A researcher compares handheld gaming consoles using FPS-per-watt charts and live performance data.
Every "Steam Deck vs ROG Ally vs Legion Go" showdown seems to end in a spec table or a single average-fps number. A new how-to from Shattered.io argues that neither tells you what matters on a handheld, which is how many watts the chip needs before extra power stops buying frames. The guide doesn't crown a winner. It describes a do-it-yourself TDP sweep, and its published numbers are synthetic.
That distinction matters, so here it is plainly. Every FPS and wattage figure in the guide's sample output comes from a generator script that produces three fictional devices (demo_a, demo_b and demo_c). None of it measures a real Steam Deck, ROG Ally or Legion Go. The only real hardware data it cites is Valve's published Steam Deck specs.
A researcher compares handheld gaming consoles using FPS-per-watt charts and live performance data. What the test actually measures​
The idea is to fix one game scene and the display settings, then step through six power limits per device. For each limit you record frame times and battery discharge, and you plot a curve. The guide calls the bend in that curve the "knee". It defines the knee as the lowest tested setting that reaches 90% of a device's peak average FPS in that scene.
The 90% figure is a judgment call, and the guide says so. Raise it to favor speed, or lower it to favor battery life. Per run, the tooling computes:
  • Average FPS.
  • Low-end FPS, taken from the 99th-percentile frame time.
  • The share of frames that take more than twice the median frame time.
  • Average battery watts.
  • FPS per watt.
Hardware facts worth knowing first​
Valve's tech specs page lists the Steam Deck OLED with a 6 nm AMD APU with a 4-15W power range. The same page lists a 7.4-inch HDR OLED display at up to 90Hz and a 50Whr battery with 3-12 hours of gameplay. Valve's runtime range is content-dependent, so it is not a promise for any particular game.
The guide also notes that the LCD Steam Deck uses a 7 nm APU. Valve's page confirms the OLED uses the 6 nm part. The practical rule is to keep LCD and OLED logs in separate folders. The same applies to any newer ROG Ally or Legion Go generation: label the exact model.
The vendor-app range also limits your sweep. If one device tops out at 15W and another at 30W, only compare at wattages every device honors. Don't test 35W on one machine just to match another.
Setting up the lab​
The analysis machine needs a recent Python 3, because the config loader uses tomllib. That module is built into Python 3.11 and later. It also needs pandas, numpy and matplotlib. The handhelds only run the logging script, which uses the standard library.
The proposed protocol:
  1. Run six evenly spaced TDP values, three repeats each, in shuffled order.
  2. Capture 120 seconds per run and trim the first 10 seconds.
  3. Cool down for about three minutes between runs.
  4. Run on battery only, because charging hides the discharge reading.
  5. Pin brightness, resolution and refresh rate, and turn off HDR, V-Sync, frame limiters and upscalers.
  6. Play the scene once beforehand to warm the shader cache.
  7. Record the model, firmware, driver and OS build next to the logs.
The guide estimates about two hours per handheld for one scene. These are protocol choices, not independently validated best practices, so treat them as sensible defaults.
Setting the limit on each platform​
  • Steam Deck: Use the performance panel's advanced view and the thermal power limit slider. Recheck after any suspend and resume.
  • ROG Ally: Use Armoury Crate's manual mode. Where short-burst limits are exposed, set them to the same value so boost can't lift the average. ASUS documentation indicates that a configured limit does not necessarily equal the power actually drawn.
  • Other handhelds: Look for a custom power mode with a wattage slider, and match any secondary limits.
A configured TDP is a control setting, not a measurement. Verify it by watching the logged watts rise when you raise the limit. If they don't, the limit isn't applying.
Capturing frame times​
On SteamOS, the guide uses MangoHud via Steam launch options. MangoHud's docs say logging requires a valid output folder, and Steam use is mangohud %command%. The sample configuration also relies on autostart_log, log_duration and log_interval. A Debian-packaged MangoHud config describes autostart as starting the log after X seconds, and log_duration as setting how long logging runs, in seconds.
A catch in the guide's own launch line. The guide's example adds no_display to hide the HUD. A MangoHud GitHub issue reports that no_display appears to disable data collection entirely instead of just hiding the overlay. That report was tested on MangoHud 0.8.1, so behavior may vary by version. If your log folder stays empty, remove no_display. You could also make the overlay transparent instead. A third-party MangoHud helper package suggests alpha=0.0,background_alpha=0.0 to hide the overlay without disabling the render loop. That is community guidance, not official documentation, so test it on your own setup.
On Windows, the guide uses PresentMon's console build from an elevated PowerShell. PresentMon's current console documentation lists --process_name, --timed and --terminate_after_timed, which match the guide's 2.x syntax. The guide notes that older 1.x builds use single-dash flags. It also says the frame-time column may be MsBetweenPresents or FrameTime, and the loader accepts either.
Reading the results​
The tooling reports the knee, the peak and the most efficient setting for each device and scene. The guide's advice for interpreting them:
  • Check the noise list first and re-run flagged settings.
  • Compare the knee with the best-efficiency setting. If they are within a few watts, use the knee. A much lower efficiency peak suggests a battery-saver profile for lighter games.
  • Check the low-percentile FPS at the knee. If the lows crater, move up one step.
  • If the knee lands on the highest tested value, extend the sweep. If it lands on the lowest, start lower.
  • Compare devices by knee and watts saved, not by peak FPS.
Where the method is fragile​
  • Battery watts are system watts. The logger reads the battery's discharge rate, which includes the screen, radios and everything else. FPS per watt here is a whole-device efficiency indicator, not chip efficiency. Different panels, refresh rates, operating systems and cooling all feed into it.
  • Sensor support varies. The Windows reading can come back as zero, and the guide suggests HWiNFO or a USB-C power meter as fallbacks. Cross-check software readings with a wall meter if you can.
  • Timestamps are critical. The analyzer pairs power samples to frame logs using each capture file's modified time. A drag-and-drop copy that resets timestamps turns every watts value into NaN. Use rsync -a, scp -p or robocopy.
  • 120 seconds isn't a session. A short capture can't show thermal throttling. The guide suggests one long capture at the knee setting, comparing the last five minutes with the first five.
  • The knee depends on your sweep. The observed peak is only the peak within the range you tested.
  • A dry run proves the pipeline, not the hardware. Run the synthetic generator first to confirm folder layout and analysis work. Its output says nothing about real handhelds.
Bottom line​
This isn't a benchmark result. It's a repeatable procedure for finding your own best per-game wattage on hardware you own. Done carefully, it replaces vague mode names like "Turbo" and "Performance" with measured curves. Watch the MangoHud no_display pitfall, preserve file timestamps, and keep the "battery watts, not chip watts" caveat in mind when you compare machines.
  1. Steam Deck vs ROG Ally vs Legion Go TDP Test (2026) - shattered.io shattered.io 2026-10-31T18:36:23+00:00
  2. Steam Deck :: Tech Specs steamdeck.com
  3. MangoHud configuration file browse.dgit.debian.org
