The useful finding is the disagreement hidden behind the headline. Golden Pig Upgrade’s original shorthand appears to label the 296W value as PL1, while jaykihn0 said it is “technically” PL2. Those are materially different configurations on Intel platforms. Until Intel publishes its own processor specifications and motherboard guidance, there is no basis for saying whether 296W would be a momentary ceiling, a sustained operating target, or simply an early validation setting that will change before retail silicon arrives.
The comparison with the current Core Ultra 9 285K is real, though. Intel lists the 24-core 285K at 125W Processor Base Power and 250W Maximum Turbo Power. A 296W ceiling would be 46W, or roughly 18%, above that official maximum-turbo figure. For an enthusiast desktop part with a proposed 8P+16E+4 LP-E configuration and 144MB of big last-level cache—or bLLC—that is a plausible signal that Intel may be willing to spend substantially more package power pursuing gaming performance.
The leak does not establish sustained 296W operation
PL1 and PL2 labels have often been flattened into “TDP” in processor coverage, but they describe different controls. Intel’s public platform documentation defines PL1 as the average-power threshold and recommends matching it to Processor Base Power. PL2 is the higher threshold at which rapid power-limiting behavior is meant to constrain spikes; the time behavior is also shaped by the Turbo Time Parameter, or Tau.
In older, more conventional desktop configurations, a processor might run at a higher PL2 value for a period before settling toward PL1. That history is why the TweakTown report interprets jaykihn0’s PL2 clarification as evidence of short 296W bursts. But that inference does not hold automatically for current enthusiast Intel desktop practice.
Intel’s own Core Ultra 9 285K material lists PL1 and PL2 as both 250W in its reference test configurations. In other words, the company’s current flagship desktop design already demonstrates that a “PL2” number is not necessarily a brief excursion followed by a return to the 125W base-power rating. It can also sit within a configuration where the sustained and turbo limits are equal.
That is the key point the initial reporting leaves unresolved. If the Nova Lake-S setting turns out to be PL1=PL2=296W, the practical meaning is very different from “a 125W CPU that occasionally spikes to 296W.” It would be a processor whose reference performance mode permits nearly 300W package power for longer all-core work, subject to thermal, current, firmware, and motherboard constraints.
Conversely, if final firmware uses a 125W PL1 and 296W PL2 with a defined Tau, then the headline wattage would matter most for short turbo-heavy workloads and less for lengthy renders, compiles, scientific workloads, or stability tests. Neither version is confirmed. The public leak has not supplied the Tau setting, current limits, voltage behavior, clock speeds, test board, BIOS revision, or a measured workload trace. A power-limit value without those details is not a power-consumption test.
Intel’s 125W label would not contradict a 296W limit
The reported 125W figure for the bLLC-equipped 28-core model also comes from previous leaks rather than Intel. Still, assuming that number eventually proves accurate, it would not create the contradiction some reports imply.
Intel already separates Processor Base Power from Maximum Turbo Power on the Core Ultra 9 285K: 125W and 250W, respectively. A Nova Lake-S part advertised at 125W base power and 296W maximum turbo power would be a more aggressive version of the same product-labeling model, rather than an unprecedented departure from it.
For buyers, the distinction is more than semantics. A boxed CPU’s base-power value does not tell a system builder what the processor can demand under an unlocked motherboard profile, a stock high-performance preset, or a long multicore workload. Cooling capacity, case exhaust, motherboard voltage-regulator design, and firmware defaults decide whether the machine can hold high clocks without thermal or power-limit throttling.
Intel itself notes in its power-limit guidance that inadequate cooling or power delivery can trigger throttling. A 296W ceiling would therefore affect more than the CPU-cooler shopping list. It raises questions about whether compact cases, modest air coolers, lower-end motherboard VRMs, and prebuilt system designs would deliver the advertised performance consistently. Those questions cannot be answered from the leak, but they are the consequences system builders should watch as real boards and engineering samples appear.
The sensible planning rule is simple: do not buy a motherboard, cooler, or power supply around this rumour. But anyone waiting to build around Nova Lake-S should treat “125W” as an incomplete description until Intel states both Processor Base Power and Maximum Turbo Power, and motherboard vendors publish their default power profiles.
bLLC is the larger product bet behind the wattage figure
The proposed processor is notable because the 296W claim is attached to Intel’s rumoured bLLC design, which reporting has described as a large cache option aimed at games that benefit from keeping more data close to CPU cores. Earlier coverage by VideoCardz, Tom’s Hardware, and regional hardware publications has consistently associated the single-tile 28-core configuration with 8 performance cores, 16 efficiency cores, four low-power efficiency cores, and 144MB of bLLC.
Those specifications remain leak-based, but the repeated appearance of the same arrangement across separate reporting over several months makes it more credible than a one-off number. It also explains why Intel might tolerate a higher power envelope: a cache-focused flagship is expected to compete in the performance-sensitive workloads where Ryzen X3D processors have built a strong following, especially games limited by memory latency and CPU scheduling rather than raw graphics throughput.
Yet cache capacity alone does not establish a gaming win, and power limits will not settle the question. The missing figures are cache latency, memory-controller behavior, boost clocks, scheduler handling of the added LP-E cores, and the performance cost of keeping a larger cache structure active. There are no independent benchmarks of this supposed 28-core bLLC chip, no retail motherboard BIOSes, and no Intel validation material to assess.
The 296W report is therefore evidence of design intent, not evidence of performance. It suggests Intel may be allocating a larger power budget to its cache-enhanced desktop tier than it does to today’s Core Ultra 9 285K. It does not show that Nova Lake-S will beat existing gaming CPUs, or even that a shipping 28-core bLLC SKU will use the reported configuration.
What builders should look for next
The immediate issue is not whether 296W sounds excessive in isolation. Current high-end desktop CPUs already require deliberate cooling and board selection when their higher power modes are enabled. The issue is whether Intel chooses to make nearly 300W the normal reference behavior for a mainstream-socket flagship, rather than an optional vendor enhancement.
Before this becomes actionable news, Intel needs to disclose four items: the processor’s actual name and core layout, its official base and turbo-power ratings, whether PL1 and PL2 are equal in its reference profile, and the supported cooling and motherboard requirements. Independent reviews will then need to test sustained package power rather than report only a peak monitoring value.
For now, TweakTown’s 296W figure is a credible-enough rumour to monitor because it aligns with the reported 28-core, 144MB bLLC Nova Lake-S configuration and is echoed by other hardware outlets. But the central detail remains unsettled: 296W is a leaked power limit, not a measured consumption result, and the PL1-versus-PL2 dispute determines whether it represents a short boost ceiling or the processor’s likely sustained high-performance operating mode.
- Intel 'Nova-Lake-S' 28-core CPU with bLLC reportedly draws 296W at PL2 - TweakTown TweakTown · 2026-08-21T18:45:14+00:00
