What the test measured
The EIA puts the average U.S. residential electricity rate at 18.31 cents per kWh for July 2026, and BGR used that rate.
The test machine was a five-year-old general-purpose desktop with 12 GB of RAM and a mid-range graphics card. Gloor used a P4460 Kill A Watt EZ plug-in meter. With the monitor off, the tower averaged close to 30 W at idle. With his budget monitor awake, the combined draw was about 40 W.
The article doesn't name the CPU or GPU model, the operating system, the power plan, how long the test ran, or what was running in the background. It doesn't include a laptop measurement. Treat the numbers as one person's observations, not a benchmark for all PCs.
Why "24/7" is misleading here
The headline sounds like continuous operation. The calculation is different. It assumes eight hours of normal daily use and then 16 idle hours a day for 30 days. The dollar figures cover only that idle time. They don't include the cost of the eight active hours.
The math
The formula is energy (kWh) = watts ÷ 1,000 × hours. At the national rate, the tower and tower-plus-monitor cases work out like this:
| Scenario | Power | Idle energy per month | Cost at 18.31¢/kWh |
| Tower only, 16 h/day idle | 30 W | 14.4 kWh | about $2.64 |
| Tower plus awake monitor, 16 h/day | 40 W | 19.2 kWh | about $3.52 |
| Tower only, 24 h/day idle (my calculation) | 30 W | 21.6 kWh | about $3.96 |
| Tower plus monitor, 24 h/day (my calculation) | 40 W | 28.8 kWh | about $5.28 |
The last two rows are my own arithmetic from BGR's wattages. They weren't measured.
One correction to the original wording. BGR says 30 W is "0.03 kWh". Strictly, 30 W is 0.03 kW, which is a rate of power use. It becomes kWh only after you multiply by hours. The final figures are right regardless.
How the cost changes
BGR's other findings are worth knowing, with different levels of evidence behind them.
- Background apps add little. In Gloor's test, Discord, Slack, a file server and a music player together added about one to two watts.
- Sleep makes the biggest difference. Sleeping the same PC instead of leaving it actively idle dropped its draw to around 2 W. Gloor puts that at a couple of dimes per month. Those are his measurements.
- Enthusiast rigs cost more. BGR cites Reddit watercooling-forum posts, not its own tests. They put common idle draw near 100 W, which BGR prices at almost $9 a month for 16 idle hours a day. Some reports reached 300 W, or nearly $30 a month. These are unverified anecdotes, so read them as illustrative.
- Heavy workloads change everything. Rendering or running a game server while you're away would cost far more than idling.
Why your rate matters
The EIA figure is an average, not your rate. The US average is a national mean that almost no household actually pays, according to one rate-tracking site's analysis of the same EIA data. In July 2026, Louisiana's average residential rate was 12.72 cents per kWh, while Hawaii's was 48.00 cents. The same 30 W idle PC costs roughly four times as much to leave on in Hawaii as in Louisiana.
Time-of-use plans can shift the answer too, because the price per kWh changes through the day.
Work out your own number
- Plug the PC into a wall-outlet power meter. A Kill A Watt-style meter is the kind BGR used.
- Put the PC in the state you care about: idle, asleep, or running a task.
- Let the meter run long enough to settle, and read either the watts or the accumulated kWh.
- For watts, multiply by hours per day, divide by 1,000, then multiply by 30 for monthly kWh.
- Multiply monthly kWh by the price per kWh on your utility bill.
- If you want the monitor included, measure it on the same meter, or add its separate reading.
Wall-outlet readings capture what the equipment actually draws, which is more reliable than adding up component spec sheets.
The takeaway
For a modest desktop, idling is cheap, and sleeping is cheaper still. Moving a 100 W or 300 W machine to sleep when you're away would save far more than trimming background apps. If you leave a PC on for remote access, downloads or a file server, a plug-in meter and your own utility rate will give you a better answer than any national average.
- How Much Would It Cost To Leave Your PC On 24/7? Idle Is Cheaper Than You Might Think bgr.com · 2026-11-01T20:17:00+00:00
- Electric Power Monthly - U.S. Energy Information Administration (EIA) eia.gov
- Iowa electricity prices, July 2026 · Power Bill Facts powerbillfacts.com
