint. Sluggish, low-conductivity oil simply cannot wick that heat away fast enough on its own—even launching a lightweight sensor readout like HWiNFO spikes CPU load enough to hit the thermal wall.
Why Commercial Immersion Cooling Works (and Why Baby Oil Doesn't)
None of this means immersion cooling is a myth. Hyperscale AI data centers and high-density server farms increasingly rely on dielectric immersion tanks—but they don't fill plastic tubs with AUD $6 pharmacy lotion.
In enterprise single-phase immersion, servers sit in engineered, low-viscosity hydrocarbon or synthetic dielectric coolants paired with dedicated pumps and a Coolant Distribution Unit (CDU) that routes warm oil out to an external radiator or chilled-water heat exchanger. Without an external radiator shedding heat from the bath, five liters of uncooled oil simply acts as a giant thermal sponge that steadily warms up until the whole tank saturates. In two-phase immersion, sealed chambers use specialized fluorochemical fluids that actually boil off directly on the hot silicon, carrying heat away via latent heat of vaporization before condensing back down on overhead coils.
Even if you only want a novelty fish-tank PC for your desk, baby oil introduces nasty side effects that regular water loops avoid:
- Additives and fragrances: Standard supermarket baby oil typically contains perfumes ("parfum") or skin-care additives, and some modern brands substitute vegetable oils for mineral oil—ingredients that can oxidize, turn rancid, cloud up, or react poorly with warm electronics over time.
- Thermal paste and plastic degradation: As thermal-interface specialists like LiPOLY note in long-term immersion testing, continuous contact with hydrocarbon fluids can swell soft tubing, stress plastic connectors, and break down or wash out standard thermal pastes and pads, quietly ruining contact pressure between the chip and heatsink.
- Cleanup nightmare: Once a motherboard, SSD, and power circuitry have been bathed in oil, getting them dry and dust-free again is virtually impossible.
The Verdict for Windows PC Builders
TrashBench's greasy experiment is a great reminder of why water cooling remains the undisputed king for desktop and compact Windows PC builders chasing lower noise and higher boost clocks. Water is cheap, non-toxic, low-viscosity, thermally unmatched for the money, and built to work with off-the-shelf cold plates and radiators.
Oil immersion looks wild on YouTube and eliminates electrical shorting risks in an open bath, but unless you are ready to invest in low-viscosity engineered dielectric fluid, an external radiator loop, and immersion-safe thermal pads, that five-liter jug of baby oil belongs in the nursery—not anywhere near your 16-core mini-PC.
- Enthusiast tries cooling a 16-core mini-PC by dunking it in 5 liters of baby oil Tom's Hardware · 2026-11-29T12:00:00+00:00
- lipoly.com lipoly.com
- notebookcheck.net notebookcheck.net
