How-To Geek's Monica J. White argues that a pocket-sized travel router is the fix. It's a good fix. But "the only way" overstates it, and the router has limits worth knowing before you pack one.
What a captive portal is, and why it's a pain
A captive portal is a web page that a public network makes you view or interact with before it grants internet access. Hotels, airports and coffee shops use them. Windows, Apple, Google and Firefox each probe a known URL to spot a portal, so your device knows when to pop up a sign-in page.
Hotels vary in what the page asks for. It may just want you to accept terms, or it may want a room number and surname, along with other credentials. White's complaints are familiar:
- You may have to repeat the login on every device you bring.
- Streaming sticks, consoles and other gadgets without a proper browser can't complete the login at all.
- Some hotels cap the number of devices per room or force a new login when a session expires.
How Windows finds the portal
Windows has its own portal detection, which is useful when you troubleshoot. Microsoft's documentation says Windows opens the web browser as soon as it detects a captive portal. It also says Windows repeats its network tests until the portal lets the user connect.
The mechanism is the Network Connectivity Status Indicator (NCSI). On Windows 10 and later, Microsoft's troubleshooting page says NCSI resolves, then sends a plain HTTP request to its connecttest.txt file. The probe uses plain HTTP so the portal can redirect it.
That gives you a manual trick. The SANS Internet Storm Center notes that if you can't find a portal's sign-in page, opening one of those probe URLs in a browser may redirect you to it.
What a travel router does
A travel router joins the hotel Wi-Fi as a single client. It then broadcasts its own private network for your devices. In practice:
- You complete the hotel's login once, on the router.
- Your phone, laptop, console and streaming stick connect to the router's network, not the hotel's.
- Network Address Translation (NAT) means the hotel generally sees one device. White cautions that stricter hotels may still behave differently.
- You can reuse the same network name and password everywhere, so your devices reconnect on their own.
GL.iNet's documentation says the same thing about device caps. The hotel sees the router as one device, and you can connect several devices behind it up to the router's client limit. GL.iNet's repeater mode also runs in WISP mode by default, with its own subnet and a firewall between your devices and the public network.
TP-Link makes a similar claim for its TL-WR1502X. You authenticate once during Quick Setup, and your device IP and MAC addresses stay hidden from the public network.
Setup, step by step
Menus differ by brand, model and firmware, so treat these as the general shape of the process. They are not a universal script.
- Power the router on and connect a phone or laptop to its Wi-Fi. The default network name and password are usually printed on the router.
- Open its admin page in a browser. GL.iNet documents 192.168.8.1 as its default address. TP-Link's TL-WR1502X uses tplinkwifi.net or 192.168.0.1. Check your own model.
- Choose Repeater or Hotspot mode. On the TP-Link TL-WR1502X, set the physical mode switch to Hotspot before powering on.
- Pick the hotel's network from the scan list and enter a password if one is required.
- Open a browser on a device that is connected to the travel router. Complete the hotel's login page. On the TL-WR1502X, a pop-up button opens the portal login during setup.
- Connect everything else to the router's Wi-Fi.
Success means your devices have internet access without each one visiting the portal. If the router's admin page shows a connected-but-no-internet warning, the login is probably not finished.
When the login page won't appear
This is the most common failure, and the fixes are mostly free.
- Open a plain HTTP page. TP-Link says opening any website on a device behind the router should redirect you to the portal.
- Turn off VPN and custom DNS on the router. GL.iNet advises setting DNS to automatic. It also advises disabling DNS Rebinding Attack Protection, all VPN connections and AdGuard Home while you sign in.
- Toggle your phone's Wi-Fi and reconnect to the router. GL.iNet says the portal should then pop up after you enter the router's password.
- Use the router's login mode. GL.iNet firmware v4.6 and later has Auto-Enable Login Mode for Public Hotspots and a Camouflage option that emulates the MAC address of the device you use for the admin panel. Login Mode switches DNS to automatic and suspends some services. GL.iNet warns this may leak your network activity to the hotspot provider, so restore your privacy settings afterward.
- Try MAC cloning. Sign in on your phone, note the Wi-Fi address it uses for the hotel network, and set the router to use that address on its upstream connection. TP-Link puts this under Advanced > Network > Internet > Router MAC Address. GL.iNet puts it in the Repeater section under Modify, with MAC Mode set to Clone.
- Ask the front desk. Some hotels enforce strict verification. GL.iNet's last resort is asking staff to whitelist the router's factory MAC address. This is permission-based troubleshooting, not a way around access controls.
MAC cloning has pitfalls
Modern phones often use a randomized "Private Wi-Fi Address" for each network. GL.iNet notes the address shown may not match the hardware address. Use the address your phone actually presents to that hotel network. A reboot of the router may be needed afterward. If the phone and router both use the same MAC at the same time on one network, you can get conflicts. Disconnect the phone from the hotel network first, or just keep it on the router.
Where "the only way" falls short
The headline is catchy, but it isn't accurate.
- Direct login still works. On a single Windows laptop, Windows will usually open the portal for you, or you can visit the NCSI probe URL. A router isn't required for one device.
- It isn't a guaranteed bypass. Hotel session expiry, device limits and stricter authentication can still apply.
- It won't fix a weak connection. Your private network can't beat the hotel's upstream coverage, capacity or internet service. A travel router can't make a congested network fast.
- It isn't a security cure-all. A private network and NAT firewall help. Encrypting your traffic is a separate job. GL.iNet describes routing all connected devices through a VPN on the router as its own configuration. That VPN may need to be off during portal sign-in.
Also verify the network you join is the hotel's official one. Marriott's help page says its portal may ask for details such as room number or reservation surname. Even so, don't type payment details into an unfamiliar login page.
Is it worth packing one?
It makes sense in these situations:
- You travel with several devices.
- You carry gear that can't handle browser sign-in, such as streaming sticks and consoles.
- The hotel limits devices per room.
- You want a consistent Wi-Fi name and password on every trip.
For one laptop and one phone on a hotel with a simple click-through page, you probably don't need one. The router earns its place on crowded, fussy networks, and it weighs very little. Just keep expectations realistic. It trims the login chores. It doesn't repair the hotel's Wi-Fi.
- This is the only way to defeat hotels' annoying Wi-Fi login pages How-To Geek · 2026-11-02T12:30:15+00:00
- How to Connect a TP-Link Travel Router to a Captive Portal tp-link.com
- Captive Portal Detection and User Experience in Windows - Windows drivers learn.microsoft.com
