A neon-styled Node.js server architecture diagram showing security, PM2 processes, monitoring, deployment, and analytics.
Hostinger’s updated Node.js deployment guide gets the broad sequence right—prepare the app, install Node.js, keep it alive with PM2, put NGINX in front of it, and enable TLS—but its VPS recipe still leaves out the settings that determine whether a deployment remains reproducible and behaves correctly behind HTTPS. For administrators deploying Express or similar Node.js services on Ubuntu, the workable baseline is a pinned runtime, a locked dependency install, persistent service-level configuration, proxy-aware application settings, and a deployment path that can fail safely.
The tutorial, revised August 8, presents two routes: Hostinger’s managed Node.js Web App hosting or a self-managed VPS. The managed route may be appropriate for a small application where the provider’s build and restart behavior is acceptable. A VPS remains the right choice where an IT team needs OS access, custom services, its own monitoring agent, firewall policy, private networking, or a predictable release process.
The important distinction is operational responsibility. Connecting GitHub to a hosting dashboard can deploy code, but it does not prove that the same dependencies, runtime version, secrets, migrations, health checks, and rollback path will behave consistently on the next release.
Production installs need a lockfile, not npm install​
Hostinger tells readers to run npm install after cloning a repository to the VPS. That command is convenient for development, but it is a weak default for a production release. npm’s own documentation identifies npm ci as the command intended for automated environments and deployments: it requires a committed package-lock.json, removes any existing node_modules directory, refuses to proceed if the manifest and lockfile disagree, and does not rewrite either file.
That difference prevents a familiar failure mode: a server installs a newer package version that still satisfies a permissive range in package.json, while the developer’s working machine continues using an older tree. A dependency expressed as "express": "^4.21.0" is not a record of the exact package set that was tested. The lockfile is.
A deployment-ready repository should therefore include all of the following:
  • package.json should declare a real start script and place runtime packages under dependencies, not devDependencies.
  • package-lock.json should be committed and reviewed whenever dependencies change.
  • A production release should run npm ci --omit=dev, except where the application’s build process genuinely needs development tooling on the target host.
  • The build, test, and database-migration stages should occur before traffic is switched to the new process.
The last point is where dashboard-driven deployments commonly disappoint. If a platform runs a build and immediately replaces the serving process, a failed build is visible; a successful build with a broken migration or missing secret may only become visible after users begin receiving errors. A health endpoint that only returns a static 200 OK does not catch that class of failure.
“Latest LTS” is not a deployment version​
The guide recommends NVM and nvm install --lts, which is sensible for interactive setup. It is not enough for a release definition. As of August 9, 2026, the Node.js project lists Node.js 24.18.0 as the latest LTS release and Node.js 26.5.0 as the latest Current release; Node.js 26 is not scheduled to become LTS until October 2026. Production services should be on a supported LTS or Maintenance LTS line, rather than an unpinned moving target.
The practical problem with nvm install --lts is that the same command can install a different major or patch line next month. That may be desirable during a planned upgrade, but it is not a substitute for one. Native modules, framework support policies, OpenSSL changes, and altered defaults can turn a routine rebuild into an outage.
Set the runtime policy in the repository and enforce it on the host. For example, use the engines field in package.json to define an approved range, retain the exact installed version in deployment records, and make the service execute Node from a known path. A team can choose Node 24 LTS today and schedule Node 26 validation separately; it should not silently receive Node 26 because a server was rebuilt.
NVM adds another operational wrinkle that Hostinger only partly acknowledges. PM2’s startup mechanism generates a systemd command that includes the active Node binary path. PM2’s own documentation warns that changing Node versions requires regenerating that startup configuration. An administrator who upgrades Node under NVM but does not refresh the generated service can find that the application starts under the old runtime—or fails to start after a reboot.
Shell exports disappear when systemd takes over​
The VPS walkthrough uses:
export NODE_ENV=production
export PORT=3000
Those variables apply to the current shell. They are not a durable production configuration. A process started manually from that terminal may work, while the same application started later by PM2’s systemd integration does not inherit the variables. That is exactly the kind of discrepancy that produces a successful test immediately after installation and a broken service after the first reboot.
Express documentation recommends setting production variables through the operating system’s init system rather than relying on an interactive shell. PM2 can also carry environment values in an ecosystem file, which is a better fit than scattering export commands through an operator’s shell history.
A minimal ecosystem.config.cjs makes the process definition reviewable:
module.exports = {
  apps: [{
    script: "./app.js",
    cwd: "/var/www/node-app",
    instances: 1,
    exec_mode: "fork",
    env: {
      NODE_ENV: "production",
      PORT: 3000
    max_memory_restart: "500M"
Secrets should still not be committed to that file. Put database passwords, OAuth client secrets, signing keys, and API tokens in a root-readable systemd environment file, the hosting platform’s encrypted variables store, or a dedicated secrets-management service. Ensure the application account—not root—owns the working directory and can read only the secrets it needs.
PM2 remains a reasonable process supervisor, but it is not magic availability. Run pm2 startup, execute the exact privileged command PM2 prints, then run pm2 save. Test the result with an actual reboot before declaring the deployment complete. PM2’s reload can provide a rolling replacement in cluster mode, but only if the application can shut down cleanly and does not keep sessions, WebSocket state, or jobs solely in process memory.
The supplied NGINX block omits the headers applications use​
Hostinger’s NGINX configuration forwards the host header and includes WebSocket upgrade headers. It does not forward the original client address or the original request scheme. That omission is easy to miss because a simple Express “Hello World” page will load normally.
Behind TLS-terminating NGINX, an application needs to know that the original browser request was HTTPS. It also often needs the real client IP for audit logging, rate limiting, abuse controls, and geographic or security policy. NGINX’s documentation provides X-Real-IP and X-Forwarded-For patterns; Express’s proxy guidance requires the application to trust only the proxy topology it actually controls.
A more complete local reverse-proxy block is:
location / {
    proxy_pass [url]http://127.0.0.1:3000[/url]
    proxy_http_version 1.1;
    proxy_set_header Host $host;
    proxy_set_header X-Real-IP $remote_addr;
    proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
    proxy_set_header X-Forwarded-Proto $scheme;
    proxy_set_header Upgrade $http_upgrade;
    proxy_set_header Connection "upgrade";
For an Express application reached only through that local NGINX instance, configure the proxy trust explicitly—for example, app.set('trust proxy', 'loopback')—rather than blindly trusting all forwarded headers. A broad true setting is dangerous when the application can also be reached through another route, because a client may be able to spoof the headers the app treats as authoritative.
This is more than a logging nicety. Without the scheme header and correct Express trust setting, code that sets secure session cookies may conclude the request is plain HTTP and decline to set them. Authentication failures that appear only in production frequently trace back to that proxy boundary.
Health checks must test readiness, not merely process survival​
The tutorial suggests checking a /health response and using pm2 logs or pm2 monit. Those are necessary operator checks, but the proposed resource figures—under 50 ms event-loop latency, roughly 300–500 MB of memory for a “standard Express app,” and CPU below 70 percent—are not useful universal health thresholds. A small API may correctly use far less memory; an image-processing or reporting service may need more. Memory growth, error rate, queue depth, database latency, and p95 or p99 request latency are meaningful only against that application’s own established behavior and host limits.
Express’s own production guidance draws a useful line between liveness and readiness. A process can be alive while its database pool is exhausted, its migrations are incomplete, its required upstream API is unavailable, or its cache is disconnected. A readiness endpoint should verify the dependencies required to accept new traffic, while a liveness endpoint should remain simple enough to tell the supervisor when a process is irrecoverably stuck.
Deployments also need graceful shutdown handling. PM2 or systemd sends a termination signal when replacing a process; the application should stop accepting new connections, finish in-flight requests within a bounded timeout, close database and queue connections, and then exit. Restarting a process without that behavior turns every rollout into a small, unpredictable packet of dropped requests.
Finally, Certbot cannot turn an IP address into the domain validation path most teams expect. Let’s Encrypt’s HTTP-01 challenge validates control through port 80 for the requested name, so public DNS must point to the server and both firewall and upstream network policy must permit HTTP during issuance and renewal. The correct post-deployment check is therefore not just a browser padlock: confirm external DNS resolution, test the HTTP-to-HTTPS redirect, inspect certificate renewal, and verify the application’s real authentication and write paths through the public hostname.
A Node.js service is deployed when it survives the second release and the first reboot with the same runtime, dependencies, configuration, traffic behavior, and observability as the first. The PM2-plus-NGINX pattern can achieve that on a VPS, but only after the shell commands in a basic tutorial are turned into a defined, repeatable release system.
Hostinger’s updated Node.js deployment guide lays out the familiar path from a local Express application to a public service: commit code, install Node.js, keep the process alive with PM2, put NGINX in front of it, and add HTTPS. That sequence is sound, but the production-ready version needs two corrections before an administrator copies its commands into a VPS: deployment should install a locked dependency set, and the supplied NGINX block does not actually preserve the client and protocol information the guide says it preserves.
The August 8 tutorial by Hostinger’s Ariffud M. also makes a useful distinction between its managed Node.js Web App hosting and a VPS. The managed product is intended to connect a GitHub repository, identify the framework and runtime, build the project, hold environment variables, and redeploy after repository changes. A VPS leaves those responsibilities with the operator. The practical dividing line is not whether the application is “serious” enough for a VPS; it is whether the team needs OS-level control, custom services, unusual networking, or a deployment process it can audit and reproduce outside a provider dashboard.
For most small Node.js services, the safest deployment is boring: use a supported LTS runtime, build the exact commit you tested, bind Node only to loopback, terminate TLS at a reverse proxy, and make process recovery and certificate renewal observable rather than assumed.
Secure web application architecture diagram showing Nginx, Node.js, Express, PM2, monitoring, and deployment.Build the Same Dependency Tree You Tested​
A package.json file and npm install are enough to make a tutorial application start, but they are not a complete production deployment contract. package.json describes permitted version ranges; a dependency such as express: "^4.21.0" can resolve to a newer compatible release at a later install. The package-lock.json file records the dependency tree actually resolved during testing.
npm’s own documentation identifies npm ci as the command designed for automated and deployment environments. It requires a lock file, fails if that lock file does not agree with package.json, removes any existing node_modules, and does not rewrite the lock. That failure mode is useful: a deployment should stop when its artifact is ambiguous, not quietly select a different package version.
For a conventional service, the release path should look more like this:
git fetch --tags origin
git checkout --detach <tested-commit>
npm ci
npm run build
If the application has a build step that needs development tooling, do not remove development dependencies until that step has completed. For applications that run directly from source and do not require build-time tooling in production, npm ci --omit=dev can reduce the installed package surface. The correct choice depends on the project; blindly omitting development dependencies breaks many TypeScript, bundler, ORM-generation, and frontend build workflows.
The Node.js version must be locked as deliberately as dependencies. Hostinger’s guide recommends nvm install --lts, which is sensible for setting up a server initially, but it also means the selected major version can move over time. As of August 9, 2026, Node.js lists Node 24 “Krypton” as an LTS line and Node 26 as the Current release; its project guidance says production applications should use Active LTS or Maintenance LTS releases. Put the intended major, and preferably the exact tested version, in the project’s engines field, deployment configuration, or an .nvmrc file.
The guide’s pinned NVM installer command is also already behind the project’s published installer version. That is a small maintenance issue rather than a deployment failure, but it illustrates the larger rule: installation snippets age. Treat bootstrap commands as versioned operational code, review them periodically, and never mistake a one-time setup command for a permanent server policy.
Managed Hosting Removes Server Work, Not Release Responsibility​
Hostinger says its Node.js Web App hosting manages the underlying runtime, process handling, SSL certificates, Git connection, and automatic redeployment. That can eliminate a substantial amount of routine operations work, particularly for a single web service that does not need custom daemons, private network routes, or host-level observability agents.
It does not remove the need for a release discipline. A Git push is not automatically a safe deployment simply because a hosting panel can build it. The repository branch connected to production should be protected; tests should pass before it is merged; secrets should live in the platform’s environment-variable store rather than in .env files committed to Git; and the deployment log should be part of the approval trail when something goes wrong.
Hostinger’s tutorial says one plan connects to one GitHub account and that all Node.js sites on that plan share that connection. That is a material operational constraint for agencies and teams running several clients or organizations from the same hosting account. The guide does not spell out branch-selection rules, rollback behavior, deployment concurrency, resource allocation by plan, or whether a failed health check automatically restores the previous release. Administrators should establish those answers in the control panel before treating automatic redeploys as continuous delivery.
A ZIP upload is even more limited. It may be suitable for a one-off demonstration, but it loses the commit-level audit trail and automatic rebuild path that make Git-backed deployments recoverable. If a release is not traceable to a commit SHA, reproducing an incident becomes guesswork.
The NGINX Example Needs Forwarded Headers​
The VPS instructions correctly put NGINX in front of Node.js and advise keeping the application on an internal port such as 3000. The process should not be exposed directly to the internet: allow inbound HTTP and HTTPS traffic to NGINX, but do not open port 3000 in UFW unless there is a specific, separately secured administrative need.
The provided NGINX block forwards the Host header and includes WebSocket-related upgrade headers. But the tutorial says these directives “preserve client information,” while its configuration omits X-Real-IP, X-Forwarded-For, and X-Forwarded-Proto. NGINX’s own proxy documentation shows these headers as the mechanism for passing the original request identity and scheme downstream.
That omission has real application consequences. An Express application behind NGINX will otherwise see the proxy as the remote client. IP-based rate limiting, audit logs, fraud detection, geolocation, and abuse controls can all record the wrong address. HTTPS-aware application logic can also think a request arrived over HTTP, which is a common source of broken secure-cookie behavior and incorrect redirects.
A baseline proxy location for an Express service should include the forwarded headers:
location / {
For WebSocket-heavy applications, operators should use NGINX’s conditional upgrade pattern rather than sending Connection: upgrade on every request. More importantly, the Node application must be configured to trust only the proxy layers it actually controls. Express documents that enabling proxy trust without a matching proxy architecture can allow clients to spoof forwarded values. For a single NGINX proxy on the same server, trust the loopback proxy explicitly rather than using a blanket setting without understanding the path requests take.
The other prerequisite is DNS. Certbot can issue and install an NGINX certificate only after the domain resolves to the server and the validation path is reachable. The Hostinger article notes that certificates cannot be issued for a bare IP address, but it does not emphasize the operational check that matters: confirm the HTTP site is reachable on port 80 before invoking Certbot, then test automated renewal with a dry run.
PM2 Is Recovery, Not a Deployment System​
PM2 is a reasonable process manager for a straightforward Node.js service. It runs the application as a daemon, records logs, can restart a crashed process, and can restore saved applications after a reboot. The tutorial’s pm2 start app.js --name "node-app", followed by pm2 startup and pm2 save, captures the basic flow.
There is a catch when Node.js comes from NVM. PM2’s documentation says pm2 startup prints a specific command to run, including the full Node binary path and target user. That generated command matters. A systemd service launched at boot does not automatically inherit an interactive shell’s NVM setup, and a server can otherwise come back online with PM2 unable to locate the intended Node runtime.
Run the deployment under a dedicated, non-root account. Hostinger’s example includes cloning as root, which works technically but makes application files, npm installs, PM2 state, and potentially exploitable web processes root-owned. That is an unnecessary privilege boundary failure. Keep /var/www ownership, the PM2 service user, and deployment credentials aligned to a non-root deployment account with only the access it needs.
PM2 also does not make a restart seamless by itself. A process can be “online” immediately after launch while database migrations are incomplete, a downstream API is unavailable, or the service is returning errors. A deployment should have a health endpoint that checks the minimum dependencies required to serve traffic, plus a separate readiness policy if the platform or load balancer supports one.
The tutorial’s suggested universal performance numbers — under 50 ms event-loop latency, 300–500 MB of memory, CPU below 70 percent, and p95 response time below 200 ms — should not be adopted as pass/fail thresholds. A small JSON API may use far less memory; a server-side rendering application, image-processing service, or application with a large ORM cache may legitimately use much more. Establish baselines from load tests and real traffic, then alert on deviations from the service’s own normal behavior and customer-facing objective.
Scaling Requires Stateless Application Design​
Hostinger accurately notes that a single Node.js process does not execute JavaScript request callbacks across all CPU cores. PM2 cluster mode can start multiple processes with pm2 start app.js -i max, and Node’s cluster facilities can share a listening port across worker processes.
What the guide leaves out is that each worker is a separate process. Node’s cluster documentation specifically warns against relying heavily on in-memory data for sessions and logins. If an application stores sessions, rate-limit counters, WebSocket routing state, or queued work inside one process, adding workers can produce intermittent logouts, inconsistent limits, or requests that land on the wrong instance.
Before turning on cluster mode, move shared state to an external service: a database, Redis-compatible store, durable queue, or another purpose-built system. CPU-heavy work should be moved out of request callbacks as well. Node’s own performance guidance explains that the event loop and worker pool can be blocked by expensive work; multiplying web workers does not repair a route that performs unbounded synchronous computation.
The immediate production checklist is therefore shorter than the tutorial’s broad survey suggests:
  • Pin a supported Node.js LTS version and deploy with npm ci from a committed lock file.
  • Run the service as a non-root account, bind it to loopback, and allow only NGINX to receive public web traffic.
  • Pass and correctly trust forwarded client and protocol headers at the reverse-proxy boundary.
  • Verify PM2’s boot service, certificate renewal, health endpoint, logs, and rollback procedure before sending production traffic to the new release.
A Node.js application is deployed when it can recover, be observed, and be reproduced—not when a browser first renders its home page.
