Currently listed as In development, the feature is slated to hit Preview in January 2027 and reach General Availability in March 2027, targeting Desktop and Web clients across Worldwide (Standard Multi-Tenant) and GCC cloud instances. In plain English, Microsoft is teaching Available-to-Promise (ATP) calculations to stop treating every customer and every SKU like they move at the exact same operational speed.
What Roadmap ID 581798 Actually Changes
Until now, standard ATP order promising has leaned heavily on stock timing, planned supply and demand, transport days, and item-level issue margins. Roadmap ID 581798 splits fulfillment friction into two distinct, real-world dimensions and feeds both directly into the ATP promise date:
- Customer lead time: Extra time that applies to everything shipped to a specific customer. Microsoft’s examples include agreed service levels, fixed delivery schedules, and extra handling or documentation requirements.
- Product lead time: Extra time that applies to a specific item no matter who buys it. That covers warehouse realities such as specialized packing, quality checks, kitting, or vendor lead times on non-stocked items.
As with every item on the Microsoft 365 and Copilot Roadmap, those January and March 2027 dates are planning estimates rather than ironclad release guarantees. Microsoft explicitly notes that features marked "In development" remain subject to change during preview and before production rollout. Still, the intent is clear: bring ATP promise dates closer to what fulfillment teams actually experience on the dock.
How Dynamics 365 ATP Works Today—and Where Generic Timers Fall Short
To appreciate why customer- and product-specific lead times matter, it helps to look under the hood of how Dynamics 365 Supply Chain Management currently calculates delivery dates. According to Microsoft Learn’s Order promising documentation, Dynamics 365 offers five primary delivery date control methods:
| Delivery Date Control Method | What It Evaluates | Best-Fit Scenario |
| Sales lead time | Default number of days from order creation to shipment; ignores on-hand stock, demand, and planned supply. | Simple catalog items where stock checks aren't required. |
| ATP (Available-to-Promise) | Uncommitted inventory, lead times, planned receipts, and issues using cumulative look-ahead math. | Make-to-stock items where material availability drives the date. |
| ATP + Issue margin | ATP date plus the item’s issue margin (time needed to prepare goods for shipment). | Stocked goods needing a consistent outbound prep buffer. |
| CTP (Capable-to-Promise) | Material availability plus production capacity via BOM/route explosion. | Assemble-to-order or make-to-order items with capacity constraints. |
| Batch CTP (formerly CTP for Planning Optimization) | Background-calculated CTP triggered when a dynamic master plan runs. | High-volume Planning Optimization environments using scheduled batch promising. |
Under the hood, Dynamics 365 calculates standard ATP using the cumulative ATP with look-ahead method. In the opening period, ATP starts with uncommitted inventory—on-hand stock minus due and overdue customer orders—and then walks forward period by period:
ATP = ATP for the previous period + Receipts for the current period − Issues for the current period − Net issue quantity for each future period (until cumulative future receipts exceed cumulative future issues).
Microsoft Learn highlights several strict boundaries in that existing engine:
- Negative results clamp to zero: If previously promised demand exceeds available supply, displayed ATP defaults to zero rather than showing a negative figure.
- Time fences and expiry limits: ATP ignores batch expiry dates and assumes any quantity can be promised once you look past the configured ATP time fence.
- Sticky promises on order edits: When a sales order is updated, Dynamics 365 only recalculates order promising if the existing promised date can no longer be met. Increase a quantity and push the achievable date out, and promising triggers; decrease a quantity so it could ship earlier, and the existing feasible promise date stays put unless changed manually.
Why ATP + Issue margin and Transport Days Weren't Enough
Right now, administrators set a global default delivery date control method under Accounts receivable > Setup > Accounts receivable parameters (on the Shipments tab under Delivery control), and override it per SKU under Product information management > Products > Released products > Default order settings. You can layer on transport days based on mode of delivery, warehouse, and destination address, or use ATP + Issue margin to tack on an item-level outbound warehouse buffer.
Notice what’s missing from that equation? Customer-specific operational drag. Mode-of-delivery transport days cover the truck on the highway, not the extra 48 hours required to compile a customer’s bespoke certificate of analysis or hit a rigid Tuesday-only receiving window. Meanwhile, relying solely on item-level issue margins forces teams into a messy compromise: pad the margin for everyone and slow down standard customers, or keep it lean and miss SLAs for high-touch accounts.
Part of a Bigger Push Toward "Honest" ATP in Dynamics 365
Roadmap ID 581798 does not land in a vacuum. Over the past several release cycles, Microsoft has systematically plugged real-world blind spots in Dynamics 365 Supply Chain Management’s ATP engine:
- Version 10.0.43 (March 2025): Introduced the ATP excl. reserved on-hand parameter in Accounts receivable parameters so organizations can choose whether reserved on-hand stock counts as available in ATP checks.
- Version 10.0.50 (December 2026 release, auto-update GA in January 2027): Microsoft Learn’s release notes list two major ATP upgrades—Consider inventory status in Available-to-Promise (ATP) calculations, which prevents quarantined or channel-segmented stock from skewing promise dates, and a preview feature (Configurable ATP with Receipt Control) that lets admins exclude purchase orders, production orders, or inbound transfer orders as ATP receipt sources.
- Omnichannel & Commerce ATP: Microsoft has also expanded headless ATP APIs through the Inventory Visibility Add-in and Commerce Scale Unit, pairing time-series availability with transfer-order lead times across retail and warehouse channels.
Viewed alongside those updates, adding customer and product lead times to ATP looks like the next logical step in turning order promising from a naive inventory math check into a true reflection of fulfillment reality. It is also worth keeping the boundary between ATP and CTP clear: this roadmap item refines ATP, which assumes infinite production capacity. If your bottleneck is machine hours or shop-floor labor rather than packing, quality checks, or customer handling, capacity-aware CTP (including Near real-time CTP available since version 10.0.41) remains the right tool for the job.
What Microsoft Hasn’t Confirmed Yet—and How Admins Should Prepare
Because Roadmap ID 581798 is still in development, several critical implementation details remain unanswered in public documentation. Supply chain architects and functional consultants should watch for Microsoft’s preview documentation to clarify:
- Calculation mechanics: Are customer lead time and product lead time strictly additive, or does one take priority over the other? How will they stack with existing Issue margin, Safety margins (such as soft issue margin behavior), and Transport days?
- Which dates move: Does the new logic adjust the Confirmed ship date, the Confirmed receipt date, or both?
- Calendars and working days: Will customer and product lead times respect warehouse shipping calendars, customer receiving calendars, or plain calendar days?
- Configuration surface and prerequisites: Microsoft has not yet published which form or parameter holds these lead-time fields, whether a Feature management toggle will gate the rollout, or which minimum 10.0.x application build will be required.
Practical Next Steps Before January 2027
You cannot configure an unreleased feature today, but you can clean up the workarounds it is meant to replace:
- Audit manual promise overrides: Identify which customer accounts and SKUs routinely force sales reps to override ATP dates because of kitting, QA holds, export paperwork, or non-stocked vendor lead times.
- Review current Delivery Control and Issue Margin rules: Document where you inflated item-level issue margins or sales lead times solely to protect a handful of high-maintenance customers.
- Map your upgrade cadence: With 10.0.50 hitting auto-update general availability in January 2027 and this new ATP capability targeting Preview in that same month, plan sandbox testing early so your order-to-cash team can validate how customer and product lead times interact with your existing Master Planning and Planning Optimization setup before the March 2027 GA window.
Summary
Microsoft’s newly announced ATP with customer & product lead time update (Roadmap ID 581798) aims to close one of the most persistent gaps in Dynamics 365 Supply Chain Management order promising: accounting for customer-specific service schedules and item-specific handling or vendor delays directly inside ATP calculations. Targeting Preview in January 2027 and General Availability in March 2027 for Worldwide and GCC clouds, it complements recent ATP accuracy improvements around reserved inventory, inventory statuses, and configurable receipt sources—even as admins wait on preview docs to reveal the exact math and configuration knobs.
- Dynamics 365 Supply Chain Management: ATP with customer & product lead time Microsoft 365 Roadmap · 2026-11-25T00:10:31.204411Z
- Order promising - Supply Chain Management | Dynamics 365 | Microsoft Learn learn.microsoft.com
- Calculate sales order delivery dates using CTP - Supply Chain Management | Dynamics 365 | Microsoft Learn learn.microsoft.com
