An open rack-mounted server reveals four large graphics cards, cooling fans, and illuminated components in a data center.
G2 Digital has launched the 2U Q-Power, a rack-mount system designed to fit up to four dual-slot Nvidia RTX GPUs into a 2U enclosure for AI workloads and rendering. DEVELOP3D reports that its custom chassis places the graphics cards horizontally, parallel to the motherboard—a packaging choice that makes GPU density the central attraction.
The headline configuration combines four RTX PRO 6000 Blackwell Max-Q cards for 384 GB of aggregate GPU memory. That is substantial capacity, but the distinction between aggregate memory and a single memory pool matters just as much as the number on the specification sheet.
An open rack-mounted server reveals four large graphics cards, cooling fans, and illuminated components in a data center. Two configurations, different priorities​
G2’s own product page separates the range into a workstation-oriented build and an EPYC-based server:
ConfigurationProcessor familyGPUsSystem memoryListed Windows option
PT9W workstationAMD ThreadripperTwo GeForce RTX 5090 cards512 GB ECC RDIMMWindows 11 Pro / Workstation
SE5 serverAMD EPYCFour RTX PRO 4000, 5000 or 6000 cards1 TB ECC LRDIMMWindows Server
These are vendor-listed specifications, rather than independently tested configurations. G2 does not identify the Windows Server release in that listing.
The company describes the system as built in Hampshire and lists an 890 mm-deep chassis, a 2,700 W power supply, dual 10GbE networking and IPMI management. Buyers should therefore assess more than rack height: depth, power provision and management integration belong on the procurement checklist too.
What 384 GB actually buys​
Nvidia’s official datasheet confirms that each RTX PRO 6000 Blackwell Max-Q has 96 GB of GDDR7 ECC memory, a PCIe 5.0 x16 interface and a 300 W board-power rating. Four cards therefore provide 384 GB in total, with combined GPU board-power ratings of 1,200 W before accounting for the rest of the server. That is specification arithmetic, not a measurement of Q-Power’s wall-power consumption.
Crucially, four cards do not establish one transparently accessible 384 GB allocation. Nvidia’s inference documentation describes model-parallel techniques that distribute weights and activations across GPUs; it also explains that serving requests requires additional memory for the key/value cache. More concurrent requests can increase that cache footprint considerably.
DEVELOP3D reports support for 70-billion-parameter models at “full precision,” plus larger models using lower precision or quantisation. However, the report does not specify the model, numerical format, context length or concurrent-user count behind that claim. Treat it as a capability assertion, not a guarantee that every 70B deployment will fit—or deliver the same performance.
The practical takeaway: ask for a demonstration using the intended model, serving software, context length and user load. GPU capacity is the starting point, not the acceptance test.
Cloud savings need a reproducible comparison​
G2 claims up to 18-fold lower costs per million tokens than premium cloud AI APIs under sustained use, alongside local latency below 40 milliseconds versus roughly 1.5 seconds for cloud APIs. Those are company claims; its product page does not provide a reproducible comparison identifying the cloud service, model, workload and latency metric.
For procurement, request three separate results:
  • Responsiveness: time to first token and subsequent generation speed.
  • Capacity: throughput at the required number of simultaneous users.
  • Economics: total ownership costs against the actual API and model being replaced.
Those are proposed evaluation criteria, not results established for this machine.
Local control is not automatic compliance​
G2 presents on-premises operation as a way to keep proprietary information within an organisation’s environment, citing GDPR, HIPAA and SOC 2 considerations. Its page does not establish a product-level compliance guarantee; buyers should not read that positioning as one.
The Q-Power’s clearest supported proposition is compact four-GPU packaging, with separate workstation and server configurations. The sensible next step is workload validation—not assuming that a dense rack enclosure automatically delivers cloud-beating economics. The chassis may be compact; the proof still needs room.
  1. G2 Digital launches quad-GPU 2U server - develop3d develop3d 2026-11-10T10:23:25+00:00
  2. NVIDIA RTX PRO 6000 Blackwell Max-Q Workstation Edition nvidia.com
  3. 2U Q-Power Rackmount GPU Server for AI & Rendering g2digital.co.uk
