What RTINGS actually tested
RTINGS tested the HP OmniBook Ultra 14 (14-kg0010ca) in Stone Blue. It had a Snapdragon X2 Elite X2E-90-100 processor, 32GB of RAM, a 1TB SSD and the 3K 120Hz OLED touchscreen. The processor is an 18-core part. RTINGS says its performance, battery, thermal and noise findings apply to that unit only. It did not test the Intel versions, so it makes no benchmark comparison between the two families.
Configurations
Snapdragon (14-kg family)
- RTINGS lists a 10-core X2 Plus and 12-core and 18-core X2 Elite options.
- Graphics are integrated Adreno, from the X2-45 in the Snapdragon X2 Plus to the X2-85 and X2-90 in the two X2 Elite options.
- The Elite models offer more performance, but even the strongest X2-90 configuration has limited headroom for demanding games and professional 3D rendering.
Intel (14-kd family)
- RTINGS lists Core Ultra 7 356H, Core Ultra 9 386H and Core Ultra X9 388H versions.
- Only the X9 gets the more capable Arc B390 graphics. The other two use basic integrated Intel graphics.
- RTINGS says the Intel versions avoid Windows-on-ARM compatibility limits and have three Thunderbolt 4 ports, Wi-Fi 7 and Bluetooth 6.0.
Display and memory
- Some X2 Plus and 12-core X2 Elite models can have a 1920 × 1200, 60Hz OLED touchscreen.
- The 2880 × 1800, 120Hz panel is what RTINGS tested. It says all Intel configurations use it.
- Both families go up to 64GB of soldered memory and 2TB of storage, and the top memory tier is limited to the 18-core X2 Elite or Core Ultra X9 models.
- Availability varies by region.
What the tested Snapdragon unit did well
Battery life was the standout. The 18-core X2 Elite with the 3K OLED display lasted nearly 16 hours of web browsing and over 21 hours of video playback. That is one sample with one display. RTINGS warns that the processor, panel, brightness and workload all change runtime, and that gaming or heavy processing drains the battery much faster. A full charge from the included USB-C charger took about two and a half hours.
RTINGS rates the laptop very good for school and work. It rates it okay for heavy workloads. It praises the compact, light aluminum build, a comfortable and quiet keyboard, and a webcam and microphone that work well for calls. The OLED panels give deep blacks and suit dark-room viewing. The speakers sound good but lack bass.
Caveats from the review
- Chassis: The review notes some flex and creaking when the closed laptop is twisted. The screen wobbles a bit when touched or when you type on an unstable surface. The Snapdragon unit also gets hot under load, with heat building up around the keyboard.
- Touchpad: The review sample's touchpad haptics were defective and gave no feedback on clicks or drags. This is a fault with that unit, not proof that every unit has it.
- Display: The 3K panel is glossy and struggles in bright reflections. RTINGS also saw flicker on it, which may bother sensitive viewers. It says its brightness and flicker findings may not apply to the lower-resolution screen. For color-critical editing, it says the tested panel needs calibration.
- Graphics: RTINGS calls the OmniBook Ultra 14 2026 mediocre for gaming. Even the top-end Snapdragon model struggles with demanding games, and upgrading doesn't fix Windows on ARM game and anti-cheat compatibility issues.
- Ports: RTINGS describes three USB-C ports, with no USB-A, HDMI or card reader. Plan on adapters for older accessories, external displays and memory cards.
How other reviewers saw it
Other outlets reviewed the Snapdragon model earlier in the year and were broadly positive. Windows Central called it the best Snapdragon X2 Elite laptop it had tested, praising the design, keyboard, trackpad, OLED display, battery life and performance. Tom's Guide was more mixed. It said the X2 Elite model offers great performance and extreme portability but has a few major drawbacks that keep it from feeling Ultra. Its listed cons include a lacking port selection, and its headline says the price is wrong. A Yahoo Tech review reported launch pricing starting at $1,899 for a Snapdragon X Plus model with 16GB of RAM, and $2,399 for a Snapdragon X2 Elite with 32GB. Those were launch prices from that review, so check current pricing yourself.
Comparisons RTINGS draws
RTINGS says the Dell XPS 14 (2026) has sturdier construction, a more stable hinge and a sharper webcam. The tested HP lasted substantially longer than the OLED Dell, though runtime depends on configuration. Against Microsoft's Surface Laptop 8th Edition (2026), the Surface has a sturdier chassis, a taller display and more varied ports. The HP counters with OLED and Intel options.
Who should buy which
My own read, based on RTINGS's findings and general industry experience rather than anything RTINGS states:
- Snapdragon X2: This suits a mobile worker who lives in browsers, Microsoft 365, Teams and mainstream apps and wants a very long battery life. Before you buy, confirm that your niche software, drivers, VPN or security agents, and peripherals support Windows on ARM.
- Intel Core Ultra Series 3: This is the safer pick for broad compatibility, Thunderbolt 4 docking and external displays. RTINGS has not measured its battery life or performance, so don't assume it matches the Snapdragon unit's runtime.
- Display choice: The 3K/120Hz panel is the one RTINGS tested. The 1920 × 1200/60Hz option is untested here. Don't carry over the brightness and flicker results to the lower-resolution screen.
Limits of this review
RTINGS' own changelog puts the sample's arrival at its lab on September 18, 2026, the start of testing on October 15, early access on October 28 and the full review on November 2. Much of the detailed test data sits behind its membership wall, so this summary draws on the freely visible verdicts rather than every measured number.
The short version is that the OmniBook Ultra 14 is a strong, light, long-lasting ultraportable. In the tested Snapdragon form it has real quirks: heat under load, a defective touchpad on the sample, and only USB-C ports. It is also not a gaming machine. Match the processor family to your software before you match the screen to your taste.
- HP OmniBook Ultra 14 (2026) Review - RTINGS.com RTINGS.com · Mon, 02 Nov 2026 16:01:26 GMT
- HP OmniBook Ultra 2026 review: The best HP laptop, yet? tech.yahoo.com
- HP OmniBook Ultra 14 (2026) Snapdragon X2 Review: Basically the perfect Windows laptop windowscentral.com
