What BGR's piece says
BGR's central point is that safety depends on placement. It relays Reddit warnings against putting anything but very light stickers on fan blades. One commenter wrote that "Usually putting weight on fan blades is a bad idea," and warned that a small imbalance at high RPM can be bad news for the bearings.
BGR also reports that some users consider a backplate less risky, provided the adhesive won't melt. It adds that figurines are generally lower risk, as long as they don't weigh the card down or block airflow completely. It points to vinyl decals as an alternative. It says some vinyl tolerates up to about 200°F, while GPUs typically run at roughly 140–185°F.
Two things to keep in mind:
- The imbalance claim is user opinion. It is plausible engineering folk wisdom, but nothing in the reporting is a controlled test of sticker weight on fan balance or bearing life.
- The backplate and adhesive advice is also anecdotal. No source gives backplate surface temperatures or a tested "safe" sticker.
The experiment behind the figurine claim
The figurine claim comes from PC Gamer's Jess Kinghorn. She added figures to an iBuyPower RDY Y40 Valorant VCTA R003 with an RTX 4070 Super. The test ran FurMark 2 at the 1080p and 1440p presets after each addition. Ambient temperature was about 34°C (93.2°F) that day.
The baseline was 83°C under a 100% GPU load, with 195 fps at 1080p and 132 fps at 1440p.
With all 20 figures inside, VideoCardz summarized the result this way: the card reached 84°C, 1080p dropped from 195 to 192 fps, and 1440p was unchanged. The intermediate 1080p numbers (194, 195, 198, 194, 194) wobble around the baseline. The best 1080p result, 198 fps, came at eight figures. That points to run-to-run noise rather than figurines improving performance.
| Figures | 1080p avg fps | 1440p avg fps |
| 0 | 195 | 132 |
| 1 | 194 | 132 |
| 4 | 195 | 131 |
| 8 | 198 | 130 |
| 11 | 194 | 132 |
| 15 | 194 | 132 |
| 20 | 192 | 132 |
What the test does not show
- It tested figures inside a case. It did not test stickers on fan blades or backplates, or figurines sitting directly on a card.
- It was one system. The setup was one pre-built PC, one GPU and one case. The result isn't a universal safe number of figures.
- It was short. The FurMark runs were brief, so hours of gaming may behave differently, and Kinghorn says as much.
- It still found a hazard. Space, not runaway temperatures, ended the experiment. According to VGTimes' summary, plastic brushed a spinning fan and made noise, so the test had to stop and the figures were rearranged.
The practical lesson is that the main physical risk is contact and obstruction, not a figurine quietly cooking your GPU.
Manufacturer guidance on fans and airflow
ASUS ROG's support guide says that dust, hair or other debris in the vents or fan can cause overheating, performance drops and loud fans. That is the guide's own wording for blocked airflow, and it applies equally to a decoration parked in front of a vent. Its checklist says to inspect every GPU fan to ensure it isn't blocked by cables or other components. It also advises leaving sufficient space around the case and its ventilation openings.
MSI also publishes guidance on checking for foreign objects in a card's fan and stopping use if blades are damaged. It also lists foreign objects on a PCB and broken fan blades as possible customer-induced damage that could affect warranty coverage. That is a reason to check your own card's warranty terms before gluing anything to the cooler. Assessment is made by the service center, so don't assume any particular outcome.
A practical placement guide
- Keep every fan clear. Nothing should touch, or be able to reach, a spinning blade. Check by hand with the PC off, then watch the first spin-up with the panel open, as the PC Gamer test suggests.
- Leave vents and intakes open. Don't cover the card's exhaust openings, the case's intake path or the heatsink fins.
- Prefer stationary surfaces. A backplate or shroud is a more sensible sticker location than a rotating fan. Use material whose manufacturer specifies a temperature rating above your card's operating range. Vinyl, not paper, is the safer bet.
- Don't load the card. A figurine resting on a GPU adds weight to the PCIe slot and the bracket. Use a stand or place it elsewhere.
- Mind the figurine, too. VGTimes notes that most figures are PVC, which softens before it melts, and GPUs under load can hit 80–85°C. That is general material knowledge, not a result from the PC Gamer test, but a figure placed in the exhaust path is the one most likely to warp.
- Secure the loose bits. Anything that can shift when you move the case can end up in a fan.
- Skip anything that makes service hard. Avoid covering screws, labels or warranty seals.
Bottom line
The reassuring finding is narrow. In one short test, a case full of figures barely moved temperatures or frame rates. The caution is broader: stickers on fan blades rest on community advice rather than testing, and the one hazard the experiment did hit was a figure touching a fan. If you decorate, keep the moving parts and the airflow path clear, and put the personality on the parts that sit still.
- Is It Safe To Put Stickers And Figurines On Your GPU? bgr.com · 2026-10-11T16:47:00+00:00
- PC Gamer packs 20 figures into a PC and measures a 1°C GPU temperature increase - VideoCardz.com videocardz.com
- Hatsune Miku Doesn't Get in the Way of Gaming: PC Gamer Tested How 20 Anime Figures Inside a Case Affect FPS and Temperature vgtimes.com
