A person analyzes data on multiple computer screens in a dark room, likely working on cybersecurity or network monitoring.
The energy sector is a foundational pillar of global infrastructure, and the security of its operational technologies has become a matter of national and economic resiliency. In this context, a recently disclosed vulnerability in Hitachi Energy’s Modular Switchgear Monitoring (MSM) system demands careful scrutiny, not only for its technical specifics but also for the broader implications on industrial control system (ICS) cybersecurity. This analysis unpacks the issue as documented in international advisories, explores the underlying technicalities, and offers critical insights into mitigation, risk, and the future of cyber defense within the power industry.
Understanding the Hitachi Energy MSM Vulnerability​
A new security advisory from Hitachi Energy and confirmed by the U.S. Cybersecurity & Infrastructure Security Agency (CISA) highlights a cross-site scripting (XSS) vulnerability (CVE-2020-11022) affecting the MSM product line, specifically versions 2.2.9 and prior. The flaw is rooted in the improper neutralization of input during web page generation—a prototypical XSS scenario. The underlying technological trigger is the use (and mishandling) of jQuery versions greater than or equal to 1.2 but before 3.5.0, where trusted and untrusted HTML manipulation leaves the door open for attacker-controlled JavaScript payloads.
The Core Exposure and Its Impact​
The CVSS v4 base score calculated for this vulnerability is 5.3 (and 6.1 under CVSS v3.1), positioning it as a moderate risk. Nevertheless, the potential for remotely exploitable attack chains—especially given the low attack complexity required—transforms this from a mere technical bug to a salient risk for anyone deploying MSM units in critical energy networks.
Should an attacker succeed, they could execute unauthorized code with the privileges of the web interface, possibly enabling privilege escalation or lateral movement across the ICS environment. The theoretical impact includes unauthorized manipulation of equipment states, interference with monitoring, or the disruption of essential energy services.
The energy sector’s heavy dependence on connected operational technology (OT) amplifies the significance of even moderate vulnerabilities. Unlike IT systems, the window for patching and mitigation in industrial environments is often limited by uptime requirements, regulatory compliance, and operational risk.
Technical Anatomy of the XSS Flaw​
The vulnerability arises from the incorrect handling of HTML input in UI construction. In the affected jQuery versions, methods like .html and .append can execute embedded scripts even after input passes through simplistic filtering or sanitization steps. This is a well-known issue that has persisted due to the high legacy burden and widespread use of JavaScript libraries in embedded systems.
Attackers exploit the flaw by providing specially crafted input—potentially even via simple GET or POST requests—that injects their own code into web interface pages. For attack scenarios where social engineering or user deception is viable (such as convincing an operator to click a link), the interface can, in turn, execute the malicious code.
CVE-2020-11022 is well-documented and includes detailed references in the MITRE CWE-79 database and in the official CVE record.
Affected Products and Global Reach​
The scope of exposure is not trivial. Hitachi Energy’s MSM is deployed worldwide and underpins critical monitoring for high-voltage switchgear—the electrical backbone for substations, transmission lines, and distribution points. The company's headquarters are in Switzerland, but its solutions have a reach across all continents, particularly in regions with advanced grid modernization initiatives.
The vulnerability applies to MSM firmware and software versions 2.2.9 and prior. Given the often-lengthy lifecycle of operational technology, it is likely that many installations have not yet been upgraded or patched, leaving a considerable attack surface.
Responsible Disclosure and Remediation​
The vulnerability was reported by Hitachi Energy’s own Product Security Incident Response Team (PSIRT) and shared with CISA, reflecting good practice in vulnerability stewardship.
In terms of remediation, Hitachi Energy recommends that users apply the latest general mitigation factors and workarounds outlined in PSIRT advisory 8DBD000219. At present, a direct patch to eliminate the vulnerable library from the MSM web interface has not been confirmed as available for all end-users, so compensatory controls remain a necessity.
Mitigation and Workarounds​
CISA, in line with industry best practice, prescribes the following primarily network-level defense mechanisms:
  • Network Segmentation: Minimize or eliminate the exposure of all control system devices to the open internet. Control systems should be physically and logically separated from business and external networks wherever possible.
  • Firewall Deployment: ICS and remote devices should reside behind rigorously configured firewalls, restricting access only to necessary communications and trusted endpoints.
  • Secure Remote Access: If remote access is essential, organizations are urged to use up-to-date Virtual Private Networks (VPNs) or comparable hardened tunnels, recognizing that these come with their own maintenance and monitoring demands.
  • Risk Assessments: All defensive modifications need to be preceded by robust impact analysis and risk assessments to avoid unintended operational side effects.
CISA also routes system owners toward comprehensive resources on ICS security, including in-depth defense-in-depth strategies and targeted cyber intrusion detection.
Critical Analysis: Strengths and Weaknesses​
Proactive Vendor Response​
A notable strength is that Hitachi Energy’s PSIRT detected and reported the vulnerability proactively, demonstrating both technical vigilance and a strong commitment to responsible disclosure. Early notification and coordinated advisories reduce the lag time between vulnerability identification and customer response—a critical metric in ICS security.
Transparent, Multijurisdictional Reporting​
The engagement with CISA and publication of advisories through highly visible channels ensure that even operators outside the company’s immediate customer base are alerted. Cross-reference with CISA advisories confirms that this issue has been flagged by several relevant sources and is not limited to niche security circles.
Clear Technical Context and References​
By explicitly linking the flaw to a widely known and previously published vulnerability (CVE-2020-11022), the vendor and advisory authors make it easier for asset owners, integrators, and third-party security teams to rapidly absorb the base risk and seek out specific mitigation documentation. The use of CVSS v4 and v3.1 base scores ensures risk quantification is both current and compatible with varied assessment frameworks.
Ongoing Risk: The Legacy OT Challenge​
Despite these best efforts, addressing vulnerabilities in the critical energy sector is fraught with persistent challenges:
  • Legacy System Ubiquity: The prevalence of older MSM units and the standard lengthy replacement lifecycle in industrial facilities means the vulnerable configurations will persist for some time.
  • Operational Downtime Aversion: System owners are naturally cautious about rolling out patches or updates that necessitate a restart or have not been exhaustively tested for incompatibilities with adjacent systems.
  • Potential for Misconfiguration: Even where network segmentation or VPNs are present, errors in configuration leave gaps; the technical skillset in some operational environments is often heavily weighted toward electrical rather than IP security expertise.
Broader Consequences for Industrial Cybersecurity​
The vulnerability typifies the larger set of issues facing the sector: software components, such as JavaScript libraries, are rarely designed with ICS contexts in mind, and updates or security patches for these libraries lag far behind consumer and enterprise IT deployments. The relatively benign CVSS score understates the potential impact in high-consequence environments.
Furthermore, the rise of adversaries targeting energy providers for geopolitical or criminal purposes multiplies the real-world risk of even moderate vulnerabilities. While no known instances of exploitation associated with this XSS flaw have yet been reported to CISA, the absence of evidence is not an assurance of safety—particularly in the world of persistent threats and zero-day attacks.
Recommendations and the Path Forward​
For Asset Owners​
  • Inventory and Prioritization: Conduct a thorough inventory of deployed MSM units and assess security posture on all relevant endpoints.
  • Apply Workarounds: Follow the detailed steps outlined in Hitachi Energy’s advisory 8DBD000219. Where possible, limit web interface access to trusted operator terminals on secured, isolated networks.
  • Continuous Monitoring: Implement logging and cyber intrusion detection on ICS networks. Look for anomalous web traffic that could indicate exploitation attempts or reconnaissance.
For the IT/OT Security Community​
  • Advocate for Firmware Upgrades: Press for regular firmware auditing and the expeditious release and deployment of patched versions, including direct removal of legacy jQuery libraries.
  • Ongoing Education: Expand operator and engineer training to include cybersecurity fundamentals, particularly around the risks associated with web interfaces and insecure remote access.
  • Engagement with National CERTs: Foster closer ties with national and industry-specific Computer Emergency Response Teams (CERTs) to ensure prompt sharing of intelligence and incident data.
For Vendors and Developers​
  • Adopt Secure Development Lifecycle (SDL) Practices: Critically review the inclusion of third-party libraries and components, and embed regular security patch integration into core release timelines.
  • Minimize Attack Surface: Re-evaluate the necessity of fully featured web interfaces, especially those powered by general-purpose JavaScript frameworks, in security-critical OT systems.
Conclusion: A Call for Security-By-Design in Energy Systems​
The disclosure of this XSS vulnerability in Hitachi Energy’s MSM is a timely reminder that securing the digital interfaces underpinning modern utilities is an ongoing battle. While the industry has made significant strides toward layered defense, the complexity and interconnectedness of modern grids ensure that even moderate vulnerabilities like CVE-2020-11022 represent more than theoretical risk.
Operators, vendors, and policy makers need to treat the web interface—not just the hardware—as a high-value threat vector in any risk assessment or defense planning. The lessons from this episode should fuel further collaboration across the energy sector and with dedicated cybersecurity authorities such as CISA to defend not only against today’s threats, but those certain to emerge as the energy transition continues.
In the end, resilience in the energy sector is not a static achievement but a continuous process, anchored in transparency, proactive defense, and a relentless focus on basic cyber hygiene reinforced by agile vulnerability response. Whether today’s risks originate from legacy code, third-party components, or human error, only a holistic, partnership-driven approach can ensure a secure, reliable, and sustainable energy future.
  1. Hitachi Energy MSM | CISA CISA
