A blue M.2 solid-state drive sits on a motherboard with glowing blue circuitry.
The Biwin M560 2TB is a PCIe 5.0 SSD that skips onboard DRAM and aims to be fast without running hot. It is also one of the first retail drives to use Silicon Motion's SM2504XT controller. Tom's Hardware reviewed it on November 1, and its verdict is that the M560 is one of the best all-around PCIe 5.0 SSDs it has tested, with class-leading responsiveness and excellent efficiency. Several other outlets have tested it since the summer, so there are independent results to compare. The same caution applies to all of them: a "drive to beat" headline is an opinion, not a category-wide verdict.
A blue M.2 solid-state drive sits on a motherboard with glowing blue circuitry. What the M560 is​
The M560 is a single-sided M.2 2280 drive. It uses PCIe 5.0 x4 and NVMe 2.0, with Kioxia 218-layer BiCS8 TLC NAND. It comes in two capacities, with a five-year warranty on both:
Spec1TB2TB
Sequential read11,000 MB/s11,000 MB/s
Sequential write9,700 MB/s10,000 MB/s
Random read / write1.4M / 1.6M IOPS1.7M / 1.7M IOPS
Endurance750 TBW1,500 TBW
Price listed by Tom's Hardware$189.99$364.99
Those prices are a snapshot from the review's publication day. Street prices move, so check before buying. The review also lists no security feature in the spec table.
DRAM-less, and why that matters​
The SM2504XT is a four-channel controller with no DRAM of its own. It can borrow a small portion of system memory for management data through Host Memory Buffer, which cuts cost, chip area and power use. ComputerBase describes the controller as built on a 6 nm process with three R8 cores. It has four memory channels, not the eight of the larger SM2508. In many respects it resembles Phison's E31T, the controller it competes with.
Tom's Hardware argues that 2TB is the right capacity for this controller. It says the ideal flash for it is four dies per channel, or 16 in total. That is the reviewer's reasoning, not a spec from the manufacturer. The practical result is that there is no 4TB version, which Tom's Hardware lists as a drawback. It also lists slower writes once the cache fills.
Performance results​
Independent testing mostly agrees on the sequential figures:
  • TweakTown measured about 11,372 MB/s read and 10,337 MB/s write in CrystalDiskMark. It also recorded a 4K Q1T1 random read of 127 MB/s. It called the M560 its favorite retail-ready consumer SSD, but it scored value "N/A" because no firm price was available.
  • ComputerBase tested a 2TB sample on firmware BS3563VN on an AM5 platform running Windows 11. The M560 scored 4,976 in PCMark 10 Quick System Drive. That is close to several higher-end PCIe 5.0 drives and ahead of the Phison E31T drives in the chart. In 3DMark Storage it scored 4,083, which ComputerBase says is about 20% ahead of the Corsair MP700 Elite.
  • Copy tests: ComputerBase found the M560 behind the E31T drives in a copy test on a freshly formatted drive. At high fill levels it moved ahead of the E31T models, which slowed sharply. ComputerBase also says DRAM-equipped high-end drives are clearly ahead in that scenario.
Results also vary by platform. TweakTown's 3DMark SSD Gaming score was 6,333 on its Intel system and 5,703 on its AMD system. Don't expect your own numbers to match any single chart.
Power and heat​
Biwin rates average power at under 5.2 W. Tom's Hardware notes that the label rating of 3.3 V / 2.0 A and the S.M.A.R.T. maximum of 8 W look alarming. Its own measurements found the drive comfortable at around 4 W, with a maximum well below 6.5 W. It concludes the drive should suit laptops and run cool even in PCIe 4.0 machines.
ComputerBase reports peak power of up to 5.5 W, slightly above its expectation but below the 5.7 W it measured for the E31T drives. It also saw slight throttling during extreme full-drive writes on a bare drive, with temperature peaks in the high 80s °C. It recommends a heatsink in that case. By contrast, TweakTown saw 42 °C after repeated sequential runs with only a motherboard heatsink and no airflow. NikKTech saw the controller stay under 63 °C at load, also with a motherboard heatsink. Low power helps, but sustained heavy writes with no cooling are a different matter.
Software and compatibility​
Biwin's download page for the drive offers three downloads:
  • A Windows data recovery tool.
  • A macOS data recovery tool.
  • Biwin Intelligence, an SSD toolbox for health checks, firmware updates and similar tasks. It is Windows-only.
ComputerBase notes that the drive ships with a small screwdriver for the M.2 screw. It also says Biwin later clarified that the choice of two label stickers applies only in China. The rest-of-world version comes with a blue thermal pad already fitted.
In a PCIe 4.0 slot the drive is limited by the slot's bandwidth, so you won't see the full PCIe 5.0 speeds. Tom's Hardware's single-sided design point still helps with fit and cooling in tight systems. TweakTown also measured 6,487 MB/s reads in a PlayStation 5 M.2 expansion slot. That is above Sony's 5,500 MB/s minimum.
Who should consider it​
It looks like a good fit if you:
  • Want PCIe 5.0 responsiveness without a high-end power draw.
  • Are upgrading a laptop or small-form-factor PC.
  • Care about gaming and application load times more than sustained heavy writing.
You may want to look elsewhere if you:
  • Need 4TB or more from one drive.
  • Do heavy sustained writing, where the cache falls away and DRAM-equipped drives pull ahead.
  • Want hardware encryption. The review lists none.
Bottom line​
The M560 shows that a four-channel, DRAM-less PCIe 5.0 drive can match many pricier drives in everyday tests. Its power draw is low, and the main trade-offs are the 2TB ceiling, slower writes once the cache fills, and the missing DRAM. Treat the lead over Phison E31T rivals as supported by several tests, but not as universal. Check the current price against the Crucial P510 and the DRAM-equipped drives before buying.
  1. Biwin M560 2TB SSD Review: The DRAM-less drive to beat Tom's Hardware 2026-11-01T15:00:00+00:00
  2. Biwin M560 2TB SSD Review - Best Overall Retail-Ready DRAMless SSD tweaktown.com
  3. Biwin M560 SSD 2 TB im Test: Empfehlenswert! - ComputerBase computerbase.de
