Where to find it
According to the Reddit post as relayed by Neowin, the path is:
- Open Edge on your Xbox.
- Go to Settings > System and Performance > Performance.
- Look for "Reduce webpage size by blocking some content" and switch it on.
Menu names have varied between reports. A March 2025 MSPoweruser article placed the same option under a heading called "Optimize Performance" settings in Edge on Xbox. Menu labels may differ by build. Nothing in the available reporting says which consoles, Xbox OS versions, Edge versions or regions have the option. Check your own console instead of assuming you have it.
You may also be able to exempt individual sites. TechIssuesToday, reporting on the 2025 screenshot, said users can toggle this setting on or off globally, or access an "Exceptions" option to allow all content on specific sites. That is useful if a site breaks with blocking on. I couldn't confirm the exceptions menu in current builds.
How it works
The setting's description text, quoted by MSPoweruser, says the feature uses an open-source list of URLs and page elements. The URLs on the list are blocked from downloading content during page load. Listed page elements are removed as the page loads. The list is EasyList, which the EasyList project describes as the primary filter list that removes most adverts from international webpages, including unwanted frames, images and objects.
That explains why the feature is not a full ad blocker:
- It only acts on what the list matches. Anything the list doesn't cover still loads.
- The wording is about page size, not ads. Ad removal is a by-product.
- Xbox Edge has no extension support. MSPoweruser notes that, unlike the desktop browser, Microsoft Edge on Xbox is a simplified browser, designed for use with a controller and on a TV screen. A built-in list is the only option on the console.
The Reddit poster's setup and its limits
AppasPurpleTongue says they pair the setting with Strict tracking prevention, found under Privacy, Search and Services > Tracking Prevention. They report a big difference. That is one user's impression. It is not a controlled test, and the post doesn't measure page weight, load time or memory use. Microsoft hasn't presented the two settings as a pair either.
The poster also reported these limits:
- YouTube: pre-video ads still appeared, though ads during videos were blocked. Ad delivery on YouTube changes often, so treat this as one person's result.
- Pop-ups: some were blocked and some weren't, according to the poster's reply in the thread.
EasyList does cover pop-ups. Its GitHub project lists rules to prevent popups/popunders. Partial coverage is consistent with a list-based approach.
Not a new feature
This setting has been around for a while. Several earlier reports track it:
- November 2023: Pure Xbox reported that a random subset of Xbox Insiders could try an experimental Microsoft Edge feature to block embedded content that negatively impacts performance. The framing was performance. Its author said they sometimes had to restart the browser because it ran out of memory.
- Early 2025: MSPoweruser and TechIssuesToday described the EasyList-based option from a Reddit screenshot and called it a preview or test.
- November 2026: the new Reddit post shows the option is still there.
These reports show users seeing the option at several points. They don't show a formal launch. I found no current Microsoft support page confirming its status or availability. I also can't say whether the 2026 setting is the same implementation as the 2023 Insider test.
Is it worth turning on?
For casual browsing on a TV with a controller, probably yes, if you have the option. Heavy ad pages are a pain to move around with a gamepad. The Insider-era framing suggests the setting was aimed at stopping heavy embedded content from bogging down the console browser. I can't confirm any speed or memory gains, though.
Some practical notes:
- If a page looks broken or a video won't load, turn the setting off or add the site as an exception.
- Don't treat it as a privacy tool. Tracking prevention is a separate setting, and neither is a substitute for a full desktop extension.
- Sites that depend on ad revenue lose income when ads are blocked. That is the trade-off with any blocker.
If you can't find the option, your console or Edge build may not have it yet. It is still a handy console-side toggle, but it only goes so far.
- Microsoft Edge on Xbox has a hidden feature that makes web browsing much cleaner Neowin · 2026-11-16T18:16:01+00:00
- Microsoft tests Built-in Ad blocker for Edge on Xbox mspoweruser.com
- Microsoft Edge on Xbox is testing a built-in ad blocker techissuestoday.com
