A sleek black Siemens-branded electronic device sits on a wooden surface in dim lighting.
The cybersecurity landscape is a sort of digital chess game, where one miscalculated move can lead to dire consequences. Recent advisories from the Cybersecurity and Infrastructure Security Agency (CISA) shed light on vulnerabilities affecting Siemens Solid Edge SE2024. As of December 12, 2024, CISA has announced that it will no longer update Industrial Control Systems (ICS) security advisories for Siemens product vulnerabilities beyond the initial advisory, thus placing the onus on users to stay informed.
Executive Summary of Vulnerabilities​
Let’s get right into the meat of it: The vulnerabilities associated with Siemens Solid Edge SE2024 are noteworthy. Recognized under the Common Vulnerability Scoring System (CVSS v4) with a score of 7.3, these vulnerabilities come with a low attack complexity, making them particularly concerning. Specific vulnerabilities identified include:
  • Heap-based Buffer Overflow - This is often a gateway for attackers to execute unauthorized code.
  • Integer Underflow (Wrap or Wraparound) - This flaw can also lead to potential code execution within the application’s context.
Affected Versions​
According to the advisory, all versions of Siemens Solid Edge SE2024 prior to V224.0 are affected. Ensuring your systems are updated is critical to mitigating risks associated with these vulnerabilities.
Risk Evaluation​
The risk from these vulnerabilities is significant. Successful exploitation could grant an attacker the ability to execute code in the context of the current process, meaning they could manipulate the application to perform actions that it was never intended to execute.
Technical Details on Vulnerabilities​
1. Heap-Based Buffer Overflow (CWE-122)​
Two different instances of heap-based buffer overflow vulnerabilities were recognized:
  • CVE-2024-54093: Related to parsing specially crafted ASM files.
  • CVE-2024-54094: Pertains to parsing specially crafted PAR files.
Both issues warrant serious attention, with CVSS v3 scores of 7.8 assigned, indicating high severity.
2. Integer Underflow (CWE-191)​
Another critical vulnerability involves integer underflow, which can occur during the same parsing processes as the heap-based buffer overflow. This is highlighted as CVE-2024-54095, also attracting a CVSS v3 score of 7.8.
Background Context​
Sector and Deployment​
These vulnerabilities directly impact critical manufacturing sectors, underscoring their importance in industrial operations around the globe, particularly from the German headquarters of Siemens.
Vulnerability Reporting​
The vulnerabilities were reported by Nafiez from Logix Advisor, indicating a proactive approach from external researchers to keep users informed and protected.
Mitigation Strategies​
Mitigating the risks associated with these vulnerabilities requires diligence. Here are some recommended strategies:
  • Do Not Open Untrusted Files: Users are encouraged to avoid opening untrusted ASM and PAR files in affected applications.
  • Update the Software: Siemens recommends updating to V224.0 Update 5 or later for buffer overflow vulnerabilities, and V224.0 Update 10 or later to mitigate the integer underflow vulnerability.
  • Protect Network Access: Employ appropriate mechanisms to guard your network against potential attacks, including the implementation of firewalls and isolation of control system networks from business networks.
CISA also advises on securing remote access through Virtual Private Networks (VPNs) and recommends adhering to industrial security guidelines provided by Siemens.
Broader Implications​
The implications of these vulnerabilities extend beyond individual companies. They resonate with the broader trend in cybersecurity where critical infrastructure becomes increasingly attractive targets for cyber adversaries. With the integration of manufacturing devices into larger networks, the need for vigilance is paramount.
Conclusion and Further Steps​
Organizations must not only implement the recommended mitigations but continuously review their cybersecurity practices in light of emerging threats. While no public exploitation of these vulnerabilities has been reported to CISA at this time, they are not remotely exploitable—an important consideration for future cybersecurity posturing.
Finally, users and organizations should stay informed by regularly checking Siemens' ProductCERT Security Advisories and implementing best practices from CISA to ensure robust defenses against these and future vulnerabilities.
The digital battleground is evolving, and staying one step ahead is not just a matter of concern—it's imperative.
  1. Siemens Solid Edge SE2024 | CISA CISA
