A stylish gaming setup displays a vivid sunset cityscape with 4K HDR, 120 Hz, and audio settings.
Grand Theft Auto VI is out November 19. If you're about to plug a console into a TV for it, a few minutes in the settings menus will help. The most useful checks are Game Mode and motion smoothing, audio routing, and HDR and resolution. This guide covers all three. It also covers what the game does and doesn't promise, and where the Xbox and PlayStation menus differ.
A stylish gaming setup displays a vivid sunset cityscape with 4K HDR, 120 Hz, and audio settings. What the game actually targets​
Rockstar's official site lists the game for PlayStation 5 and Xbox Series X|S with a November 19, 2026 release date. That's the platform list in the research notes. The same notes say Rockstar describes a 30 frames-per-second target. They also say the PS5 Pro gets sharper images through PSSR and ray-traced shadows that the base PS5 doesn't have.
There's a hard-to-miss caveat for Xbox players. Xbox Wire says GTA VI will also stream on Xbox One through Xbox Cloud Gaming from 1 a.m. ET on launch day, and the cloud version uses Xbox Series S graphics settings. The exact wording from Xbox is that the game uses Xbox Series S graphics settings when cloud-streamed. Your TV can't change how a streamed game is rendered. It can only change how the stream looks on your screen, so everything below matters most for native play on Series X|S and PS5.
Takeaway: a 30 fps target means you don't need a 120 Hz panel to match the game's announced frame rate. Treat 30 fps as a target, not a promise for every scene.
1. Game Mode or ALLM, and motion smoothing off​
BGR's Faith Leroux recommends turning on Game Mode or Auto Low Latency Mode (ALLM). Both cut input lag, which you notice in driving and shootouts. The same article says to make sure motion smoothing is off. Some sets turn smoothing off automatically in Game Mode, but the article says to check the picture, advanced or expert menus to be sure.
The reasoning is simple. With a 30 fps game, a TV that invents in-between frames adds delay and can leave smeared artifacts around fast objects like cars.
PlayStation's support pages add specifics for PS5:
  • ALLM switches a compatible TV into low-latency mode automatically while you play.
  • The setting lives at Settings > Screen and Video > Video Output > ALLM. Sony says the latest system software is required.
  • Setting ALLM to Off still triggers low-latency mode when VRR output is in use. To fully disable it, you also have to turn VRR off.
  • PS5 doesn't send an ALLM signal while a media app is running.
  • Not every HDMI 2.1 TV has ALLM, so check your TV's manual.
Sony also says ALLM may appear as "Game Mode" in a TV's menus. If your TV calls it something else, look for the game-labelled picture preset.
VRR and the 30 fps wrinkle​
BGR suggests leaving variable refresh rate on in case frame rate fluctuates. It also warns that a 30 fps target can sit below the native VRR window of many TVs, commonly 40 or 48 Hz. Where both display and source support low framerate compensation (LFC), frames are repeated to stay inside that window.
This is general display behavior from BGR. I found no confirmation from Rockstar about how GTA VI behaves with VRR or LFC. Sony says VRR results vary depending on the TV and the game. Leave it on as a safety net, but don't expect it to engage every time.
2. Audio: match the settings to what you actually listen on​
BGR's advice depends on your setup, so start by working out whether the sound goes to TV speakers, headphones, or a soundbar or receiver.
Soundbar or AV receiver​
BGR recommends two changes:
  1. Set the TV's digital audio output to Passthrough or Auto over HDMI eARC.
  2. Set the console's HDMI audio format to match your speakers, for example Dolby Atmos where supported. This avoids unnecessary conversion or downmixing.
This is advice for a particular setup, not a universal best setting. What works depends on your TV, receiver, cable path and speaker layout. Don't expect passthrough to improve latency or sound in every home.
On Xbox, one forum poster suggests uncompressed stereo for TV speakers, since most are built for stereo. Treat that as one user's view, not official guidance. BGR's Xbox audio guide also notes that the console won't activate Dolby formats unless it detects compatible speakers.
Headphones on PS5​
Sony's support page covers the steps:
  1. Go to Settings > Sound.
  2. Choose 3D Audio (Headphones).
  3. Turn on Enable 3D Audio for Headphones.
  4. Optionally run Create Personalised 3D Audio Profile. You answer questions about sound position and direction to build a profile for your hearing.
Sony says the profile applies only while "Apply Personalised 3D Audio Profile" is enabled. If you turn it off, a preset profile is used instead.
PS5 also supports 3D audio on built-in TV speakers. Under Settings > Sound > 3D Audio (TV) it uses the controller's microphone to measure your room. Sony says to re-measure if you move the TV, your seat or the room layout.
Headphones on Xbox​
BGR points Xbox players to Volume & audio output and then Headset format, with Windows Sonic, Dolby Atmos and DTS:X as options. BGR's separate Xbox audio guide puts the route at Settings, then General, then Volume & audio output. Exact labels vary slightly between sources, so go by what your console shows.
Some context on those formats:
  • TechRadar reports that Windows Sonic is the default headphones setting.
  • BGR says wired headsets that aren't built for Xbox are limited to uncompressed stereo and Windows Sonic unless you buy a Dolby Atmos for Headphones license or a DTS Headphone:X subscription.
  • Spatial formats only work in games that support Dolby Atmos or DTS sound. I haven't seen confirmation of which formats GTA VI supports on Xbox, so check the game's audio menu after launch.
Takeaway: pick one spatial format for your headset and stick with it. Match the console output to your hardware, and don't assume the fanciest option sounds best.
3. HDR and resolution​
BGR says to output at the highest resolution both console and display support, with 4K the obvious target on both current consoles. On PS5 the menu is Video Output. On Xbox Series X|S it's TV & display options under Settings.
I'd soften the idea that 4K is always best. A mode that works reliably on your display and cable is better than a flickering 4K one. Sony's support page says PS5 detects your TV's capabilities and automatically selects the best available resolution. Leaving Resolution on Automatic is a sensible default.
Turning on HDR on PS5​
Sony's steps:
  1. Go to Settings > Screen and Video > Video Output > HDR.
  2. Choose On When Supported to leave non-HDR content in standard dynamic range.
  3. Choose Always On only if you want non-HDR games and apps converted to HDR output.
  4. Run Adjust HDR from the same menu to calibrate brightness.
Sony adds that all PS5 consoles have 4K and HDR capability, but the image quality you get depends on your home entertainment setup.
HGiG​
BGR recommends turning on HGiG (HDR Gaming Interest Group) if your TV has it. The goal is to stop the TV from applying extra dynamic tone mapping after you've calibrated with the console. Whether it's available, and what it does, varies by TV maker and model.
BGR says HDR avoids washed-out colors in the game's neon-lit scenes. I'd be more careful. HDR only helps if it's calibrated correctly and your equipment supports it. A badly set up HDR chain can look worse than good SDR.
Troubleshooting common problems​
Sony's PS5 pages list fixes for common display problems:
  • Picture cut off or black borders: go to Settings > Screen and Video > Screen > Adjust Display Area.
  • Flickering at 4K: try a lower Video Transfer Rate setting. Sony says -1 or -2 limits some output modes, including 4K 120 Hz.
  • Blank screen or 1080p at 4K 120 Hz: check the TV's firmware and the HDMI 2.1 port. Use the included cable or a certified Ultra High-Speed cable. Connect straight to the TV, because receivers in between can affect the signal.
Since GTA VI targets 30 fps, you probably won't need 4K 120 Hz anyway.
A quick pre-launch checklist​
  • Turn on Game Mode or ALLM, and check that motion smoothing is off.
  • Leave VRR on as a safety net, but expect it not to engage at 30 fps on many TVs.
  • Set the audio format to match your gear: headphones, TV speakers, or soundbar over eARC.
  • Set resolution to Automatic or the highest mode that works reliably.
  • Enable HDR, run the console's HDR calibration, and turn on HGiG if your TV has it.
  • Leave color temperature and sharpness until you've played for a while. BGR notes that preferences vary by game.
This is a checklist, not a requirement, and Rockstar hasn't endorsed any of it. Menu names differ across TV brands and console generations. If a label doesn't match, check your TV's manual or the console's current menus.
Bottom line​
None of these settings will lift GTA VI above its 30 fps target. They remove the common causes of lag, odd motion, mismatched audio and dull HDR. For Xbox One owners on cloud streaming, the TV tweaks help only with how the stream is displayed. The rendering stays at Series S settings.
  1. 3 TV Settings You Should Change Before Playing GTA 6 bgr.com 2026-11-18T19:42:21+00:00
  2. Xbox Series X Dolby Vision and Atmos: what’s supported, and what isn’t? techradar.com
  3. How to change PS5 console resolution playstation.com
