What Discord has confirmed
Discord's status page lists an incident titled "Issues establishing voice call," with an "Investigating" update at 08:26 PDT on October 31, 2026. That is 15:26 UTC. The status page later showed a "Monitoring" update at 12:40 PDT (19:40 UTC). That update said a fix had been implemented and the team was watching the results.
The page was inconsistent. Its past-incidents list still labeled the October 31 entry as unresolved, even though it displayed the later monitoring update. So the evidence supports "a fix was being monitored." It does not support "fully resolved." No restoration time was given.
The same page showed the individual components as operational when it was captured. Those included the API, Gateway, Desktop, Web, Android, and the US Central, US East, US South and US West voice regions. That doesn't rule out trouble for some users. An incident limited to establishing calls could sit alongside green components. It does argue against saying every Discord service was down.
What the outage trackers saw
Third-party trackers saw the same event, and they describe a connectivity problem centered on voice.
- StatusGator classed it as voice calls unavailable because of connectivity issues. It lists the detection at 3:26 PM, with Discord acknowledging it two minutes later. Its page showed a 3h 3m duration. In its recent-outage table, the incident later appeared as lasting 4h 20m. Treat both as tracker estimates, not Discord's own measurement of impact.
- StatusGator's page, checked at 8:32 PM UTC, said the service was operational. It also showed 113 user-submitted reports in the past 24 hours and said the outage was now resolved.
- Downforeveryoneorjustme logged a problem detected at 3:16 PM and resolved at 6:06 PM. It reported about three hours of downtime. Another tracker, Instatus, said recent reports leaned toward app, messaging and login complaints. That snapshot reflected a quiet hour, not the incident window.
- Downforeveryoneorjustme says that audio/video accounted for 80% of its reports, which matches the voice-call incident.
- One StatusGator user report from California described trouble connecting to voice servers. It said no calls had gone through for the previous four hours. This is a single anecdote, but it fits the official incident title.
The Sunday Guardian's numbers
The Sunday Guardian article leans on Downdetector. It says Downdetector showed 1,565 reports at 10:08 pm on October 31, against a baseline of 12. It also says the top-issues section listed more than 300 issues. I couldn't independently verify those figures, and the article doesn't state a timezone. Read them as that outlet's snapshot, not as a confirmed count of affected people.
Several details deserve caution:
- The breakdown doesn't add up. The listed categories are connectivity (59), server not responding (8), service down (6), app not loading (4), error message (2), slow performance (1) and other (1). Together they total 81. That is nowhere near 1,565, so they probably come from a different display or subset.
- The headline says "thousands." The article's own figure is 1,565 reports, which is not thousands. The piece also disclaims that user reports don't prove a platform-wide failure.
- PC and Xbox are in the headline only. The official incident doesn't mention either platform. Nothing I found shows PC or Xbox users were hit harder than anyone else.
- Rolling counts differ. The article cites 70 StatusGator reports and more than 732 tracked outages. The live page I saw showed 113 reports. It also said it had tracked more than 735 outages. These counts change with time. Don't add them together.
Where the reports came from
StatusGator's map listed India, the United Kingdom and Germany as the top report locations over 24 hours. Individual reports came from Belarus, Switzerland, the United States, the Netherlands, Poland, Czechia, Canada and Australia. These are the places where reports were filed. They don't show everyone in those places was affected, and they don't show a US-wide outage.
Not Discord's first voice problem this week
The day before, Discord's status page showed a similar incident, "Issues establishing voice calls." It was resolved at 09:18 PDT on October 30 after a fix was implemented. Instatus put the earlier incident at 55 minutes, with reports peaking at about four times normal. Two voice-call incidents in two days is notable. But nothing in the evidence says they share a cause, and I won't guess at one.
What to do if calls won't connect
- Check Discord's status page first. If the voice-call incident is listed, the problem is probably not on your end.
- Test whether only voice is failing. If text chat and servers load but calls won't start, that matches the official incident. It doesn't prove your own cause.
- Check your connection. Try another site or network, since many "connectivity" reports have local causes.
- Restart the desktop app or browser tab. Update Discord if an update is offered.
- Skip repeated reinstalls. They won't fix a server-side problem and can waste time.
- Don't count on a recovery time. Discord gave none. Watch the status page for a final "Resolved" entry.
The takeaway
Discord's own incident points to a voice-call problem, and Discord said a fix was in place and being monitored. Crowd-sourced trackers corroborate a spike in connectivity complaints, mostly about audio and video. The wider claims about messages, app loading, server access and Xbox aren't backed by the official record. Outage-tracker spikes are a useful early signal, but they measure complaints, not confirmed impact. When a headline says "thousands," check the status page.
- Discord Outage Today: Is Discord Down in the US? Thousands Users Reports Major App Loading Problems, Voice Call Failures, Messages Errors & Server Access Issues on PC, Xbox | Check Downdetector Status - The Sunday Guardian The Sunday Guardian · 2026-10-31T19:32:27+00:00
- Discord Status. Check if Discord is down or having an outage. statusgator.com
- Is Discord down? Live status and problems past 24 hours downforeveryoneorjustme.com
