Laptop and Wi‑Fi printer on a desk show dual-band settings and WLAN error/repair steps for 2.4GHz.
Brother HL-L2350DW owners in 2026 are still most likely to fix Wi-Fi and “offline” failures by checking the printer’s status, reconnecting it to a named 2.4 GHz network, clearing stalled print queues, and reinstalling Brother’s current software before resorting to a network reset. The useful story here is not that one small laser printer is fragile. It is that home and small-office networks have become more complicated than the devices many people still depend on. The HL-L2350DW is a good printer living in a router market that has moved on without asking whether every endpoint came along.
The Printer Is Usually Not the Villain​
The Brother HL-L2350DW has the kind of reputation vendors envy: cheap to run, physically compact, fast enough for home offices, and boring in the best possible way. It is a monochrome laser printer, not a cloud appliance pretending to be a lifestyle platform. That simplicity is exactly why users are surprised when it suddenly drops off Wi-Fi or shows as offline after working fine for months.
But “offline” is a misleading word. In many cases, the printer is not dead, not broken, and not even disconnected in the way the user imagines. It may be asleep, blocked by an error message, parked behind a stale Windows queue, or attached to a network identity that changed under it.
That distinction matters because printer troubleshooting has trained people to take drastic action too early. They delete drivers, reset routers, and factory-wipe devices before checking whether the LCD is showing a jam, whether Windows has toggled “Use Printer Offline,” or whether the router quietly merged the 2.4 GHz and 5 GHz bands under one fashionable mesh-network name.
The first fix, then, is almost insultingly analog: look at the printer. If the HL-L2350DW is asleep, wake it. If it has an error on the display, clear it. If the toner, paper path, or job state is blocked, Wi-Fi troubleshooting will not help because the machine is not ready to accept work.
Modern Routers Broke the Old Assumption​
The most consequential fact about the HL-L2350DW is also the one many owners discover only after buying a new router: it is a 2.4 GHz Wi-Fi printer. Its wireless interface is built around 802.11 b/g/n behavior, plus Wi-Fi Direct, not 5 GHz networking. That was ordinary for inexpensive printers when the model arrived, and it remains sufficient for sending black-and-white documents across a room.
The problem is that routers stopped presenting networks in the simple way printers expect. Dual-band and mesh systems increasingly prefer one shared SSID, band steering, automatic channel selection, and roaming logic designed for phones and laptops. A printer with a small LCD and conservative wireless stack does not negotiate that world with the same grace as a MacBook or Android handset.
That is why the advice to separate the bands is not superstition. Giving the 2.4 GHz and 5 GHz radios different names removes ambiguity. The printer sees the network it can actually use, joins it directly, and is less likely to be pushed around by router-side “smart” features that are smart mostly for devices that support them well.
For IT pros, this is familiar. The consumer router market sells invisible complexity as convenience, and then legacy endpoints pay the price. The HL-L2350DW is not alone here; smart plugs, older cameras, scanners, label printers, and industrial handhelds often share the same 2.4 GHz dependency. The printer is just the device that makes the failure visible because somebody is waiting for paper.
“Offline” Is a State, Not a Diagnosis​
Windows has long treated printers as a stack of abstractions: device, driver, port, queue, default target, spooler, and status flag. When that stack gets out of sync, the user sees one word: offline. It is efficient as a warning and terrible as a diagnosis.
The “Use Printer Offline” setting is the classic example. It can be enabled intentionally, toggled by accident, or left behind after a temporary communication failure. Once checked, it continues to hold jobs even if the printer itself is now awake, connected, and reachable.
“Pause Printing” is another trap. A paused queue can make the printer appear unavailable while nothing is wrong with the radio link. A stuck document can do much the same thing, especially if a malformed job is blocking everything behind it.
The practical fix is to treat the print queue as part of the device. On Windows 11, that means going through Settings, Bluetooth & devices, Printers & scanners, and opening the queue for the Brother printer. On Windows 10 and earlier, the older Devices and Printers route still exposes the familiar “See what’s printing” menu, where “Use Printer Offline,” “Pause Printing,” and queued jobs can be cleared.
The default-printer setting deserves equal suspicion. Windows can create duplicate printer entries after driver reinstalls, USB port changes, or repeated setup attempts. Users then print to the ghost while the actual Brother sits idle, apparently offline, apparently useless, and completely innocent.
The Five-Minute Wait Is Not Folklore​
Power-cycling is the least glamorous fix in computing, but for wireless printers it often works because it forces three state machines to renegotiate: router, computer, and printer. The order matters more than people think. Restart the router first, let it fully boot, then restart the computer, and bring the printer back last.
That sequence gives the HL-L2350DW a stable access point to join and gives the computer a fresh network environment in which to discover it. Turning everything off and back on randomly can still work, but it also creates timing races. The printer may come up before the router is ready, the PC may cache an old address, or the user may test too quickly and conclude nothing changed.
The five-minute pause after restarting the printer is another small instruction with a large failure rate. Printers are not phones. They do not always rejoin, advertise, and become visible at human impatience speed.
Moving the printer closer to the router during this test is not an admission of defeat. It is a diagnostic control. If the machine reconnects at close range and fails in its usual location, the problem is signal quality, interference, placement, or router behavior. If it fails even next to the router, the likely causes narrow to credentials, band selection, configuration, or firmware.
Brother’s Best Diagnostic Tool Is Paper​
There is a satisfying irony in the HL-L2350DW’s most useful wireless diagnostic: it prints a WLAN report. In a world of apps, cloud dashboards, and animated setup screens, the printer can still tell you what happened by putting the network result on a sheet of paper.
That report matters because it changes the exercise from ritual to evidence. Instead of repeatedly entering the Wi-Fi password and hoping, the user can see whether the connection succeeded and, if it failed, which error code Brother assigns to the failure. That code then points toward the actual problem.
The control-panel path is simple enough: Print Reports, WLAN Report, then Go. It is not a beautiful interface, but it is local, durable, and independent of whether Windows or macOS currently believes the printer exists.
This is also where the HL-L2350DW shows its age in a useful way. Many modern devices hide diagnostics behind apps or online accounts. Brother’s older small-office design assumes the device should be able to explain itself without a subscription or companion cloud service. That does not make troubleshooting pleasant, but it keeps it possible.
Windows Needs the Right Address, Not Just the Right Printer Name​
A wireless printer can be connected to the router and still be unreachable from a PC. That sounds contradictory until you remember that discovery, addressing, and printing are separate layers. If Windows has the wrong IP address, the wrong port, a stale WSD entry, or a mismatched subnet expectation, the printer’s Wi-Fi icon is not enough.
Brother’s Network Connection Repair Tool exists for exactly this class of failure on Windows. Its purpose is not magical repair; it corrects the machine’s network settings so the computer and printer agree on how to reach each other. In the real world, that often means resolving a bad IP address or subnet mask relationship after a router change, DHCP lease shift, or reinstall.
This is where many home users accidentally become network administrators. They did not ask to learn about addressing; they just wanted to print a shipping label. But printers sit at the intersection of operating system assumptions and router decisions, and that intersection is where “offline” lives.
For small offices, the lesson is sharper. If a printer is shared by multiple workstations, a casual router replacement can create a morning of lost productivity. Reserving an address for the printer in the router, keeping SSIDs stable, and documenting the setup are not enterprise overkill. They are the cheapest insurance against the next “nothing prints” incident.
macOS Has Fewer Toggles but the Same Failure Modes​
Mac users avoid some of Windows’ more infamous printer-status quirks, but they do not escape the network problem. The HL-L2350DW still needs the same 2.4 GHz network, the same usable signal, and the same clean driver relationship. If the printer dropped off the router, macOS elegance will not save it.
The Mac path is more about selection and rebuilding. Open Printers & Scanners, confirm the Brother is the intended printer, clear stuck jobs, and remove and re-add the printer if the system appears to have stale information. That last step can be surprisingly effective because it forces macOS to rediscover the device and rebuild the print path.
AirPrint support helps, especially for Apple-heavy households, but it is not a substitute for network health. AirPrint depends on the printer being visible and reachable on the local network. If the router’s band steering or multicast behavior gets in the way, the experience can still feel random.
Brother iPrint&Scan gives mobile users another route for printing and maintenance, including firmware workflows in some cases. But the app should be understood as a tool, not a cure-all. If the printer cannot stay attached to the 2.4 GHz network, every client—Windows, macOS, iOS, Android—will eventually feel the same failure.
Firmware and Drivers Are the Boring Fix That Still Matters​
Printer firmware does not inspire excitement, and driver packages are nobody’s idea of a good afternoon. Still, stale software remains one of the more plausible reasons a setup that worked last year misbehaves this year. Operating systems change, routers update, security defaults shift, and old assumptions become brittle.
The sensible move is to install Brother’s current full driver and software package for the operating system in use. On Windows, that can clear corrupted installations, duplicate entries, and broken port mappings. On macOS, it can replace a generic or stale setup with one that better matches the device.
Router firmware belongs in the same conversation. A printer owner may blame Brother after a Wi-Fi failure that was actually introduced by a mesh update, a changed band-steering policy, or a security-mode default. Updating the router can fix bugs, but changing router firmware can also create new behavior. That is why the SSID and band setup should be checked after major router changes, not assumed.
The caution is not to treat updates as a substitute for diagnosis. If the printer is trying to join a 5 GHz-only SSID, no driver package will fix it. If Windows is paused, firmware will not unpause it. Software maintenance is necessary, but it works best after the basic state and network facts are known.
WPS Is Convenient, but Manual Setup Is the More Durable Skill​
The HL-L2350DW supports WPS one-push setup, and in many homes that is the fastest way to get the printer back on Wi-Fi. Select the WLAN WPS option on the printer, press the router’s WPS button when prompted, and wait for the printer to report that it connected. For users who do not want to enter a long WPA password on a small printer panel, WPS can be a mercy.
But WPS is not always available, not always enabled, and not always welcome in security-conscious environments. Some routers hide it, some mesh systems abstract it away, and some administrators disable it. That leaves the Wireless Setup Wizard as the more universal method.
Manual setup is also better at exposing the real problem. If the SSID does not appear, the printer may not see the 2.4 GHz network. If the hidden network must be entered manually, the user learns that stealth SSIDs add friction without much practical security benefit. If the password fails, the issue is credentials, not Windows.
The strongest setup is the least ambiguous one: a visible, named 2.4 GHz SSID; a known password; a printer placed within reliable range; and client devices connected to the same local network. That sounds old-fashioned because it is. It also works.
Resetting the Network Is a Last Resort, Not a First Move​
Brother’s network reset is effective because it wipes the printer’s saved network configuration and returns wired and wireless network settings to factory defaults. That includes the saved Wi-Fi password and IP address. Afterward, the printer must be set up again.
That is exactly why it should come late in the sequence. Resetting too early destroys useful evidence. If the problem was a paused Windows queue, the reset adds work without solving the root cause. If the router band is wrong, the printer will simply fail to reconnect after the wipe.
There are cases where reset is the right answer. A printer that has accumulated old network settings, moved between homes or offices, or been repeatedly configured against changing routers may benefit from a clean slate. Once simpler fixes fail, wiping the network settings and rebuilding the setup can be faster than guessing what state remains inside the device.
Even then, the reset should be paired with a plan. Separate the 2.4 GHz SSID first. Confirm the password. Download the current driver. Keep the printer close to the router during setup. Then reset, reconnect, and reinstall with the fewest variables possible.
The Missing Ethernet Port Changes the Troubleshooting Playbook​
One detail in the Technobezz material deserves emphasis because it prevents a lot of bad advice: the HL-L2350DW does not have an Ethernet port. It is USB or wireless, with Wi-Fi Direct available, but there is no wired network jack to inspect. Advice written for nearby Brother models can easily mislead owners here.
That limitation is not automatically a flaw. Ethernet would make the printer more reliable in a fixed office, but this model was designed as a compact, inexpensive home and small-office laser. Brother made the trade-off many buyers accepted: low cost and wireless convenience over a physical LAN port.
The absence of Ethernet does, however, make USB a more important fallback. If a mesh router refuses to behave, or if a workstation absolutely must print reliably, direct USB removes the wireless network from the equation. It is not elegant, but neither is losing print capability every time a router decides to “optimize” the network.
For administrators, the missing Ethernet port should inform purchasing more than troubleshooting. If a printer is business-critical, shared by several users, or expected to live for years across router upgrades, buying a model with Ethernet may be the wiser choice. The HL-L2350DW can be a workhorse, but it is not a network-infrastructure appliance.
The Real Pattern Is Consumer IT Becoming Enterprise IT​
The HL-L2350DW story is small, but it reflects a larger shift. Home users now run networks that would have sounded exotic in a small business two decades ago: dual-band radios, mesh nodes, guest networks, WPA transitions, app-managed routers, automatic firmware updates, and client isolation features. They also expect old endpoints to survive every change without attention.
That expectation is understandable. A printer should not require a networking lesson. But wireless printing is not magic; it is a chain of dependencies that includes radio compatibility, authentication, addressing, discovery, drivers, queues, and user permissions.
Vendors do not always help. Router makers optimize for seamless onboarding of modern devices and rarely explain what “smart connect” means for older 2.4 GHz clients. Printer makers publish correct guidance, but often in fragmented support articles that read like a maze rather than a diagnosis. Operating systems collapse multiple failure modes into one emotionally loaded label: offline.
Technobezz’s paired guides are useful because they restore order to that mess. Start with the device. Check the queue. Respect the 2.4 GHz limitation. Print the WLAN report. Repair the Windows address path. Reinstall software only when appropriate. Reset only when the evidence points there.
The Fixes That Matter Most for This Brother Workhorse​
The recurring lesson is that the HL-L2350DW is rarely mysterious once the owner stops treating “offline” as a single problem. It is a symptom produced by several layers, and the quickest repair is the one that tests those layers in the right order.
  • Make sure the printer is powered on, awake, and free of LCD errors before changing router or computer settings.
  • Put the printer on a clearly named 2.4 GHz Wi-Fi network, especially after installing a dual-band or mesh router.
  • Clear Windows’ “Use Printer Offline” and “Pause Printing” states, remove stuck jobs, and confirm the real Brother entry is the default printer.
  • Print the WLAN report when Wi-Fi setup fails, because the error code is better evidence than repeated guessing.
  • Use Brother’s current driver package, firmware updates, and Windows repair tool before wiping the printer’s network configuration.
  • Treat Network Reset as the clean-slate option after simpler checks fail, because it erases saved Wi-Fi settings and requires setup again.
The Brother HL-L2350DW endures because it does one job well, but its Wi-Fi troubles show how much the environment around simple hardware has changed. The next generation of home-office devices will need better diagnostics, clearer router compatibility, and less dependence on users knowing the difference between a queue state and a radio band. Until then, the practical answer is unromantic but effective: simplify the network, clear the software state, and make the printer prove what it knows before assuming it is broken.
  1. Brother HL-L2350DW Not Connecting to WiFi? 10 Fixes (2026) Technobezz 2026-06-23T02:20:41.591251
  2. Brother HL-L2350DW Won't Work With Mesh WiFi? 11 Fixes (2026) Technobezz 2026-06-23T02:10:08.532208
Brother’s HL-L2350DW commonly stops working after a mesh Wi-Fi upgrade because the printer supports 2.4 GHz wireless networking but not 5 GHz, while many mesh systems combine both bands under one network name and steer devices automatically. The practical fix is not exotic: give the 2.4 GHz band its own SSID, connect the printer to that network, and then repair any stale printer queue or driver settings left behind on Windows or macOS. The frustration is that a printer which appears to have “Wi-Fi problems” is often behaving exactly as designed. Mesh networking has simply made that design harder for ordinary users to see.
Wi‑Fi printer connected to 2.4GHz IoT and 5GHz devices, with laptop showing print queue online. The Mesh Router Did Not Break the Printer — It Exposed Its Age​
The Brother HL-L2350DW remains a perfectly useful monochrome laser printer in 2026 because it does the core job well: it prints quickly, cheaply, and without the inkjet drama of dried cartridges and app-dependent maintenance rituals. But its wireless hardware belongs to a more modest era of home networking. The printer supports 802.11 b/g/n wireless and Wi-Fi Direct, but its ordinary infrastructure Wi-Fi connection is a 2.4 GHz affair.
That detail used to be almost invisible. Older routers commonly exposed separate 2.4 GHz and 5 GHz network names, or users simply connected everything to the slower, longer-range network by default. A printer could sit in a corner for years, wake up when needed, grab the same network, and do its job.
Mesh systems changed the experience. They are designed to hide complexity, not reveal it. The whole sales pitch is that the user should see one Wi-Fi name, roam through the house, and let the system decide which radio, band, and node is best.
That is usually good for phones, tablets, laptops, and streaming boxes. It is less forgiving for older printers, smart plugs, cameras, thermostats, and other devices that only speak 2.4 GHz. When the network abstraction leaks, the user sees a familiar failure: the printer is online one moment, missing the next, and “offline” in Windows even though nothing obvious has changed.
One Network Name Is Convenient Until a Single-Band Device Joins​
The central problem is the single SSID. Many mesh routers broadcast one friendly network name across 2.4 GHz, 5 GHz, and sometimes 6 GHz bands. The router then uses band steering to nudge clients toward the band it thinks is most appropriate.
That is sensible for a modern laptop. A laptop close to the router should often prefer 5 GHz or 6 GHz because those bands can deliver higher throughput and avoid some of the congestion that plagues 2.4 GHz. Move farther away, and the system may push the client to another node or band.
The Brother HL-L2350DW is not that kind of client. It cannot join a 5 GHz network. It needs a 2.4 GHz SSID, a compatible security mode, and enough signal stability to stay attached while sleeping and waking.
Brother’s own guidance for mesh and dual-band setups points directly at the issue: separate the mesh network name into different bands and connect the Brother machine to the 2.4 GHz network. That advice may feel like a step backward from the mesh ideal, but it is the cleanest fix because it removes ambiguity. The printer no longer has to live behind a network name that represents radios it cannot use.
The Official Fix Is Boring, Which Is Why It Works​
The most reliable repair starts in the router or mesh app, not on the printer. Create a dedicated 2.4 GHz network name — for example, a main network for modern devices and a clearly marked 2.4 GHz network for printers and other legacy hardware. Then connect the HL-L2350DW only to that 2.4 GHz SSID.
The name matters. If both 2.4 GHz and 5 GHz bands share the same SSID, the printer may appear to connect during setup and then become unreliable later. If the 5 GHz band has a distinct name and the 2.4 GHz band has a distinct name, there is no mystery about where the printer belongs.
This is also where many users get tripped up by mesh terminology. Some systems call this an “IoT network,” “legacy network,” “2.4 GHz only network,” or “compatibility mode.” Others make it annoyingly hard to split bands at all. In that case, look for options that temporarily disable 5 GHz during setup, create a separate guest or IoT SSID limited to 2.4 GHz, or turn off band steering for specific devices.
The goal is not to make the whole house slower. The goal is to give the printer a stable lane. Your phone and laptop can keep using the fast band; the printer just needs a radio it understands.
Restarting Still Matters, but Only After the Network Makes Sense​
Power cycling is over-prescribed in tech support because it sometimes works for reasons nobody wants to document. Here, it has a more concrete role. Once the mesh network is configured properly, restarting devices in the right order helps the printer rejoin a clean environment.
Restart the router or mesh nodes first. Wait until the Wi-Fi network is fully available again. Then restart the computer, followed by the printer.
That sequence matters because printers often hold on to stale network assumptions longer than users expect. A mesh upgrade may change DHCP leases, IP ranges, node associations, or the way devices discover one another. If the computer comes back before the network is stable, or the printer wakes before the 2.4 GHz SSID is ready, Windows or macOS can cache the wrong state and call the device offline.
Placement is the other unglamorous fix. The HL-L2350DW does not need gaming-router bandwidth, but it does need a stable 2.4 GHz signal. Keep it away from thick walls, metal shelving, microwaves, and the dead zone between mesh nodes where a client may be passed back and forth.
The Network Configuration Report Is the Printer’s Confession​
Before tearing out drivers or resetting everything, print the Network Configuration Report. It is the fastest way to tell whether the printer is actually on the network you think it is on.
From the printer’s control panel, use the arrow keys to choose Print Reports, select Network Config, press OK, and then press Go. The report should show the printer’s IP address, subnet mask, wireless node name, and MAC address.
The IP address is the first thing to inspect. If your computer is on a 192.168.1.x network and the printer is on 192.168.50.x, they may not see each other depending on the router configuration. If the printer has no useful IP address, the Wi-Fi connection is not really established.
The node name can also help confirm that you are looking at the wireless interface. Brother wireless nodes often appear with a BRW-style identifier. If that report points to the wrong SSID, an unexpected address, or no valid network at all, the problem is not Windows being fussy. The printer is not properly attached.
Rejoin Wi-Fi from the Printer, Not from Memory​
Once the 2.4 GHz SSID exists, use the printer’s built-in Setup Wizard to connect from scratch. On the HL-L2350DW, open Network, choose WLAN or Wi-Fi, select Setup Wizard, enable WLAN when prompted, and pick the 2.4 GHz network name from the SSID list. Enter the network key carefully.
This step is tedious because the printer’s small control panel is not built for pleasant password entry. Still, doing it directly avoids a common trap: assuming the printer will automatically reinterpret the old network after the mesh system changes. It may not.
Use the exact SSID and password configured in the mesh app. Avoid clever characters in a temporary test network name if the printer refuses to join; once the connection works, you can decide whether to keep the simpler SSID permanently.
If the printer connects successfully, print another Network Configuration Report. A valid IP address on the same network as the computer is the dividing line between Wi-Fi troubleshooting and operating-system troubleshooting.
Windows May Keep Arguing After Wi-Fi Is Fixed​
Windows can make a solved network problem look unsolved. If the printer went missing during the router upgrade, the print queue may still contain stuck jobs, the printer may be marked offline, or the driver may point to an old IP address.
On Windows 11, open Settings, go to Bluetooth & devices, choose Printers & scanners, select the Brother printer, and open the print queue. Cancel stuck jobs and make sure the device is not paused. On Windows 10, the older Devices and Printers path may still expose the familiar “See what’s printing” queue, where “Use Printer Offline” and “Pause Printing” should be unchecked.
If the printer is reachable by IP address but Windows will not print, the driver port is the next suspect. Mesh routers often assign a new IP address after a network rebuild. Windows may still be trying to send jobs to the address the printer used last week.
Brother’s Network Connection Repair Tool exists for exactly this kind of failure. It locates the printer and updates the IP address inside the printer driver. That is not magic; it is housekeeping. But it is the right housekeeping for a printer that moved addresses while the operating system was not paying attention.
macOS Has a Different Failure Mode, but the Same Network Truth​
On a Mac, the failure is often less theatrical. The printer may simply disappear from Printers & Scanners, sit idle with old jobs, or fail to show up as an AirPrint destination after the network change.
The first check is the same: verify that the Mac and printer are on the same Wi-Fi network or at least the same routed local network. If the Mac is on a guest network and the printer is on the main network, discovery may fail even if both have internet access. Guest networks frequently isolate clients from one another by design.
Then remove and re-add the printer in macOS. This forces the Mac to rediscover the device rather than relying on a stale entry. If the printer appears through AirPrint, that may be enough. If Brother’s driver package is needed for fuller functionality, install the current package from Brother rather than reusing an old download from a previous router era.
As with Windows, do not skip the printer’s own report. macOS discovery can be elegant when it works and opaque when it fails. An IP address on the wrong subnet is still an IP address on the wrong subnet, no matter how polished the settings panel looks.
The Network Reset Is the Last Resort, Not the First Ritual​
A network reset on the HL-L2350DW returns the printer’s network settings to factory defaults. It clears saved wireless credentials, IP configuration, and related network state. That makes it useful, but it also means you should not do it casually before you have created a proper 2.4 GHz SSID.
The reset path is straightforward: open Network from the control panel, choose Network Reset, confirm Yes, and let the machine restart. After that, use the Setup Wizard to join the dedicated 2.4 GHz network again.
This is the point where many users finally succeed because the printer is no longer clinging to an old SSID, old password, or old DHCP lease. But the reset only helps if the network it rejoins is compatible. Resetting the printer and then sending it back into the same merged-band mesh configuration just recreates the conditions that caused the failure.
If a clean reset and fresh setup still cannot hold a connection, the likely causes narrow quickly: weak signal, router compatibility settings, security-mode mismatch, defective wireless hardware, or a mesh system that refuses to provide a usable 2.4 GHz-only path.
USB Is the Escape Hatch, but Not a Network Strategy​
The HL-L2350DW has Hi-Speed USB 2.0, and that can save the day if the printer sits next to a desktop. A direct USB cable bypasses mesh entirely. For one computer, it is the simplest possible answer.
But USB is not a real replacement for network printing in a household or small office. It ties the printer to one machine unless that computer is left on and configured to share the printer. That adds its own failure points, especially across Windows and macOS clients.
Ethernet would be the cleaner fallback, but this model does not provide wired Ethernet. That distinction matters because users often assume every “DW” Brother model includes a network jack. The HL-L2350DW does not; wireless and USB are the practical connection choices.
That makes the 2.4 GHz Wi-Fi setup more than a preference. For shared printing without a host computer, it is the path.
Mobile Printing Works Best When the Network Is Already Stable​
Mobile printing does not escape the same physics. Brother iPrint&Scan, AirPrint, Mopria, Cortado Workplace, and Wi-Fi Direct all give users ways to print from phones and tablets, but they are not substitutes for a stable LAN configuration.
If the phone is on the 5 GHz band and the printer is on 2.4 GHz, that can still be fine as long as both bands belong to the same local network and the router allows devices to talk across them. The printer does not need the phone to be on 2.4 GHz; it needs the printer itself to be on 2.4 GHz and reachable.
Wi-Fi Direct is different. It lets a device connect directly to the printer rather than going through the router. That can be useful for quick jobs or temporary setups, but it is less convenient as the default mode in a home or office where multiple devices need to print.
The app question is also worth getting right. For this model, Brother iPrint&Scan remains the relevant mobile path. Newer Brother app branding can confuse users, but app support depends on the model list, not the age of the phone.
Security Settings Can Quietly Sabotage the Fix​
A split 2.4 GHz SSID is the headline repair, but security settings can still trip up the printer. Older devices may not behave well with the newest router defaults, especially if a mesh system is configured for WPA3-only security or an aggressive compatibility profile.
The safer setting for this printer class is usually WPA2-Personal with AES. Mixed WPA2/WPA3 modes may work, but if setup fails repeatedly, temporarily testing WPA2-only on the 2.4 GHz SSID is reasonable. WEP should be avoided; it is obsolete and insecure.
Do not disable security just to make the printer happy, except for a brief diagnostic test in a controlled environment. A printer is not worth an open network. If the router’s “IoT network” feature isolates devices from the main LAN, also check whether that isolation prevents computers from reaching the printer.
Mesh vendors increasingly treat IoT devices as untrusted clients, which is not irrational. But printing requires local communication. A perfectly isolated printer is secure in the same way a locked filing cabinet at the bottom of a lake is secure.
The Real Lesson Is That Printers Are Infrastructure Now​
The HL-L2350DW mesh problem is easy to dismiss as a cheap-printer nuisance, but it points to a larger home-networking shift. Mesh routers have turned consumer Wi-Fi into managed infrastructure. They make good decisions automatically most of the time, but they also hide the knobs that legacy devices still need.
That creates a support gap. The router app tells the user everything is fine. The printer says it is offline. Windows shrugs. The actual issue lives between them: an SSID abstraction that is too clever for a single-band client.
For sysadmins and IT pros, none of this is surprising. Separate SSIDs, DHCP reservations, known-good security profiles, and static printer ports are old tools. What is new is how often home users now need enterprise-style network hygiene just to print a shipping label.
The best long-term setup is boring: a dedicated 2.4 GHz SSID for legacy and IoT devices, a sensible WPA2-compatible security profile, a DHCP reservation for the printer, and a freshly installed driver or repaired port on each computer. Once that is done, the printer can go back to being invisible in the good way.
The Fix Is a Network Design Decision, Not a Printer Superstition​
The reliable path through this problem is short, but the order matters. Do the network work first, then the printer setup, then the operating-system cleanup.
  • Create a separate 2.4 GHz SSID in the mesh router or enable a 2.4 GHz-only IoT network that still allows local printing.
  • Connect the Brother HL-L2350DW to that 2.4 GHz network using the printer’s control-panel Setup Wizard.
  • Print the Network Configuration Report and confirm the printer has a valid IP address on the same local network as the computer.
  • Clear stuck print jobs and make sure Windows or macOS has not paused the printer or marked it offline.
  • Use Brother’s Network Connection Repair Tool on Windows if the printer is online but the driver is still pointing at an old IP address.
  • Reset the printer’s network settings only after the 2.4 GHz network is ready, then reconnect it from scratch.
The Brother HL-L2350DW is not suddenly obsolete because a mesh router moved into the house, but it does need the network to stop pretending every device is equally modern. Give the printer a real 2.4 GHz home, clean up the stale driver state, and it should return to its proper role: a quiet little laser box that wakes up, prints the page, and disappears from your attention until the next job arrives.
