A laptop sits on a sunlit desk beside a charger, coffee, and plants, with a full-battery eco icon displayed.
If you have shopped for a sub-$800 Windows laptop lately, you already know the usual compromises: creaky plastic lids, dim washed-out screens, and keyboards that feel like typing on a damp sponge. That is why veteran tech journalist Paul Thurrott’s November 23, 2026 first impressions of the 14-inch HP OmniBook 5 raised eyebrows across the Windows camp. Fresh out of the box, Thurrott reports that HP’s budget-friendly notebook felt "firing on all cylinders," pairing a surprisingly upscale chassis and playful finishes with an affordable starting price.
Thurrott’s early hands-on frames the OmniBook 5 as HP’s unspoken answer to Apple’s MacBook Neo—a comparison rooted not just in price, but in fit, finish, and refusing to treat budget buyers like second-class citizens. While HP never mentions Apple in its pitch, Thurrott highlights practical advantages on the Windows side of the fence, including a backlit keyboard and an available multitouch OLED display. Still, an unboxing glow can hide plenty of spec-sheet traps. Because Thurrott explicitly left real-world testing of Intel’s Core Series 3 "Wildcat Lake" silicon for a follow-up review, pairing his early impressions with official HP documentation and independent lab testing reveals a much sharper picture of what this laptop nails—and where Windows buyers need to watch their step.
A laptop sits on a sunlit desk beside a charger, coffee, and plants, with a full-battery eco icon displayed. Decoding the "OmniBook 5" Label Before You Buy​
Walk into an online storefront looking for an "HP OmniBook 5," and you could easily walk out with three completely different computers. When HP retired its long-running Pavilion branding, the OmniBook 5 name took over as the company’s mainstream consumer tier—sitting above the entry-level OmniBook 3 and below the OmniBook 7, OmniBook X, and flagship OmniBook Ultra. Today, the OmniBook 5 badge covers both 14-inch and 16-inch clamshells, 2-in-1 "Flip" convertibles, and processors from Intel, AMD, and Qualcomm.
Even if you narrow your search strictly to the 14-inch Intel "Wildcat Lake" models (formally the HP OmniBook 5 14-mh0000 series introduced on October 1, 2026), pricing and component tiers shift quickly depending on the retailer and region:
  • Entry-level configurations: Thurrott cites a late-November 2026 starting price of $699 and notes tight stock on higher configurations. Meanwhile, Tom’s Guide’s review lists a $649 starting model—temporarily discounted to $599 on HP’s US storefront—packing an Intel Core 5 315, 8 GB of RAM, a 256 GB SSD, and a non-touch 1920 × 1200 OLED display. Official listings for retail variants like the 14-mh0004ca and 14-mh0523nr confirm that 8 GB SKUs with 256 GB or 512 GB SSDs are very much on the market.
  • The sweet-spot 16 GB tier: Tom’s Guide tested a $749 configuration stepping up to the Intel Core 5 320, 16 GB of RAM, a 512 GB SSD, and an OLED touchscreen. Notebookcheck reviewed a similar Core 5 320 / 16 GB touchscreen configuration listed between $700 and $800.
  • Core 7 step-ups: Stepping up to the Intel Core 7 350 with 16 GB of RAM and 512 GB of storage has appeared on HP’s US store at $1,069.99, a roughly $370 jump over the $699 launch tier that bundles CPU, memory, and storage upgrades together.
The takeaway for Windows shoppers is simple: never buy by brand name alone. Check the full SKU string, processor number, memory capacity, and whether "touch" is actually listed on the spec sheet.
Build Quality, Colors, and Port Quirks​
Where the OmniBook 5 14 genuinely earns its buzz is in how little it resembles a traditional budget PC. Thurrott’s review unit arrived in Soft Honeydew—a sage-like green that joins Smoke Silver, Starlit Blue, and Peony Pink across the 14-inch lineup—with both the keyboard and touchpad color-matched to the aluminum chassis. Despite housing a 14-inch 16:10 panel, Thurrott notes the footprint feels closer to a 13.3-inch machine. Independent measurements back up that pocket-sized impression: Tom’s Guide and Notebookcheck put the chassis at 12.3 × 8.62 × 0.46 inches and roughly 2.56 to 2.6 pounds, built with recycled metal for the outer cover, keyboard deck, and base.
Typing comfort draws mostly positive marks, with a minor split among reviewers. Thurrott praised the full-sized backlit keyboard as "terrific in early use," and Tom’s Guide praised its spacing and key travel. Notebookcheck’s testers were slightly more measured, noting that key travel and feedback lean closer to HP’s older Pavilion line—a touch shallower and spongier—than to a business-class EliteBook. Still, for a sub-$800 consumer ultraportable, the hardware feel clearly punches above its weight.
Connectivity is similarly pragmatic, though with two caveats worth flagging:
  • No USB-A, one-sided charging: On the left edge, you get a full-sized HDMI 2.1 port and two USB Type-C ports supporting Power Delivery 3.1, DisplayPort 2.1, and HP Sleep and Charge; the right edge holds only a 3.5 mm combo audio jack. While Thurrott’s write-up referred to those ports as "10 Mbps" USB-C, official specifications and Notebookcheck’s hardware breakdown confirm they are actually 10 Gbps USB 3.1 Gen 2 ports. Still, having zero USB-C ports on the right side means left-side outlet placement rules your desk, and legacy USB-A flash drives will need an adapter.
  • Practical wireless and webcam trade-offs: Wireless duties rely on Intel Wi-Fi 6E and Bluetooth 5.3 rather than Wi-Fi 7—a sensible cost trim that still delivered strong real-world throughput in Notebookcheck’s router benchmarks. Above the screen sits a 1080p Full HD IR camera supporting Windows Hello facial recognition and dual-array microphones. Just temper your expectations for video calls: Notebookcheck notes there is no physical privacy shutter, and Tom’s Guide found the webcam output visibly grainy even in bright rooms.
That OLED Screen: Gorgeous Contrast, Modest Brightness​
On paper, getting an OLED panel at $699 sounds like an instant knockout—and in dark rooms, the 1920 × 1200 display delivers the infinite contrast and 100 percent DCI-P3 saturation OLED is famous for. The hinge also folds flat to 180 degrees, though Tom’s Guide warns that touch-equipped models lack active stylus support, limiting flat-screen use to finger taps and swipes.
In lab measurements, however, the entry-level 1200p OLED shows its budget roots:
Spec or MeasurementBase 1200p OLED (Tested)Higher-Tier 1800p OLED Option
Resolution & Refresh1920 × 1200, 60 Hz2880 × 1800, 120 Hz
HDR SupportNo (SDR only)Yes (up to 1,100 nits HDR peak)
Measured Brightness~272–282 nits averageBrighter outdoor visibility
Touch OptionTouch or non-touch SKUsTouchscreen
Tom’s Guide measured the 1200p panel at an average of 272 nits, while Notebookcheck logged roughly 282 nits on its Samsung SDC425A test panel—well behind the brighter 398-to-452-nit SDR displays on the 2026 Dell XPS 13 and MacBook Neo. Combined with a glossy finish and 60 Hz refresh rate, outdoor glare is noticeable. Notebookcheck also points out that in regions offering the 2880 × 1800 120 Hz HDR OLED upgrade for roughly $120 more, that panel upgrade does far more for daily enjoyment than paying extra for a Core 7 350 CPU. HP’s own announcements also schedule a 2.5K (2560 × 1600) 620-nit multitouch OLED option for March 2027, so buyers should double-check exact panel specs before checking out.
Inside "Wildcat Lake": Why 16 GB RAM Matters and Copilot+ Does Not Apply​
Thurrott closed his first impressions wondering whether HP "made sense of Wildcat Lake" after a disappointing encounter on a different laptop. Understanding what Intel actually built here explains both the OmniBook 5’s endurance and its performance ceiling.
Intel’s Core Series 3 ("Wildcat Lake") silicon is the value-focused sibling to Core Ultra Series 3 ("Panther Lake"). Fabricated on Intel’s 18A node, it uses a two-tile layout with up to two Cougar Cove Performance cores and four Darkmont Low-Power Efficiency cores—meaning the Core 5 315, Core 5 320, and Core 7 350 all top out at six cores and six threads, paired with two Xe3 graphics cores and single-channel memory.
That design carries two major implications for Windows 11 buyers:
  • No Copilot+ PC features: Despite "AI PC" branding on retail pages, Wildcat Lake’s integrated NPU delivers 15 to 17 TOPS (16 TOPS on the Core 5 320 and 17 TOPS on the Core 7 350). That falls well short of Microsoft’s 40-TOPS NPU floor for Copilot+ PC experiences. If you specifically want local Copilot+ features on an OmniBook 5, you need one of HP’s Qualcomm Snapdragon X or X2 Plus variants—not the Intel 14-mh0000.
  • Soldered RAM makes 8 GB a dead end: According to HP’s 14-mh0000 specifications and Notebookcheck’s internal teardown, the battery, M.2 Wi-Fi module, and single M.2 2280 SSD can be serviced or swapped, but the LPDDR5-6400 memory is soldered directly to the board. There is no future RAM upgrade path. Thurrott’s flat refusal to recommend an 8 GB configuration makes total sense here: Windows 11 with a dozen browser tabs and background sync tools quickly crowds 8 GB, making 16 GB the sensible baseline.
In day-to-day productivity, independent benchmarks confirm Wildcat Lake hits its intended target—and stops there. Tom’s Guide reported smooth performance across heavy Chrome tab loads, word processing, video streaming, and light GIMP image edits, posting Geekbench 6 scores of 2,583 single-core and 7,855 multi-core. Notebookcheck’s Core 5 320 benchmarks similarly placed it right alongside the Wildcat Lake Dell XPS 13, while estimating only about a 10 percent CPU uplift on the Core 7 350. Heavy video transcoding, demanding creative suites, and modern 3D games are off the table—Tom’s Guide saw Borderlands 3 crawl at an unplayable 10.5 fps at 1080p, and Apple’s MacBook Neo maintained a clear CPU and GPU benchmark lead even with 8 GB of RAM.
Battery Life: Marketing Claims vs. Real-World Endurance​
If raw horsepower goes to Apple’s camp, stamina is where HP swings back hard. HP’s product pages advertise up to 42 hours of local video playback for a 14-inch OmniBook 5—a controlled manufacturer test figure that no buyer should mistake for mixed workday endurance.
Even so, real-world testing proves the 60 Wh battery and low-power Wildcat Lake chip are an efficiency standout. In Tom’s Guide’s standardized Wi-Fi web-surfing rundown at 150 nits, the Intel Core 5 320 OmniBook 5 14 ran for an exceptional 19 hours and 52 minutes—comfortably beating both the 2026 Dell XPS 13 (14 hours, 57 minutes) and the MacBook Neo (13 hours, 38 minutes). When you finally do need a wall outlet, HP bundles a compact 65W GaN USB-C adapter that supports HP Fast Charge, topping the battery back up to roughly 50 percent in about 30 minutes when the laptop is shut down.
The Bottom Line for Windows Buyers​
Paul Thurrott’s early enthusiasm passes the fact-check—with an asterisk on configuration. HP’s 14-mh0000 OmniBook 5 proves that affordable Windows 11 laptops no longer have to look or feel disposable, delivering a slim metal build, fun color options, sharp OLED contrast, and nearly 20 hours of tested web-browsing stamina. Just shop like an IT pro rather than an impulse buyer: skip the non-upgradeable 8 GB entry models, verify whether you are getting a touch or non-touch panel, double-check whether you need a USB-A dongle, and remember that Wildcat Lake trades gaming muscle and Copilot+ NPU horsepower for marathon battery life at a student-friendly price.
Correction (November 23, 2026): An earlier version of this article said the HP OmniBook 5 14-mh0000 series was introduced in September 2026. HP announced the laptop on October 1, 2026.
  1. HP OmniBook 5 First Impressions - Thurrott.com Thurrott.com 2026-11-23T18:04:04+00:00
  2. HP Omnibook 5 14 Wildcat review: Better than any Pavilion laptop - Notebookcheck Review notebookcheck.net
  3. pcmag.com pcmag.com
