The core idea: quiet without cooking your parts
The goal is less noise without losing cooling headroom. BGR notes that fans, airflow restrictions, component temperatures, fan speeds, placement and vibration all affect how loud a system sounds. This applies equally to gaming rigs, workstations and general-purpose machines. A quiet PC that throttles under load isn't a win.
Key 1: Fan placement, airflow and fan curves
BGR warns against assuming more fans means better cooling. Each extra fan is another noise source. Its advice is to use the fewest fans that keep components cool, at the lowest practical speed. It suggests three intakes and two exhausts, or three intakes and one exhaust. The author runs four fans in a darkFlash DK352 case and describes that setup as positive pressure.
Noctua's published airflow guidance adds some nuance:
- Baseline layout: Noctua recommends a baseline for most builds of five fans: three intakes at the front, plus one rear exhaust and one top exhaust.
- Fan count versus speed: Noctua also says more case fans let each fan run slower and deliver the same airflow at lower noise than fewer, faster fans. This partly cuts against a "fewer fans is always quieter" reading. The real trade-off is total fan count against the speed each fan needs to run.
- Direction of airflow: In a standard front-to-back layout, front fans are intakes and rear fans are exhaust. Noctua recommends front-to-back unless you are an experienced user with a specialised setup.
- Turbulence: Air streams that meet head-on should be avoided, because they hurt cooling and create audible noise.
Both sources agree on fan curves. Don't pin every fan at maximum. Use your motherboard's fan-control software or UEFI/BIOS to build a curve that ramps up gradually as temperatures rise. Then check temperatures under your own workloads before settling on a profile.
Takeaway: There's no single magic fan count. Keep the airflow path clear, point all fans in a consistent direction, and let the fan curve do the work.
Key 2: Quiet components and sensible power
Airflow can't hide a noisy part. BGR names four common culprits:
- CPU cooler: Air coolers are generally not loud, but noise varies by model, so check reviews before buying.
- Power supply: Look for a quiet fan and enough wattage for the build. BGR cites the Corsair RM850x as an example with a Zero-RPM fan mode that keeps the fan off at low or medium loads.
- Graphics card: Supported AMD and Nvidia cards can offer a similar fan-stop mode. This is model-dependent, so check your specific card.
- Storage: Swap a mechanical HDD for an SSD. HDDs have moving parts that make noise, and SSDs don't.
On fan size, BGR says a 140 mm fan at 1,500 RPM can move more air than a 120 mm fan at 2,000 RPM, but the larger one may be louder at full speed. Turning it down fixes that. Noctua's general principle is consistent: it recommends using the largest fan size that fits a slot, because larger blades move more air at lower speed, which means better cooling and less noise. Treat the BGR numbers as an illustration. Real noise depends on the specific fan model, so compare manufacturer acoustic specs rather than RPM alone.
Key 3: Vibration, rattles and maintenance
Fan vibration can travel into the case and rattle, especially when fans are mounted with standard screws. BGR's checklist:
- Fit anti-vibration mounts to isolate fans from the chassis.
- Tighten any loose screws on fans, brackets and case panels.
- Gently press on an outside panel. If the noise changes, the panel may be resonating.
- Be extra careful with tempered glass, which is vulnerable to impact, especially at the edges.
- Keep cables clear of fan blades.
- Clean dust filters and heatsinks regularly, since dust restricts airflow and makes fans work harder.
One more cause is worth knowing about, though it isn't in BGR's piece. Noctua's support guidance describes periodic humming when adjacent fans run at nearly identical speeds. It suggests a small speed offset between neighbouring fans, which you can set through your fan curves. Not every hum has this cause, so rule out loose mounts and panels first.
Key 4: Where you put the tower
Placement affects both cooling and how much noise reaches your ears. BGR's guidance:
- Give front intakes, rear exhaust and any top or bottom vents room to breathe.
- Avoid cramped cabinets, enclosed compartments and carpet.
- Use a stable surface to limit vibration into furniture.
- If it hums or rattles and the simple fixes don't help, move it off hollow desks and shelves.
- Under the desk is fine with adequate clearance, and the extra distance from your ears can make the noise less noticeable.
- If vibration is noticeable and persistent, have a qualified technician look at it.
A practical order of attack
- Clear dust and obstructions, and tidy cables.
- Identify the noise source: fan, PSU, GPU, HDD or a resonating panel.
- Tighten mounts and add anti-vibration hardware where needed.
- Lower fan curves gradually while watching CPU and GPU temperatures under a repeatable load.
- Upgrade the loudest part last, using model-specific reviews and acoustic specs.
A note on the source
BGR discloses that it may earn a commission from purchases made through links, and its article shows specific products. The advice is general, though, and the product mentions work as examples rather than endorsements. Its fan counts, pressure setup and RPM comparison are one builder's experience, not tested benchmarks. Noctua's guidance backs the broad principles but also shows that different layouts can be equally valid, depending on the case and hardware.
- 4 Keys To Building A Quiet PC bgr.com · 2026-11-07T00:47:00+00:00
- FAQ: Airflow guide part 2 - setup ideas noctua.at
- FAQ: Airflow guide part 1 - the fundamentals noctua.at
