What was announced
The M5 MAX is built around AMD's Ryzen AI Max+ PRO 495. BOSGAME lists the chip as 16 cores and 32 threads, boosting up to 5.2GHz, with Radeon 8065S integrated graphics. The configuration on sale pairs that with 192GB of onboard LPDDR5 and a 2TB PCIe 4.0 NVMe SSD, plus a second M.2 slot for more storage.
Here is the rest of the hardware as BOSGAME describes it:
- Networking: Dual RTL8127 10GbE RJ45 ports, plus Wi-Fi 7 and Bluetooth 5.4 on an M.2 E-key 2230 module.
- Expansion: An OCuLink PCIe 4.0 x4 port for an external GPU or other PCIe devices.
- Video and I/O: HDMI 2.1, DisplayPort 2.1, two USB4 ports rated for 8K at 60Hz, and an SD 4.0 card reader.
- Other ports and cooling: Technetbook's report also lists three USB-A 10Gbps ports, one USB-A 480Mbps port, two 3.5mm audio jacks and a three-fan cooling system. I'd treat that inventory as BOSGAME-sourced and untested.
- Power: The listing advertises a performance-mode switch for 125W, 85W and 55W profiles, with a 120W adapter included. These are BOSGAME system settings. They are not AMD's processor TDP figures.
- Warranty: One year on the whole unit.
The timing change
The date is a small surprise. An earlier BOSGAME post said the first version would launch in mid-November 2026 with 128GB and 2TB, while a 192GB version was planned for early 2027. The company's own pages have since contradicted each other. A later post says the 192GB and 2TB version is expected in November 2026. The 192GB model is clearly on sale for pre-order now, but no firm delivery date has been published.
Shipping and delivery
Notebookcheck reports that BOSGAME is taking first-batch orders but has not given a firm shipping date. Local shipping covers the US, EU and UK, and other countries currently ship from China. That makes this a bet on a presale, not a purchase of a box you can unwrap this week.
How the price compares
Notebookcheck put the M5 MAX next to rival systems with the same chip family. Its snapshot:
| System | Listed price |
| BOSGAME M5 MAX (presale) | $6,199 |
| Acemagic F9A | $6,699 |
| GMKtec EVO-X5 Pro | $6,799 |
| Minisforum MS-S1 MAX-P495 | $7,399 |
| Framework desktop (DIY, no storage) | from $6,799 |
| Framework desktop (preassembled) | from $7,449 |
Notebookcheck says the gap runs from roughly $500 to $1,250, though configurations, connectivity and availability differ. So treat this as a price snapshot and not a verdict on value. An introductory price may also rise once the first batch sells out.
Vendor claims versus evidence
BOSGAME's headline claim is up to 131 TOPS of combined CPU, NPU and GPU compute, and the ability to run 320B LLMs locally. I'd be careful with that one. Guru3D notes that the company has not published performance results for AI software or other applications. The listing gives no model, quantization, context length or token speed. Notebookcheck's more modest estimate is that the NPU delivers up to 55 TOPS and that, with 160GB allocated to the GPU, you can run roughly 100-billion-parameter models locally. That's a reviewer's estimate and not a benchmark. The two numbers differ by a wide margin, which is a good reason to wait for independent testing.
The memory naming is also muddled. BOSGAME's titles say LPDDR5X, but the spec lines say LPDDR5. Don't assume a particular memory speed until someone verifies it on a real unit.
What matters for Windows and IT buyers
- The memory is fixed. Guru3D advises buyers to confirm the configuration meets their needs, because the 192GB is onboard. You can add storage through the second M.2 slot, but you can't add RAM.
- OS support is advertised, not validated. BOSGAME lists Windows 11 and Ubuntu support and promotes the machine for LLM work, CI, Proxmox and KVM virtualization. That's a compatibility claim. It says nothing about driver quality or what ships on the machine.
- Networking is a real strength. Two 10GbE ports suit NAS-heavy, cluster or build-server setups. You'd still need 10GbE switching to use them.
- OCuLink offers an upgrade path. An external GPU could add graphics power for rendering or inference later. Nobody has tested that on this system yet.
- Support is thin. A one-year warranty and the usual presale caveats apply at this price.
Bottom line
The M5 MAX makes an unusually large memory pool available in a mini-PC format at a competitive introductory price. What it lacks is evidence. There are no independent benchmarks, no shipping date and no confirmed memory speed. Developers, virtualization admins and local-LLM tinkerers who need that much shared memory have a new option to watch. Everyone else should wait for reviews and real shipping dates before putting $6,199 down.
- BOSGAME M5 MAX Mini AI Workstation Launches with 192GB RAM and AMD Ryzen AI Max+ PRO 495 - Technetbook Technetbook · 2026-11-03T21:14:00+00:00
- BOSGAME M5 MAX Mini PC,AMD Ryzen AI Max+ PRO 495,192G 2TB,Linux friendly AI workstation for LLM,CI and virtualization bosgame.com
- BOSGAME M5 MAX Packs Ryzen AI Max+ PRO 495 and 192GB RAM guru3d.com
