This piece covers what the MQ80 is, how it performs, where it falls short, and who should buy it. It is a PC peripheral story, so I've included notes on Windows use.
What the MQ80 is
The MQ80 is a low-profile, 80% ("compact TKL") wireless mechanical keyboard. It keeps the function row, arrow cluster and a block of navigation keys, and drops the number pad. Tom's Hardware lists a release date of February 25, 2025. It reports a $159.99 MSRP, while IQUNIX's own store lists $159.00 and showed the product as sold out when the source packet was captured.
Price and stock vary by source and snapshot. Tom's Guide cited $169, and the Tom's Hardware review's retailer comparison showed a higher Amazon price when crawled. Check live listings before you buy. The "wait for a sale" advice is the reviewer's opinion, not a confirmed discount.
Specs at a glance:
| Item | Detail |
| Layout | 80% compact TKL. Tom's Hardware's table says "80" keys. IQUNIX lists an ANSI layout with 84 keys, so the counting differs by source. |
| Case | CNC aluminum with an anodized finish, in black or silver |
| Size | About 321 × 124.5 × 27.5 mm at the rear. The front is roughly 10.2–10.8 mm, depending on the source. |
| Weight | 1,180 g (2.6 lb) |
| Switches | Linear, 40 gf actuation, 1.2 mm actuation point, 2.8 mm total travel |
| Connectivity | USB-C, 2.4 GHz, Bluetooth 5.1 |
| Battery | 4,000 mAh |
| Software | VIA, a browser-based configurator |
| Compatibility | IQUNIX lists Windows, macOS, iOS and Android |
Build quality, and the weight problem
The review's central point is that this thin keyboard is heavy. The aluminum case puts it near the weight of a full-size mechanical keyboard or a good TKL. Tom's Hardware says people often remark on the weight when they pick it up.
IQUNIX includes a hard carrying case, so the board is technically portable. The reviewer still doesn't see most people carrying it every day. It suits a desk better than a backpack. Other reviewers treat the weight as a plus: Hardware Planet notes that it is heavy for a 75% low-profile board, at almost 1.2 kg, and says fans of aluminum will be satisfied. Whether the weight is good or bad depends on whether you carry the keyboard around.
The keycaps are PBT. The review describes them as thick, lightly textured and dye-sublimated. IQUNIX's page calls them high-purity PBT with an anti-oil coating. Both descriptions come from the sources, and neither is an independently verified durability test. The keycaps are not shine-through, so the per-key RGB is less useful in the dark unless you touch-type.
Inside the keyboard
The internals are a big part of the pitch. Top to bottom, the review describes:
- An FR4 plate that the switches snap into.
- A thick PORON foam layer, plus thinner IXPE foam and a PET sheet near the switches.
- Another PORON layer under the PCB.
- A bottom IXPE layer before the aluminum case.
- A modified gasket mount IQUNIX calls "Le-Tray." Six arms hold the assembly in the case on silicone buffers for softer bottom-outs.
The reviewer says the result is a deeper, quieter keystroke with a soft landing. It feels a little stiffer than the gasket mounts on most full-height gaming boards. Other reviewers agree on the sound. Tom Eversley credits the foam layers and a flex-cut PCB for a soft, cushioned feel and a muted, smooth sound.
Typing and the switch question
The review is clear about who this keyboard is for. It's for people who like low-profile boards, linear switches and a light touch.
- Switch naming: Tom's Hardware calls the switch Kailh Rose Red. IQUNIX and Tom's Guide call it a pre-lubed Kailh POM Gold Red linear switch. I'd go with the manufacturer's naming and treat the review's wording as a discrepancy.
- Adjustment period: The keycaps feel identical from row to row. The reviewer found the light switches easy to trigger by accident, especially for heavy-handed typists.
- Typing speed: The reviewer's MonkeyType average dropped from about 110 WPM on a full-height board to 105 WPM on the MQ80, because of extra backspacing. That's one person's test, not a benchmark.
- Switch options: The switches are hot-swappable with Kailh Choc V2 alternatives. Choice is thin, though, and the reviewer wanted a tactile option. The review says the one non-light tactile option it found would cost about half the price of the keyboard.
If you want tactile or silent switches at checkout, the review points to rivals. It says the NuPhy Air75 V3 types at least as well and is more customizable, with Gateron low-profile switches and tactile and silent options. It also suggests the Lofree Flow 2 for a more office-friendly board with a tactile option. These are the reviewer's assessments, not rankings.
Gaming, wireless and battery
For gaming, the light switches that hurt typing accuracy feel like hair triggers. Over wired or 2.4 GHz, the board polls at 1,000 Hz. The review notes that this lags 8,000 Hz boards on paper, and that you may not feel the difference.
There are no gaming-specific features such as adjustable actuation. The reviewer's pitch for the MQ80 is that it's pleasant, not competitive. PowerUp Gaming makes the same point: it doesn't try to be an esports deck with rapid-trigger tricks.
One detail for wireless users: IQUNIX lists 125 Hz over Bluetooth. If latency matters, use the dongle or the cable.
On battery life, IQUNIX claims up to 350 hours. Its own page says that is a theoretical estimate with RGB off, and the review puts it on Bluetooth with lighting disabled. Tom's Hardware got close to two weeks between charges with lighting on, and estimates about 45 hours on 2.4 GHz with RGB set high. Real use will fall between the maximum and the worst case.
VIA software and one firmware warning
The MQ80 uses VIA instead of a vendor app that has to stay running. That matters on Windows, where background configuration utilities are often a nuisance:
- Remaps, macros and layers are written to the keyboard itself.
- The settings then travel with the board to any machine.
- You can map up to F24, media controls, macros and RGB controls.
- Limits: there's no simple per-key custom lighting. A fully custom scheme means writing code and flashing it manually.
- IQUNIX's product page warns that the custom firmware does not support Mod-Tap, Layer-Tap, or KC_MEH/KC_HYPR modifiers. VIA power users who rely on dual-role keys should note this before buying.
Who should buy it
Good fit:
- You want a desk-based low-profile keyboard with an aluminum chassis and a damped, soft sound.
- You like light linear switches.
- You value VIA remapping that isn't tied to an app.
Weaker fit:
- You commute with your keyboard.
- You want tactile or silent switches out of the box.
- You want high polling rates or adjustable actuation for competitive play.
Tom's Guide praises the typing feel and build. It also flags the high price, the lack of adjustable feet and frustrating shortcut combos for changing settings.
Bottom line
The MQ80 is a premium board with a clear personality. Its main drawbacks are weight, limited switch variety and a price that has stiff competition. Check live pricing and stock first, since sources disagree and IQUNIX's own store showed it sold out. If you want a heavy, quiet, soft-landing keyboard for a desk, it's a strong option. If you want something light and flexible, look at the NuPhy or Lofree boards the review suggests.
- IQUNIX MQ80 low profile mechanical keyboard review Tom's Hardware · 2026-10-25T15:08:23+00:00
- IQUNIX MQ80 アルミロープロファイルメカニカルキーボード – IQUNIX.com iqunix.com
- IQUNIX MQ80 Aluminum Low Profile Mechanical Keyboard – IQUNIX.com iqunix.com
