The color is a convention, not a code
The MakeUseOf piece says there is no universal standard for Ethernet cable colors. Meaning depends on what an organization, vendor or installer decides. Industry sources agree. BICSI, a telecommunications standards body, says no standards presently address recommended colors of balanced twisted-pair cables, whether based on performance category or intended use (network, AV, voice).
So the familiar color lists are local habits, not rules. The article offers these examples:
- Blue: general network connections.
- Yellow: Power over Ethernet devices such as cameras, VoIP phones and access points.
- Red: critical or restricted links.
- Green: crossover links or building systems.
- Orange or purple: special purposes such as test, guest or contractor networks.
Each of these may hold at one site and mean something else at the next. One real-world example is a county government cabling standard that says all cabling for CCTV electronics shall have yellow cable jackets. That is a local rule written into one organization's specification. It isn't a universal one.
One nuance: BICSI's guidance concerns balanced twisted-pair jacket colors. Color coding does exist elsewhere in structured cabling. The Fluke Networks material mentions the ANSI/TIA/EIA-606-A labeling standard, which requires work-area outlets to be labeled with floor, telecommunications room, patch panel and port. Labels and records are the dependable system. Jacket color is a visual aid on top of them.
Don't confuse jacket color with wire color
The article is careful to separate two things:
- Jacket color is the outer covering. It is purely organizational.
- Conductor color is the coding of the wires inside. It matters for termination. Wikipedia's summary of TIA-568 notes the pair colors run blue, orange, green and brown. Each pair has a solid conductor and a white-striped partner.
If you're crimping a plug, the inner colors matter. If you're tracing a cable behind a desk, only the jacket color and your own documentation matter.
What actually tells you performance
The category printed on the jacket is the better clue. Reference material on Cat 5 notes that the category and type of cable can be identified by the printing on the jacket. Look for markings such as Cat 5e, Cat 6, Cat 6A or Cat 8 along the cable.
The article gives rough speeds for each category. Fluke Networks' comparison table adds the distance limits that matter in practice. All figures below are for 100 m channels unless noted.
| Category | Max frequency | Supported Ethernet standards (Fluke) |
| Cat 5e | 100 MHz | 10BASE-T, 100BASE-TX, 1000BASE-T |
| Cat 6 | 250 MHz | The above, plus 10GBASE-T up to 35 m |
| Cat 6A | 500 MHz | The above, plus 10GBASE-T at 100 m |
| Cat 8 | 2000 MHz | The above, plus 25/40GBASE-T up to 30 m |
Three corrections to common shorthand:
- Cat 6 is not a long-run 10 Gb/s cable. Fluke lists 10GBASE-T for Cat 6 only up to 35 m. That makes it the weak spot in the article's "Cat 6a handles 10 Gbps over longer distances" comparison. The accurate version is that Cat 6A reaches the full 100 m.
- Cat 8 is short-reach. Fluke's fact sheet says Cat 8 has a maximum permanent link of 24 m and a maximum channel of 30 m for 25 and 40 Gb/s. It can support 10 Gbps and lower at a full 100 m channel. It is also a shielded-only design, so shield termination matters.
- MHz is not Gb/s. Frequency is a cable's rated bandwidth. Data rate depends on the Ethernet standard running over it.
A category label is also not a guarantee. Fluke says a link only counts as certified if the cable and hardware meet their standards, it is installed correctly, and it passes a test from a compliant field tester. The same material notes that not all Cat 5e installations can support NBASE-T (2.5 and 5 Gb/s), which is why certification is recommended.
Is "upgrade to Cat 6" good advice?
MakeUseOf suggests moving from Cat 5 to Cat 6 or 6A can make a noticeable difference. That is sometimes true, but it depends on your setup. If your router, switch and network adapter top out at 1 Gb/s, a good Cat 5e cable already runs at that speed. A new cable won't make it faster. The cable only becomes the bottleneck when the equipment at both ends supports a higher rate, or when an old or damaged cable is causing errors. This is my analysis based on the Fluke figures, not a claim from the MakeUseOf article.
Practical advice
- Home: Color-code however you like, for example one color for router-to-switch and another for the NAS. Write the scheme down.
- Office or server room: Don't unplug a red or yellow cable because you assume it's critical or PoE. Check labels, patch-panel records or the documented scheme first.
- Buying: Read the category on the jacket or packaging. Ignore the color.
- Troubleshooting: If a link underperforms, check the devices at both ends and the run length. Then consider a cable tester. Fluke notes cabling is a leading cause of network failures, so testing beats guessing.
Bottom line
The rainbow of Ethernet cables is a housekeeping tool. A bright pink Cat 6 can outperform a gray Cat 5e, as the article says, but only if the rest of the link supports it. The real information is the printed category, the length of the run and the quality of the installation.
- I never realized Ethernet cables had a color code until now MakeUseOf · 2026-11-02T14:00:16+00:00
- Cat 8 Ethernet Cable Fact Sheet | Fluke Networks flukenetworks.com
- Network Engineer Tools and Troubleshooting Guide | Fluke Networks | Fluke Networks flukenetworks.com
