A gaming PC with a GeForce RTX graphics card sits beside a monitor showing graphics settings capped at 144 FPS.
A GPU that sounds like a leaf blower the moment you launch a big game is annoying. It isn't always a sign of failure, though. A guide from BGR this week covers the usual fixes for loud Nvidia cards. Some of its claims are solid. Others are shaky, and I've flagged those below.
A gaming PC with a GeForce RTX graphics card sits beside a monitor showing graphics settings capped at 144 FPS. First, work out which noise you're hearing​
"Loud GPU" covers at least three different problems. Each has a different fix, so it pays to sort them out before you touch any settings.
SymptomLikely causeWhat it tracks
Rising or fluctuating whooshFans responding to heatGPU temperature and the fan curve
High-pitched buzz or squealCoil whine from power-delivery componentsFrame rate and load
Grinding, clicking or persistent rattleMechanical problem such as a worn fan bearing or a loose partFan speed, and it often gets worse over time
Coil whine comes from inductors in the card's power circuitry vibrating as current flows through them. Coil whine usually comes from vibrating inductors in a GPU's power-delivery circuitry, and by itself it normally does not affect GPU performance or reliability. A comparison from one retailer's guide makes a useful point: fans respond mainly to temperature and fan curves, while coil whine can react almost immediately to workload changes.
That gives you a quick test. Cap your frame rate temporarily. If the electrical noise falls significantly as soon as FPS drops, coil whine from the GPU or its power circuitry becomes more likely. If the pitch doesn't change but the whoosh follows temperature, you're dealing with fan noise instead.
Step 1: Cap the frame rate​
BGR's best advice is also the cheapest. Menus, loading screens and lightweight scenes can run at hundreds of frames per second if nothing stops them. That makes the GPU work flat out for no visible benefit. A cap tells the card to stop.
Nvidia documents a driver-level option for this:
  1. Open the Nvidia Control Panel and go to Manage 3D Settings.
  2. Find Max Frame Rate. Nvidia's reference describes it as the maximum frame rate the GPU will render for a game or 3D application.
  3. Set it to On. Then move the slider to the maximum you want (20–1000 fps) and click OK.
  4. Use the Program Settings tab if you only want the cap on one game. Global Settings applies it everywhere.
The same page lists a Background Application Max Frame Rate control. It limits a game or 3D app running in the background, which helps reduce power consumption or fan noise. The documented range is 20–200. It's handy if you alt-tab out of a game and leave it running.
A common rule of thumb is to cap at your monitor's refresh rate, for example 144 fps on a 144 Hz panel. That isn't from Nvidia. It's general practice, and it's endorsed by a number of vendor and retailer guides. A capped GPU also runs at a steadier load. One guide describes it as a more consistent, moderate load state instead of swinging wildly between heavy rendering and idle-ish coasting.
If the game has its own frame limiter, try that first. In-game limiters often pace frames more smoothly than driver-level ones.
Step 2: G-Sync is optional, and it isn't a noise fix​
BGR says that enabling G-Sync will "immediately reduce" power draw and dampen electrical whine. That overreaches. Nvidia describes G-Sync as a display feature that eliminates screen tearing while minimizing input lag and stutter. It syncs the monitor's refresh to the GPU's output. Nvidia doesn't present it as a power-saving or noise-reduction tool.
G-Sync can still help indirectly. Pairing it with a frame cap just below your refresh rate is a popular combination, and the cap is what reduces the workload. If you have a compatible monitor and want to enable it, Nvidia's steps are:
  1. In the Nvidia Control Panel, under Display, click Set up G-SYNC.
  2. If it isn't checked, tick the Enable G-SYNC/G-SYNC Compatible box.
  3. Choose Full screen mode, or Windowed and full screen mode, depending on your system and the programs you plan to run.
  4. Make sure a G-SYNC-capable or G-SYNC Compatible display is connected, enabled and set as the primary display, and that Monitor Technology is set to G-SYNC/G-SYNC Compatible under Manage 3D Settings.
You don't need a G-Sync monitor to cap frames. The cap in Step 1 works on any display. Buying a monitor to quiet a fan would be a pricey experiment.
Step 3: Tame the fan curve, carefully​
If the noise is fans ramping up and down, a custom fan curve can smooth it out. BGR recommends MSI Afterburner. The tool lets you set fan speed against temperature rather than accepting the card's default profile.
A few cautions:
  • A quieter curve usually means a hotter card. If you lower fan speeds, watch temperatures under the load that normally triggers the noise. Back the curve off if temperatures climb noticeably.
  • Smoothness often beats silence. Many people find a steady, moderate hum less irritating than fans that surge and drop. A gentler slope on the curve can help with that.
  • Laptops are different. Per the research notes, MSI says laptop GPUs can't use custom fan curves through Afterburner because the manufacturer presets fan control in the BIOS. On a laptop, look at the vendor's own utility or performance profiles instead.
  • Don't lock one speed for every situation. BGR mentions locking fans to temperature bands. A curve that responds to temperature is the safer approach.
A fan curve won't fix coil whine. As one guide puts it, fan curve optimization won't fix electrical coil whine, but it's the best way to reduce fan noise by keeping speeds low during idle or light tasks.
Step 4: Lower the power draw​
For coil whine and heat together, reducing power can help. BGR suggests a mild undervolt through Afterburner. Other guides suggest a simpler route: dropping the power limit slider in MSI Afterburner by 10–20% can noticeably reduce coil whine without meaningfully affecting gaming performance for most people. That claim comes from an MSI-branded hobbyist site, so treat the figures as a starting point rather than a guarantee. Results vary from card to card.
Change one thing at a time, test in a game you know well, and keep the setting only if it's stable. Undervolting and power-limit changes are tuning, not repair. If a game crashes or artifacts appear, revert.
Step 5: Clean the cooler​
Dust in the heatsink and fans makes the card run hotter, so the fans spin faster. Blowing it out is a reasonable first physical step.
BGR gives some specifics here. Treat them as sensible precautions rather than manufacturer procedure:
  • Power the PC off and unplug it first.
  • Ideally take the card out of the system before using compressed air.
  • Keep the fans from free-spinning while you blow air through them. Compressed air can spin a fan far beyond its normal speed.
What I'd skip or treat with caution​
Several claims in BGR's piece weren't backed up by the sources I could check, so I'd be wary of repeating them:
  • An "86°C critical threshold" for GPUs. Thermal limits vary by model and generation. Check your card's specifications and your monitoring software rather than relying on one number.
  • Hand-spinning fans to diagnose bearings and oiling them. Grinding or clicking does suggest a mechanical problem. But lubricating a fan, or dismantling the shroud, can void a warranty and isn't something I can point to a manufacturer recommending.
  • Repasting every year or two. I found no support for a routine schedule. Repasting makes sense for an older card that runs hot after cleaning, once it's out of warranty. It is a real teardown job. Pads, screws and cables are easy to get wrong.
  • Replacing a fan or the whole shroud. Reasonable for an out-of-warranty card with a failed fan, but it's a repair, not a quick fix.
If your card is under warranty and has a grinding fan, runs hot at stock settings or crashes from overheating, contact the card maker's support instead of opening it up.
Is it worth a return?​
Coil whine is generally treated as normal behavior, and warranties often don't cover it. One guide suggests a card is worth returning if the whine is louder than its fans in normal games with a sensible frame cap, or if it comes with crashes, artifacts or overheating. That's one site's practical rule, not a policy. Check the retailer's return terms.
The short version​
  1. Identify the sound: airflow whoosh, electrical whine, or mechanical grinding.
  2. Cap your frame rate, in-game first, then in the Nvidia Control Panel's Max Frame Rate.
  3. Enable G-Sync only if your monitor supports it and you want variable refresh. Don't expect it to fix noise on its own.
  4. Adjust the fan curve gently and watch temperatures.
  5. Try a modest power limit reduction or undervolt if whine persists.
  6. Clean the cooler safely.
  7. For grinding, overheating or crashes, use warranty support rather than oil and a screwdriver.
BGR's core advice is sound: cap frames, tune the fans, clean the dust. Its stronger claims need care. G-Sync isn't a quiet-GPU switch, and a one-size repaste schedule isn't established. A frame cap is cheap, reversible and takes about a minute, so start there.
  1. What To Do If Your Nvidia GPU Is Too Loud bgr.com 2026-10-31T20:47:00+00:00
  2. Manage 3D Settings (reference) nvidia.com
  3. To set up G-SYNC nvidia.com
