A wall-mounted Wi-Fi router with multiple antennas, connected to a network.
A new force has entered the competitive mid-range Wi-Fi market, and it’s not from the usual names. The DrayTek VigorAP 905, quietly launched and now grabbing attention in recent group tests, aims to deliver robust Wi-Fi 6 coverage and enterprise-grade control, all without the premium pricing of more prominent consumer brands. PC Pro Magazine’s August 2025 review puts DrayTek’s promise of fuss-free mesh networking and security-rich features to the test, revealing a device that brings both surprising strengths—and a few critical compromises—to home and pro users seeking affordable, scalable wireless.
Background: A Shifting Wi-Fi Landscape​
Home and business networking is in a state of flux. Wi-Fi 6 continues to mature, and aggressive pricing for Wi-Fi 6E and initial Wi-Fi 7 mesh kits is already pulling the top spenders into the future. Yet, for the vast majority of buyers, especially small businesses and “prosumer” households, a rock-solid Wi-Fi 6 solution strikes the best balance between cost, performance, and device compatibility.
DrayTek, long respected in business circles for robust, security-focused routers, often flies under the radar in mainstream mesh and access point chatter. The VigorAP 905, however, is designed to change that with a package promising:
  • Dual-band Wi-Fi 6 speeds (up to 2402Mbit/s 5GHz, 574Mbit/s 2.4GHz)
  • Dedicated mesh controller support
  • Flexible deployment as standalone AP, mesh node, or wireless bridge
  • DrayTek’s signature business-class management tools
With a retail price hovering around £120, the VigorAP 905 targets price-sensitive buyers who refuse to compromise on stability or control—a rare strike zone among both consumer and SME networking gear.
Design and Core Features​
The VigorAP 905 is unashamedly functional in its design, prioritizing cooling, antenna performance, and easy mounting over slick domestic stylings. Physically, the unit boasts:
  • Four external adjustable antennas (detachable)
  • Well-ventilated chassis for 24/7 operation
  • Integrated wall and ceiling mounting points
  • Four gigabit Ethernet ports plus PoE (Power-over-Ethernet) support
Interface-wise, a crisp, browser-based setup menu provides access to advanced settings—VLANs, multiple SSIDs, guest isolation, firewalling, mesh topology control, and more—mirroring the capabilities found in DrayTek’s more expensive business products. Notably, users can combine up to six VigorAP 905 units in a mesh arrangement, managed either locally or through a DrayTek router.
Mesh Capabilities​
The VigorAP 905’s mesh system, while less glossy than big-brand consumer options, offers enviable flexibility:
  • Easy expansion by adding new nodes via WPS-based pairing
  • Seamless roaming with fast hand-off, ideal for multi-story homes and offices
  • Wired or wireless backbone support (including mixed-mode operation)
By allowing a mix of Ethernet and wireless uplinks, installers can optimize placement for reliability and maximum throughput—a significant win for both awkwardly-shaped homes and offices with legacy wiring.
Security and Management​
DrayTek’s security pedigree shines through. The AP supports enterprise-grade protections including:
  • WPA3 encryption
  • 802.1X authentication (RADIUS)
  • Per-SSID VLAN assignment
  • User and time-based access rules
  • Centralized monitoring, alerting, and syslog support
Most surprisingly, granular control is available even in mesh mode—a rarity when compared to “set-and-forget” consumer meshes that often hide (or lack) business-grade management features. Firmware upgrades can be automated or applied centrally, providing welcome peace of mind for teams responsible for multiple locations.
Performance: Real-World Testing and PC Pro’s Verdict​
In the 2025 PC Pro group test, the VigorAP 905 was pitted against both value-driven and high-end rivals. Its Wi-Fi 6 chipset performed admirably in a variety of scenarios:
  • Speed: In single-AP mode, throughput approached the theoretical maximums for Wi-Fi 6, matching more expensive competitors on 80MHz channels. Devices consistently achieved 900Mbit/s+ close-range (5GHz Wi-Fi 6 client), dipping to 350-400Mbit/s at range and through multiple walls—impressive for any mid-price AP.
  • Mesh operation: In multi-node mesh, the VigorAP 905 delivered stable speeds with only a modest throughput penalty for devices moving between nodes. Hand-over was quick, avoiding dropouts even during lag-sensitive tasks such as video calls and gaming.
  • Wired backbone: When nodes were connected via Ethernet, mesh performance closely mirrored direct AP results, demonstrating the versatility of DrayTek’s hybrid meshing.
While the “feel” of the DrayTek mesh lacks the frictionless mobile-app experience of Asus, TP-Link, or Netgear Orbi, power users and network admins will appreciate the transparency and depth of control.
Standout Strengths From Testing​
  • Rock-solid stability: Uptime was flawless across a month-long torture test. No unexplained disconnects or “node drops” were observed, a notorious issue with cheaper mesh systems.
  • Interference resilience: Wi-Fi 6’s OFDMA and MU-MIMO combine well with DrayTek’s radio tuning, delivering consistent bandwidth even in congested, device-heavy environments.
  • Management consistency: Whether in mesh or standalone mode, every layer of network configuration stayed clear, with no loss of advanced features—a huge plus for business deployments.
Feature Breakdown: What Sets the VigorAP 905 Apart?​
Versatile Deployment Modes​
DrayTek customers can deploy the VigorAP 905 in three distinct ways:
  • Standalone AP: For offices or businesses simply seeking a fast, secure hotspot.
  • Mesh node/controller: Scalable mesh for growing coverage as needed, without controller hardware lock-in.
  • Wireless bridge/repeater: Quick extension of legacy networks without the configuration headaches of range extenders.
Remote and Cloud Management (Optional)​
For MSPs and IT teams, DrayTek offers optional central management via:
  • VigorACS cloud management (subscription required)
  • Direct integration with DrayTek business routers for site-wide policy enforcement
This feature is especially powerful for branch offices or multi-site organizations, blurring the lines between consumer AP, prosumer mesh, and classic enterprise Wi-Fi control.
Advanced Traffic and Access Controls​
In addition to deep VLAN support, the VigorAP 905 offers:
  • Traffic shaping and bandwidth limits per SSID or user
  • Application-aware firewall and parental controls
  • Scheduled Wi-Fi availability
Unlike most mesh rivals, these controls function in both single and multi-AP deployments—a vital advantage for mixed-usage environments.
PoE for Flexible Placement​
Power-over-Ethernet support removes the need for a nearby mains socket, allowing for neat, out-of-the-way installations—crucial for jobs where both aesthetics and signal propagation matter.
Comparisons: How Does the VigorAP 905 Match Up?​
With its £120 price point, the DrayTek VigorAP 905 is bracketed by both entry-level consumer mesh kits and lower-tier enterprise access points. Its principal competition includes:
Consumer Mesh Kits​
  • TP-Link Deco X20: Glossier mobile setup, but limited advanced controls, less capable VLAN support, and fewer management options.
  • Netgear Orbi RBK352: Strong performance, but higher cost, app-centric management (less transparency), walled-garden ecosystem.
  • Asus ZenWiFi AX Mini: Attractive pricing, seamless mobile experience, but lacks DrayTek’s granular business features and can be inflexible for power users.
Enterprise/Prosumer APs​
  • Ubiquiti UniFi 6 Lite: Slightly higher price, controller-dependent, wireless mesh not as mature, occasional stability hiccups in larger deployments.
  • Cisco Business CBW150AX: Excellent hardware, more expensive, more complex setup, and recurring license costs for advanced features.
DrayTek’s value proposition is clear: an AP that covers 90% of SMB requirements at a fraction of classic enterprise costs, with none of the “dumbing down” prevalent in home mesh kits.
Critical Analysis: Strengths and Cautions​
Key Strengths​
  • Uncompromised Control: Almost all advanced features remain available in mesh mode—rare at this price.
  • Consistent, Transparent Management: No hidden limitations or forced cloud accounts, avoiding the lock-in and sudden app deprecations of consumer giants.
  • Stability and Security: Month-long stress testing shows professional-class reliability—an essential trait for business-critical deployments or home offices reliant on VoIP, VPNs, or high-availability cloud work.
  • Flexible Expansion: Can be adopted in growing organizations, adding nodes or reconfiguring roles without rebuying or repurposing hardware.
Risks and Limitations​
However, the VigorAP 905 is not the perfect fit for every use case:
  • Setup Complexity: The advanced interface, though comprehensive, will intimidate non-technical users. There’s no step-by-step mobile app wizard, and initial provisioning is best left to someone comfortable with networking concepts.
  • Basic App Experience: Lack of a robust smartphone app for local or remote management, which more modern rivals tout as standard, hinders “fire-and-forget” usability.
  • Limited Third-Party Mesh Interoperability: The mesh ecosystem is proprietary—users are locked into other DrayTek VigorAP units if expanding mesh coverage, a trade-off for management consistency.
  • No Wi-Fi 6E/7 Support: While Wi-Fi 6 is sufficient for most users today, the VigorAP 905 will inevitably date as client devices shift to 6GHz and Wi-Fi 7 over the next few years. This timing risk is standard among sub-£150 APs but is worth consideration for future-proofing.
Ideal Applications: Who Should Buy the DrayTek VigorAP 905?​
Best For:​
  • Small businesses needing rock-solid Wi-Fi and employee/corporate traffic separation
  • IT-managed multi-story homes or home offices with wired backhaul and mixed security needs
  • Schools, medical offices, shared spaces requiring granular user and VLAN controls
  • Branch offices of larger organizations seeking affordable, easy-to-expand mesh
Possibly Not Ideal For:​
  • Tech-averse homeowners who crave “plug-and-play” simplicity and will never touch browser settings—Asus ZenWiFi, Eero, or TP-Link Deco will provide a faster, easier start.
  • Early adopters wanting 6E/7 support or heavy 160MHz channel utilization for ultra-high throughput scenarios—future-centric mesh alternatives are available, often at twice the price.
Final Verdict: A Mesh Solution for the Discerning​
The DrayTek VigorAP 905 is the rare access point that now wears multiple hats and wears them well. Its performance matches or exceeds expectations in both wired and true wireless mesh modes. Long-term reliability, security, and flexibility back up the claim that business roots can benefit home users—if those users are ready to manage their own networking destiny.
Where it falls just short of consumer mesh rivals in out-of-the-box ease, it soars ahead in control, transparency, and expansion options. For the self-reliant power user or growing business, the VigorAP 905 is a top-tier recommendation—perhaps the stealth hit of this year’s Wi-Fi tests. The greatest testament: it’s a product that will probably never cause you to reboot it.
As long as Wi-Fi 6 remains mainstream, and as long as buyers value policy, security, and uptime ahead of app glitz, DrayTek’s VigorAP 905 stands as one of the best mesh-capable business-class access points currently available at its price—quietly redefining what sub-£150 Wi-Fi hardware can deliver.
  1. Draytek vigorap 905 - 7 Aug 2025 - PC Pro Magazine - Readly Readly | All magazines - one magazine app subscription
