A media console holds a gaming console beneath a TV, with blue and orange airflow illustrated through the cabinet.
Putting a game console in a closed entertainment-center cabinet is a bad idea. A cabinet is for a cable box, not for a box that can draw a couple hundred watts. Engadget's Roger Fingas made that case on November 2, 2026. The advice covers Xbox consoles, so it matters to anyone who plays on a Series X or Series S. Here is what holds up, where the manufacturers disagree, and what to do about it.
A media console holds a gaming console beneath a TV, with blue and orange airflow illustrated through the cabinet. Why a cabinet is a problem​
Heat is the main concern. Engadget says a PlayStation 5 can draw up to 220W during a game, and that the Xbox Series X is roughly in the same range. It contrasts that with a high-end Blu-ray player, which tops out around 32W. A console has fans to push hot air out and vents to pull cool air in. In a sealed cabinet the exhaust has nowhere to go, and the intake may pull in the same warm air again.
Engadget describes the likely results:
  • The fans spin harder.
  • The system may reduce performance to limit heat.
  • Under extreme conditions, prolonged heat can cause visual glitches or a temporary shutdown.
Treat these as risks, not guarantees. None of the manufacturer guidance I reviewed quantifies how often cabinets cause failures or by how much they shorten a console's life. Engadget's claim about lifespan is plausible, but it is the author's argument, not a measured result.
Dust makes it worse. A cabinet can keep some dust out, but it also makes it harder for particles to escape. A thick layer of dust on or inside the vents reduces airflow in and out.
What the manufacturers say​
The three console makers don't say the same thing.
Microsoft (Xbox). Microsoft's Xbox product and regulatory guide warns against blocking the ventilation openings. It also warns against putting the console in a confined space such as a bookcase, rack or stereo cabinet. The exception is a space that is well ventilated. It also says to keep the console off soft surfaces like a bed or sofa, and away from radiators, heat registers, stoves and amplifiers. So Microsoft doesn't flatly ban cabinets, but it sets a condition most closed cabinets won't meet.
Sony (PS5). Sony's safety guide is stricter. It says not to use the console in a closed cabinet or any place where heat can build up. It warns this can cause overheating, and potentially fire, injury or malfunction. Sony's ventilation advice also calls for about 10 cm (4 inches) of space from a wall. It says not to cover the console with cloth and to keep dust from building up on the vents. These are PS5 rules, not Xbox rules.
Nintendo (Switch). Nintendo's support answer for Switch says to leave at least 10 cm around the air intake and vent. It says to clear dust from them with a vacuum cleaner or similar. It says warmth while charging or in use, including Sleep Mode, is not a defect. It recommends an ambient temperature of 5 to 35°C. If the console runs hot at other times, Nintendo says to check the room temperature and whether the vents are blocked. It also says to stop using the console and contact support if you're worried. That page covers the Switch models it names, not every Nintendo device. Engadget separately says Nintendo advises docking the Switch 2 in an open, ventilated area.
How much clearance does an Xbox need?​
Published numbers conflict, so I'd hold off on treating any one figure as official.
  • Engadget says Microsoft suggests 4 to 6 inches (up to about 15 cm) on all sides, and Sony about 4 inches.
  • Pure Xbox, reporting in 2020 on Microsoft's Xbox Series X|S FAQ, quoted different wording. For a standard, non-enclosed media stand, it said to leave at least 1.5 inches (approximately 4 cm) of clearance from the top of the console, vertical or horizontal.
  • Microsoft's regulatory guide, as far as I could verify, gives no inch figure at all. It only says "well ventilated."
The 1.5-inch figure applies to an open stand, not a cabinet. It is a minimum for the top of the console, not a recommendation for an enclosed space. Engadget's 4-to-6-inch figure is more conservative. I couldn't confirm it against a current Microsoft page. If you want a number, treat several inches of open space as a sensible margin, not a certified requirement. Check Xbox Support for your exact console.
What to do​
  1. Read your console's own guide. Rules differ by manufacturer and model.
  2. Keep the vents clear. Don't put controllers, game cases, books or fabric on top of the console. Don't push it into a tight slot.
  3. Keep it away from heat sources. Amplifiers and radiators are on Microsoft's list.
  4. Use the open-shelf option if you can. The Xbox Series consoles can stand vertically or lie horizontally, so try both to see which gives better airflow in your setup.
  5. If you must use a cabinet, make it well ventilated. Engadget suggests a small fan pointed at the console. Open-back or perforated cabinets are better than a closed door. That is general airflow reasoning, not a Microsoft-certified fix.
  6. Dust the outside periodically. Engadget suggests a microfiber cloth and canned air. If you use canned air, hold the can level and several inches from the hardware so you don't spray liquid onto circuitry. Don't open the console.
  7. If it runs unusually hot, check the room temperature and whether anything blocks the vents. If it still runs hot, contact the manufacturer.
PC handhelds and small PCs​
Engadget says the same principle applies to PC-based gaming systems such as the ASUS ROG Ally X and the Valve Steam Machine. Each system draws air in and out at different places, so check where yours does. For Windows users with an Xbox-branded handheld or a living-room PC, the rule is the same: a trapped space is never good.
Bottom line​
The article doesn't reveal a new defect. It's a reminder that console makers don't put this advice up front. Sony is the most categorical, saying not to use the PS5 in a closed cabinet. Microsoft allows a confined space only if it is well ventilated. Either way, a closed cabinet is the wrong place for a console that runs hot, however good it looks. Give the vents room.
  1. Think Twice Before Putting Your Gaming Console Inside A Cabinet - Engadget Engadget 2026-11-02T18:15:00+00:00
  2. (Switch) My console gets hot. Is it broken? | Q&A | Support | Nintendo nintendo.com
  3. How Much Ventilation Does The Xbox Series X Need? Here's What Microsoft Says purexbox.com
