A gaming PC’s GPU and power supply are shown with airflow, temperature, connector, and maintenance indicators.
A PC power supply has no fixed expiry date. The "three to 12 years" figure that gets repeated is a rough guide at best. How long a unit lasts depends on its model, its build quality, how hot it runs and how hard it works.
BGR's recent explainer, by Shahmeer Shahzad, says a PSU usually lasts somewhere between three and 12 years. It splits PSUs into budget (three to five years), midrange (five to eight) and premium (up to 12). That is a handy mental model, but it is BGR's estimate and not a manufacturer-backed standard. Here is what the manufacturer and standards material says, and how to use it.
A gaming PC’s GPU and power supply are shown with airflow, temperature, connector, and maintenance indicators. Why there is no universal lifespan​
Seasonic's engineering guidance says plainly that no universal service life exists for consumer or industrial power supplies. It says the forecast has to be based on the specific model and its operating conditions. Seasonic notes that actual longevity depends mainly on how the components age, specifically the capacitors and the fan. The same material points to operating temperature, load and cooling as the main variables.
Seasonic is a PSU maker, so treat this as manufacturer guidance and not independent testing. It is still consistent with BGR's own emphasis on heat, capacitor quality, workload and dust.
Seasonic's separate component write-up goes further on capacitors:
  • Capacitors are often among the first parts to degrade under heat and constant load.
  • Real-world wear depends on temperature, load, component quality and circuit design.
  • Capacitors on the heavily loaded 12V side of the unit face more stress than those on the primary side.
  • Hot spots inside the unit can speed up aging even when the fan is quiet.
  • Capacitors are only one possible culprit. Fans, solder joints and switching components can also contribute.
Don't read MTBF as a lifespan​
Spec sheets often quote MTBF (mean time between failures), and it is easy to misread. Seasonic's example is a consumer unit rated at 100,000 hours at 25°C, with the fan excluded. Seasonic describes MTBF as a statistical measure of reliability and not a guaranteed service life for a specific unit. Dividing 100,000 hours by 8,760 hours in a year gives about 11 years. That arithmetic is tempting but wrong, because MTBF describes failure rates across a population under stated conditions. It does not predict one unit's lifespan.
Warranty length is a clue, not a promise​
BGR calls warranty length a highly accurate indicator of reliability. That overstates it. A long warranty does suggest a maker has some confidence in the design, but it is not a health check.
Seasonic's warranty policy shows how much terms vary, even within one brand:
  • 12 years for PRIME and VERTEX series.
  • 10 years for FOCUS PX/GX-class models, with 7 years for some other FOCUS lines.
  • 7 years for CORE GX and 5 years for CORE BC/GC.
  • 3 years for MagFlow.
The policy also says the warranty covers defects in materials and workmanship. It does not cover normal wear and tear, and Seasonic says it is not a guarantee of product lifespan or continued performance. Terms vary by region and model, so check the exact model's policy, your purchase date and your proof of purchase. These are one vendor's terms, not an industry-wide rule.
The other reason to replace a PSU: it no longer fits your PC​
A PSU can still work perfectly and be wrong for the system. BGR is right that this matters, and the main triggers are a new graphics card or a new platform. Intel's PSU guidance says to calculate your system's power needs and suggests erring on the side of more wattage. Intel's example is a 500-watt system, where a 600- or 650-watt PSU gives some overhead and room for future upgrades. That is an illustration, not a rule for every 500-watt PC.
Connectors matter as much as watts:
  • Per NZXT, ATX 3.1 is Intel's current revision of the desktop PSU design guide, and it specifies the 12V-2x6 connector, a 16-pin cable that can deliver up to 600 W to a single graphics card.
  • Intel's design guidance notes that the 12V-2x6 connector is not compatible with the 2x3 or 2x4 auxiliary power connectors. An older PSU may therefore need an adapter, or may simply be unsuited to a new card.
  • PCWorld's ATX 3.0 coverage reported that, with the higher "power excursion" requirements, a 1,200-watt PSU is recommended for a 600-watt GPU and 300-watt CPU. That is a worst-case figure for extreme builds, not a typical target.
Before a major GPU upgrade, check the card maker's power requirement, the PSU's continuous output and its available connectors. Also confirm the unit physically fits the case. Seasonic's own comparison shows how much length varies, with its PRIME TX at 210 mm and its VERTEX GX/PX at 160 mm.
A practical keep-or-replace checklist​
  1. Identify the unit. Note the exact model, wattage and purchase date from the label or your records. Don't open the PSU, because it can hold dangerous charge even when unplugged. Opening it can also void the warranty.
  2. Check the warranty. Look up that model's terms and region. Remember that warranty length is not a guarantee of how long the unit will last.
  3. Match it to your hardware. Compare your CPU and GPU requirements against the PSU's continuous rating and connectors, and leave some headroom. Seasonic's selection tips suggest a 20–30% reserve, which is a vendor recommendation.
  4. Look at conditions. Check that fans spin, vents are clear of dust and the case airflow is reasonable. Seasonic notes that frequently triggered overheating protection is a reason to check the system's load and cooling.
  5. Know the warning signs. Seasonic describes aging-related power problems as unstable booting, reboots under load or unusual noise. These are reasons to investigate, not proof the PSU is at fault. A bad RAM stick, a loose connector, an overheating CPU or a failing GPU can look the same.
  6. Stop using it if it's unsafe. If you see damage, smell burning, or hear abnormal repeated noise, power down and seek qualified help or a warranty replacement.
Where BGR's claims need care​
  • "Three to 12 years" is not a rule. Treat it as a rough estimate. A well-cooled, well-built unit may outlast it, and a stressed or poor-quality one may not reach it.
  • "Actively damage other parts." BGR says a weak PSU run near its limit can damage other components. That is too categorical. An undersized or defective unit can cause instability, and a failing unit can create risk. But Seasonic describes protection circuits as intended to limit dangerous conditions, though it doesn't claim every PSU protects equally well. Ordinary operation near rated output isn't automatically destructive.
  • "Blown capacitor or shorted transformer." These are plausible internal failures, but they are not something a home user can verify without opening the unit. A PC that won't power on has several possible causes, so test other components before you condemn the PSU.
  • 80 PLUS and lifespan. BGR argues that higher efficiency means less heat and so a longer life. Lower heat does help in principle. But Seasonic's guidance says 80 PLUS certification confirms efficiency and power-factor compliance under test conditions. It does not indicate ripple level or service life.
Bottom line​
Age alone is a poor reason to replace a working PSU, and a long warranty is no guarantee it will survive. Replace one that is unreliable or damaged. Also replace one that can no longer meet your hardware's wattage or connector needs. When you do, choose by the exact model's specs and the component makers' requirements, not by a lifespan number from a headline.
  1. How Long Does A Power Supply Last In Your PC? bgr.com 2026-11-17T17:17:00+00:00
  2. Industrial Power Supply vs Consumer Power Supply seasonic.com
  3. How to Choose Power Supply for PC: What to Know - Intel intel.com
