A wireless gaming headset with a boom mic sits on a desk beside battery and connectivity icons.
The Edifier Hecate G5 Max has a battery-life headline that sounds like a typo. PC Gamer's review finds that the rest of the headset doesn't live up to it. The review is from reviewer Andy Edser, and its verdict is blunt. The headset has stellar endurance, but a boxy default sound, a dull microphone and a "slightly cheap-feeling" build make it a hard sell at $150.
A wireless gaming headset with a boom mic sits on a desk beside battery and connectivity icons. What the 305 hours actually means​
Edifier's U.S. spec sheet lists up to 305 hours in Bluetooth mode. That is a narrower claim than the single "305-hour" line in PC Gamer's spec table, which names no connection mode.
Other sources fill in the qualifiers:
  • Edifier's Hecate site says the battery lasts up to 305 hours in Bluetooth mode and 227 hours in 2.4 GHz mode.
  • The company says those figures were measured at 50% volume with the lights off.
  • A retailer-style spec listing gives roughly 119 hours (Bluetooth) and 104 hours (2.4 GHz) with the lights on.
The practical point for PC users is that the 2.4 GHz dongle is the usual low-latency choice for gaming on a desktop. If you use it, plan around the lower figure.
How the reviewer tested it​
Edser says he tested for about three weeks and hadn't charged the headset yet. That included leaving it on overnight a few times to try to drain it. This is an anecdotal endurance result, not a measured full-charge runtime. The review doesn't state the connection mode, volume or lighting settings. It supports "very long-lasting in practice" and nothing more precise.
Other reviewers saw similar behavior:
  • Tom's Guide reported about 18 hours of use, including overnight on a PS5, took the battery down only 7%.
  • The Shortcut said it charged the headset once and still had roughly 80% left.
Where it falls short, per PC Gamer​
Sound. The default tuning is very boxy, and the EQ presets are heavy-handed. Several game presets push the upper mids and treble hard, and the bass preset overdoes it. Edser got better results with his own parametric EQ curve: a small bass lift, a slight dip around 200–300 Hz and a touch more treble. He praises the drivers' detail and positioning, especially for footsteps in shooters with spatial audio on.
Microphone. The built-in mics are described as hollow but usable in a pinch. The boom mic is dull and muffled. Raising noise reduction brings audible digital artifacts, and the clarity setting adds sibilance and removes depth. These are subjective listening impressions, not measurements.
Fit and build.
  • The thick headband and low weight are comfortable at a desk.
  • The ear cup frame is metal, but the earpads feel baggy.
  • Clamping force is light enough that the headset slipped during movement.
  • The controls feel tinny and the ear cup plastics are glossy.
Software. The Hecate app has a parametric EQ, a separate bass boost, volume levelling, THX Spatial Audio+ switching and a separate mic EQ. It also has RGB, power-off and connection controls, plus user profiles. Edser says the app got stuck in an update loop when he first installed it. He allows that this may be a one-off, so treat it as one person's experience.
Reviews disagree​
PC Gamer is on the harsher end. The same hardware gets much warmer treatment elsewhere:
  • Tom's Guide calls it supremely comfortable, with excellent, immersive in-game audio.
  • The Shortcut scores it 4/5 but says a weak mic holds it back.
  • CGMagazine finds it solid overall but says the feel of prolonged use drops the ball.
The microphone is the one weak spot that several reviews share, and the sound verdict is where they diverge most. Sound quality is subjective, and fit varies with head size. Reading two or three reviews beats trusting any single score.
Specs worth knowing​
ItemDetail
Weight305 g
Connectivity2.4 GHz via USB-A/USB-C dongle, Bluetooth 6.0, wired
CodecLHDC 5.0 over Bluetooth
Drivers53 mm; Edifier says PEN diaphragm, PC Gamer says composite and titanium-coated
Frequency response20 Hz–40 kHz
MicrophonesDual built-in mics plus detachable boom
Launch US price$149.99
PC Gamer's table prints the frequency response as 20,000–40,000 Hz. That looks like a typo, since the manufacturer's figure is 20 Hz–40 kHz. The review also lists a "$150/$160" price without explaining the second number. The $149.99 figure is the launch MSRP, and street prices may differ.
How it compares, per PC Gamer​
  • Razer BlackShark V3: The review's top gaming headset pick. It is lighter at 270 g, has better out-of-box sound and a nicer chassis, and gets only 70 hours of battery. Its mic is also weak, but better than the G5 Max's.
  • PowerA LucidSound LS500: Cheaper and lighter, with 70 hours of battery. Edser prefers its mic and its 50 mm drivers.
  • HyperX Cloud Alpha Wireless: Rated for 300 hours, and the review priced it at $109 on publication. That price will have moved since.
Bottom line​
The G5 Max is a good fit if you mostly use Bluetooth, hate charging and are willing to spend time in the EQ. It's a poor fit if you want a good mic, a secure fit while moving, or good sound without tinkering. The 305-hour figure is real but conditional. It applies to Bluetooth with the lights off, and 2.4 GHz buyers get a lower rating. PC Gamer's verdict is that battery life alone doesn't justify $150.
  1. 305-hour battery life should make this headset a superstar, but it's the rest that lets it down - PC Gamer PC Gamer 2026-10-30T17:06:25+00:00
  2. Edifier G5 Max review: incredible sound and amazing battery life, held back by a weak mic theshortcut.com
  3. Gaming Headset edifier.com
