The sensible takeaway is to evaluate old fans—not automatically replace them, and not automatically trust them. Manufacturer documentation adds some important checks to that decision, particularly around mounting, speed control and maintenance.
Why a case fan can survive a platform upgrade
BGR’s central distinction is between changing computing requirements and a relatively stable cooling task. Software and games can demand more processing power, while a case fan continues moving air regardless of the processor or graphics architecture inside the enclosure. That makes a healthy fan a candidate for another build, another computer or a suitable DIY project.
But “still spins” is not a complete compatibility test.
For example, Noctua specifies its NF-A12x25 PWM as 120 × 120 × 25 mm, with 105 × 105 mm mounting-hole spacing and a 4-pin PWM connector. Those details—not simply the fact that it is a PC fan—are what you would compare with the destination case and motherboard. They are specifications for that particular model, not universal measurements for every fan.
The mounting method also matters. Noctua’s installation manual directs users fitting this fan to a heatsink or radiator to use the mounting mechanism supplied with that cooling product. Its radiator guidance additionally addresses sealing the gap between fan and radiator to reduce air loss. In other words, fitting the screw holes is only part of doing the job properly.
A compatible plug does not guarantee speed control
One practical trap deserves more attention than it usually gets: a fan can run correctly yet lose automatic speed control after a move.
Noctua’s connector guidance confirms that its 3-pin fans can connect to 4-pin motherboard fan headers, leaving the fourth, PWM-signal pin unused. However, controlling a 3-pin fan’s speed requires suitable voltage-based control; plugging it into a 4-pin header does not magically make it a PWM fan.
Depending on the motherboard, the firmware setting may need to change from PWM to a voltage-based mode labelled DC, Voltage or Analog. Some boards select the appropriate method automatically. Noctua specifically advises consulting the motherboard manual rather than assuming all headers behave alike.
The reverse connection has a similar caveat: a 4-pin PWM fan attached to a 3-pin header can run at full speed unless the motherboard supports voltage-based regulation. If a transplanted fan suddenly sounds much louder, the control arrangement is worth checking before declaring its bearings worn out.
Long-life ratings are not retirement dates
The longevity figures behind this story are substantial, but they need careful interpretation.
Noctua lists an MTTF—mean time to failure—of more than 150,000 hours for the NF-A12x25 PWM, alongside a six-year manufacturer’s warranty. Antec lists 40,000 hours at 25°C for its P12 PWM. These are manufacturer specifications, not evidence that any particular used fan has that much service remaining.
BGR correctly distinguishes a statistical reliability rating from a guarantee. Its hypothetical conversion of 150,000 operating hours into more than 51 years at eight hours per day should therefore not be read as a lifespan prediction. The arithmetic does not tell you when an individual bearing will fail.
Nor should the two manufacturers’ figures be treated as a straightforward durability contest: Antec explicitly includes a temperature condition, while the quoted specifications do not establish equivalent testing methods.
What to check before keeping an old fan
A useful reuse assessment comes down to four questions:
- Will it fit? Compare dimensions, mounting-hole spacing and the required mounting hardware.
- Can it connect and be controlled? Check the fan connector, destination header and motherboard’s supported control mode.
- Does it show mechanical trouble? BGR identifies grinding, rattling and increasing vibration as possible signs of bearing damage.
- Has dust accumulated? Noctua recommends regular cleaning to maintain performance, using gentle methods rather than excessive force. For its NF-A12x25 PWM, it warns against vacuum cleaning and removing the impeller, which breaks the bearing seal. Follow the instructions for your particular model.
The bottom line is refreshingly unglamorous: an upgrade is a reason to inspect your fans, not an automatic reason to discard them. A compatible, well-maintained fan may earn another tour of duty. One with worsening mechanical symptoms deserves a different verdict, however impressive its original reliability rating looked on the box.
- Your Old PC Won't Age Well, But This One Part Is An Exception bgr.com · 2026-11-08T20:17:00+00:00
- Antec PC Fans, 120mm Fan, Silent Case Fans, High Performance, Silent Quiet Low Noise, 3-pin Connector, P12 Series antec.com
- FAQ: Can I run Noctua 3-pin fans on 4-pin PWM connectors or 4-pin fans on 3-pin connectors? | Noctua noctua.at
