The short version
The XF1 sells for roughly $179 / £139 / AU$339, depending on market. Lucas scores it:
- Sound quality: 4/5
- Features: 5/5
- Design: 5/5
- Usability and setup: 5/5
- Value: 4.5/5
His praise is for an open but focused soundstage, strong detail and a capable midrange. His main complaint is the bass. He calls it lumpy and one-note. He also says the tonal balance never becomes truly neutral, even with EQ adjustments.
Everything about how the speakers sound comes from Lucas's listening. It is not lab measurement.
What you get
Creative's launch announcement was dated June 24, 2026, with Japan as the first market in the global rollout. The company's own specification sheet lists:
- Drivers: two 3-inch woofers and two ¾-inch tweeters.
- Amplification: a separate amp for each driver. That is 2 × 26W RMS for the woofers and 2 × 10W RMS for the tweeters, 72W RMS in total.
- Frequency range: 55Hz to 40kHz. This is a manufacturer figure, not a promise of flat response.
- Dimensions: each cabinet is about 155 × 99.7 × 191 mm. The left speaker weighs 1.29 kg and the right 1.36 kg.
- Colours: black or white.
- Cables: a 1.5 m USB-A to USB-C cable and a 2.0 m speaker interconnect cable. The US product page also lists cork stands with screws.
The cabinets are MDF. Lucas says they look pricier than they are. He thinks the build and finish would suit a system costing two or three times as much.
Connections and PC compatibility
The right speaker is the hub. It carries the connections and the mains power, and a four-pin cable links it to the left speaker. Lucas notes you cannot swap channels. So "wireless" here still means at least two wires.
The inputs are:
- USB-C digital audio. Creative specifies up to 24-bit/96kHz.
- 3.5mm analog line-in.
- Bluetooth 6.0. Creative lists SBC, AAC and LDAC codecs, with a stated range of up to 10 m in open space.
- Subwoofer output. Creative describes this as an upgrade path to a 2.1 system. A separate powered subwoofer adds cost and desk or floor space.
Creative's US product page lists Windows PC among the supported platforms, alongside Mac, PlayStation 5, Nintendo Switch and Switch 2. Lucas tested with a MacBook Pro over USB-C, using Qobuz and Tidal. He did not report testing on Windows.
The Creative Nexus app
Controls on the speaker are minimal. Lucas describes a single front dial for power, volume and input selection, plus an LED. A rear button starts Bluetooth pairing, and an energy-saving switch powers the speakers down when idle.
Everything else lives in the Creative Nexus app. It offers:
- A 10-band parametric equalizer.
- Presets, with Creative claiming more than 100.
- Firmware updates.
- A Desktop mode for near-field listening.
Creative says the app supports Windows 10 or later (64-bit), iOS 17 or later and Android 10 or later. One independent reviewer notes Nexus replaces Creative's older "Acoustic Engine" software, so legacy effects such as Surround, Crystalizer and Dialog+ are absent. Stereo Guide adds that the app is not a full music remote. Lucas agrees there are no playback controls.
Stereo Guide also reported an app problem. After one step in its testing, the Nexus app couldn't find the speaker system, even after several attempts. Treat that as one reviewer's experience rather than a known bug. Creative's support page, as summarised in the research notes, shows a Windows Nexus release dated July 14, 2026. It describes a fix for firmware downloads or installations that failed under certain conditions. If you update firmware on a PC, install the latest Nexus build first.
Who should look elsewhere
Lucas's own "don't buy" list is short:
- You want truly wireless speakers. For that you need something battery-powered.
- You want strictly neutral sound. He says the XF1 has a flavour of its own.
- You care about bass nuance. The weight is there, but the detail is not.
He names the Logitech Z407 as the main alternative. In his view it costs a touch less and adds a subwoofer, so it has more real bass. But he judges it to have less poise, less balance and less ease of use than the XF1. These are his comparisons, not controlled tests. Check current prices yourself, because they vary by retailer and region.
Bottom line
For about $180, the XF1 gets a lot right. It gives a Windows or Mac desktop USB-C hi-res input, LDAC Bluetooth, an analog input, a parametric EQ and a subwoofer output for later expansion. The trade-offs are the power and interconnect cabling, a house sound that isn't neutral, and bass that Lucas finds underwhelming. If you plan to add a subwoofer, that cost and the extra desk or floor space should go into the budget.
- Creative XF1 review: although not truly perfect, these active desktop speakers get pretty close for not a lot of money TechRadar · 2026-11-07T18:00:00+00:00
- Creative Labs XF1 Bluetooth 6.0 Desktop Speakers 51MF1730AA001 bhphotovideo.com
- Creative XF1 Review: Hi-Res Desktop Speakers with USB Audio and Subwoofer Output stereoguide.com
