What was announced
Games.gg reports that GameSir announced the two editions in London on 16 November 2026, adding Miami-inspired designs to its controller range. PC Guide carries the same dateline. GameSir's own product page lists the pair as one product, with specifications, compatibility and pricing. That page appeared in search about 20 days ago, so the editions were visible on GameSir's site before the November press push. Treat the London date as the press-release date, not necessarily the first time the designs were shown.
Both editions are priced at $89.99/£99.99 on the GameSir website. The structured data on GameSir's page lists the $89.99 price in USD. On timing, XiaomiToday says both are scheduled to begin shipping in November 2026. PC Guide says they can be pre-ordered. I could not confirm a specific delivery date, so don't assume stock is already in hand.
What the designs look like
Basic Tutorials describes Sunset Boulevard as a multicolour gradient: cobalt blue sticks, sunset-orange ABXY buttons, a pink back panel and blue shoulder buttons. Ocean Breeze is more restrained, with solid pink, grey stick caps, pink ABXY buttons and pink grips.
Several outlets note the GTA 6 resemblance. iTechGuides states plainly that they are not official GTA 6 controllers and have no Rockstar licensing. The "officially licensed" label in GameSir's materials refers to Xbox licensing, not to any game.
The platform detail buyers should check
"Tri-mode" is easy to misread. According to the source material:
- Xbox: wired only. The controllers are officially licensed wired Xbox controllers, described as tri-mode for PC.
- PC: wired or 2.4GHz wireless. The games.gg specification list gives polling of up to 1,000Hz on PC over both connections.
- Android: Bluetooth.
- PlayStation: not supported. Newsy Today says they support Xbox consoles, PC and Android, but not PlayStation.
So the wireless modes are for PC and Android, not for an Xbox console. Someone buying one for a Series X|S should plan on a cable. GameSir's support documentation reportedly lists Windows 10 and 11, but I could not retrieve that page, so verify it before buying if your setup is unusual.
The 1,000Hz figure is a manufacturer maximum. It does not mean every game or system will register 1,000Hz in practice, and I have seen no independent latency testing.
Hardware carried over from the G7 Pro
Both editions keep the G7 Pro's Mag-Res TMR sticks, dual-mode triggers, four extra remappable buttons and four vibration motors. The games.gg specification list adds:
- Hall Effect analogue triggers with micro-switch trigger stops, switchable between analogue and hair-trigger behaviour.
- Optical micro-switch ABXY buttons and a mechanical micro-switch D-pad.
- Two mini bumpers and two rear buttons as the extra programmable inputs.
- Six-axis motion control, with mapping on PC only.
- A 1,200mAh battery, swappable faceplate, stick caps and D-pad, and a charging dock with neon styling.
GameSir Nexus software lets players remap buttons, set stick dead zones and tune response curves. That software handles the PC-side tuning, and iTechGuides notes the Nexus settings apply to the hardware regardless of which edition you choose.
GameSir's page shows a 4096 joystick resolution figure. That is a spec-sheet number. Likewise, "anti-drift" and "tournament-ready" are marketing claims, not test results. TMR sensing is generally pitched as a durable alternative to potentiometer sticks, but this is a general industry point, and long-term durability of these units is unproven.
Weight discrepancy
Games.gg lists a net weight of 272g. The product evidence I was given reported that GameSir's generic support manual says 392g. That is a large gap between two GameSir documents, and I could not retrieve either page to settle it. If weight matters to you, confirm it with GameSir before ordering.
Bottom line
- The editions are visual variants priced at $89.99 (£99.99 per the press release), and the hardware is the existing G7 Pro.
- On PC you get wired or 2.4GHz wireless at up to 1,000Hz, tuned through Nexus.
- On Xbox you are plugged in.
- There is no independent review yet, so treat the performance claims as unverified until one appears.
- GameSir Reveals G7 Pro Sunset Boulevard and Ocean Breeze Editions - games.gg games.gg · 2026-11-17T11:53:42.968000+00:00
- G7 Pro Sunset Boulevard & Ocean Breeze Edition gamesir.com
- GameSir G7 Pro GTA VI-Inspired Controllers Launch for $89.99 - XiaomiToday xiaomitoday.com
