New testing of the Lenovo Pro 9n—officially cataloged as the Lenovo Pro 9 15N1X11—suggests Lenovo may have cracked the thermal and acoustic puzzle better than its early rivals. Based on a comprehensive review by Mark Hachman at PCWorld, alongside independent lab benchmarks from StorageReview and Tom's Hardware and Lenovo's official Product Specifications Reference (PSREF), the 18-core Pro 9n turns out to be one of the most compelling Windows-on-Arm workstations yet—even if its $3,000-plus entry price and Windows memory rules force buyers to read the fine print.
The 18-Core RTX Spark N1X: Fewer Cores, Minimal Sacrifice
Nvidia attaches the same RTX Spark N1X branding to two distinct configurations. The flagship tier packs a 20-core Grace Arm CPU and a 6,144-core Blackwell GPU, whereas the entry variant tested in the Lenovo Pro 9n steps down to an 18-core CPU (nine performance cores up to 3.9 GHz and nine efficiency cores up to 2.8 GHz, with no SMT) and a 5,120-core Blackwell RTX GPU, paired with a 52 TOPS NPU.
On paper, losing two CPU cores and 1,024 GPU cores sounds steep. In practice, the gap shrinks dramatically:
- Productivity and Graphics: PCWorld found that the 18-core Pro 9n kept pace with the higher-tier Surface Laptop Ultra in UL Procyon's Office Productivity suite and finished near the top of its laptop charts in Geekbench 6 multi-core, 3DMark Time Spy, and 3DMark Night Raid, even surpassing Intel's Core Ultra X7 and X9 ("Panther Lake") chips in productivity graphics benchmarks.
- Gaming and Creator Workloads: In PCWorld's PugetBench Adobe Premiere test, the Pro 9n easily outpaced entry creator laptops while trailing top-tier gaming rigs. Testing Cyberpunk 2077 at 1080p Ultra delivered 72 fps; cranking settings to 1080p Ray Tracing Overdrive dropped native performance to 20 fps, before Nvidia DLSS upscaling and frame generation brought it back up to 65 fps.
- Cross-Outlet Benchmarks: StorageReview compared the 18-core Pro 9n directly against a 20-core, 32GB HP OmniBook Ultra 16. The Lenovo trailed by just 8 to 11 percent in rendering, compression, and LLVM compilation, virtually tied in Stockfish chess search (15.20 Mnps vs. 15.12 Mnps) and OpenBLAS N=20000 matrix solves (318.1 vs. 322.4 GFLOPS), and beat a Razer Blade 16 (RTX 5090) by 23 percent in Cinebench 2026 multi-core.
- Where Arm64 Software Still Trips: Both outlets noted platform quirks. PCWorld saw average HandBrake transcoding speeds and slower ComfyUI text-to-video runs (roughly 20 seconds slower per run than an RTX 4090-equipped MSI Raider). StorageReview isolated a sharp Arm64 software bottleneck in HandBrake's SVT-AV1 encoder, where every RTX Spark system crawled at roughly 15 fps compared to 77.3 fps on the x64 Blade 16.
Section Takeaway: Stepping down to the 18-core N1X costs surprisingly little real-world speed. Most buyers will notice Arm64 software optimization—or lack thereof—long before they miss two CPU cores.
Thermal Discipline: Why the 18-Core Chip Runs Cooler and Steadily
If there is one area where Lenovo's engineering shines, it is sustained thermals. High-wattage AI laptops have a bad habit of sounding like airport tarmac equipment the moment a workload spins up. PCWorld singled out the Pro 9n's quiet, unobtrusive fans as its standout feature, noting that even during plugged-in stress tests at maximum performance, fan noise stayed remarkably restrained.
More importantly, the Pro 9n refused to throttle under load—a feat corroborated across three separate test labs:
| Stress Test / Outlet | Lenovo Pro 9n (18-Core N1X) Result | Rival Comparison |
| PCWorld (Cinebench 2024, 10-min loop) | No performance drop observed | Surface Laptop Ultra throttled during loop |
| Tom's Hardware (Cinebench 2026, 10 runs) | Opened at 6,219.85; climbed to 6,417.45 on run 6 | Sustained high-6,300s without thermal dip |
| StorageReview (Cinebench 2026, 30-min loop) | Held 3,288 MHz; finished at 6,416 (101.1% of pass 1); 92°C peak | HP OmniBook Ultra 16 (20-core) peaked at 97–98°C |
Why does the 18-core Lenovo keep its cool better than 20-core rivals? StorageReview points to Lenovo's redesigned dual-fan cooling, larger underside intake grille, and 80W power budget. With 18 cores sharing an 80W ceiling instead of 20 cores, each core sustains higher clocks at lower temperatures—Tom's Hardware recorded the Cortex-X925 performance cores averaging 3.57 GHz and Cortex-A725 efficiency cores averaging 2.81 GHz during its ten-run stress loop. The only component that ran noticeably warm in StorageReview's testing was the 1TB Samsung Gen4 SSD, which hit 78°C under sustained storage stress.
Section Takeaway: Lenovo traded two cores for headroom, and the payoff is a laptop that stays quieter and avoids the thermal throttling seen on competing RTX Spark hardware.
The Local AI Catch: Windows Memory Splits Trump Core Counts
Here is the most important caveat for developers, data scientists, and local-AI tinkerers eyeing the base 32GB Pro 9n: on Windows 11 on Arm, RAM capacity sets a hard ceiling before GPU compute does.
StorageReview highlights an essential platform limitation on Windows 11 26H1 (Arm64): unlike the Linux software stack on Nvidia's DGX Spark systems, Windows does not yet support dynamic unified memory pooling across the CPU and GPU. Instead, users must set a static memory split inside the NVIDIA app—for example, dedicating 12GB to the GPU and 20GB to Windows on a 32GB machine.
That split creates a sharp divide in what the base Pro 9n can run locally:
- Small Models Fly: In StorageReview's MLPerf Client v2.0 tests, the 5,120-core GPU generated 55.1 tokens per second on Llama 3.1 8B and 95.2 tokens per second on Phi-4-mini—within 2 percent of the 20-core HP OmniBook Ultra 16 because token generation at this scale is bandwidth-bound rather than core-bound. Full Retrieval-Augmented Generation (RAG) queries returned answers in 0.252 seconds.
- Larger Models Hit a Wall: Because 12GB of GPU-usable memory leaves no room for models like the 12.8GB
gpt-oss:20b(plus its KV cache), the 32GB Pro 9n could not qualify for StorageReview's 16GB-minimum model-loading and coding-agent benchmarks. - NPU Software Gaps: Despite boasting a 52 TOPS NPU, PCWorld found zero NPU utilization in Windows Task Manager during its microphone tests, and noted that the Windows Camera app lacked the NPU-driven filtering controls commonly seen on Copilot+ PCs.
Because the LPDDR5X-9400 memory is soldered, you cannot upgrade it later. Worse, Lenovo ties 64GB and 128GB memory options exclusively to the pricier 20-core N1X chip.
Section Takeaway: If your AI workflows stick to 8B-parameter or smaller models, the 32GB Pro 9n keeps up with 20-core rivals. If you want 20B+ local coding agents, you have to pay up for 64GB or 128GB from the factory.
Display, Webcam, Audio, and the Touchpad Stylus Twist
At 3.64 pounds and 0.66 inches thick (a configuration in Lenovo's PSREF also lists starting weight up to 3.86 pounds), the Thunder Grey aluminum clamshell feels remarkably familiar to anyone who has used a Yoga laptop—so much so that PCWorld spotted a "YOGA" logo flashing during boot despite the Pro 9n branding.
The centerpiece is a 15.3-inch 2560×1600 PureSight Pro OLED touchscreen with a 48–165Hz variable refresh rate. Lenovo factory-calibrates it with X-Rite Pantone validation (rated Delta E under 0.5, 100% sRGB and P3 coverage, 99% Adobe RGB, Dolby Vision, and VESA DisplayHDR True Black 1000). PCWorld measured 460 nits in SDR (versus Lenovo's 500-nit typical / 1,100-nit HDR peak rating) and appreciated the color-profile switcher and OLED burn-in dimming tools tucked inside Lenovo Vantage—though Hachman noted that 2560×1600 feels slightly modest on a $3,000+ creator laptop when buyers may expect 4K sharpness, and he encountered a single non-repeating visual glitch early in testing.
Where Lenovo decisively beats the Surface Laptop Ultra is video conferencing. The Pro 9n packs a sharp 9.2-megapixel (2400p) IR webcam with a physical side e-shutter switch, alongside a triple-mic array that nearly erased rock music and white noise in PCWorld's voice-recording tests. Its four-speaker Dolby Atmos array (two 2W woofers and two 2W tweeters) also earned high marks, trailing only the Surface Laptop Ultra among tested RTX Spark laptops.
Input hardware brings one notable quirk. The keyboard offers comfortable 1.5mm travel and two-stage backlighting (plus auto), though it omits a number pad and dedicates a function key to launching Calculator. Below it sits a massive 95×150mm glass haptic Force Pad that pairs with the bundled Yoga Pen Gen 2 (AES 3.0, 8,192 pressure levels). Because the clamshell lid doesn't fold flat into a tablet, the stylus is built to ink on the touchpad rather than the display. PCWorld found it surprisingly accurate for signing documents or sketching quick UI wireframes, though cursor visibility and USB-C charging management take some getting used to.
Section Takeaway: You get top-tier webcam, mic, and color-accurate OLED hardware, though illustrators expecting to draw directly on the screen should note the touchpad-only pen workflow.
Ports, Dual M.2 2242 Bays, and the 140W Docking Reality Check
Port selection is generous by modern thin-and-light standards, though there is an important spec clarification to catch. While PCWorld's spec list mentioned three USB4 ports, Lenovo's official PSREF documentation—alongside Tom's Hardware and StorageReview—confirms the chassis actually carries two USB4 Type-C (40Gbps) ports, split evenly across the left and right edges:
- 2x USB-C (USB4 40Gbps) with DisplayPort 2.1 and USB PD 65–100W
- 2x USB-A (10Gbps), with one Always On port
- 1x HDMI 2.1 (up to 8K/60Hz)
- 1x UHS-II SD card reader
- 1x 3.5mm headphone/microphone combo jack
- Wi-Fi 7 (2x2) and Bluetooth 5.4
IT admins and desk-bound creators should also pay close attention to power delivery. Lenovo's PSREF footnotes reveal that while the USB-C ports accept standard 65–100W USB PD, reaching the full 140W (20V/7A) fast-charging spec relies on a proprietary Lenovo protocol requiring the bundled 140W USB-C Slim adapter. As PCWorld warns, plugging into an older USB4 or Thunderbolt 4 dock will likely leave the laptop underpowered under heavy loads, making a newer Thunderbolt 5 dock—or keeping the Lenovo brick handy—a smart precaution.
Inside, Lenovo made an unusual storage choice: two M.2 2242 slots (one PCIe 5.0 x4 and one PCIe 4.0 x4, each supporting up to 2TB). Having a second NVMe bay beats single-slot rivals for expansion, though compact M.2 2242 drives are harder to source and typically slower than standard M.2 2280 SSDs.
Section Takeaway: Two USB4 ports, dual USB-A, HDMI 2.1, and UHS-II SD cover nearly every dongle-free scenario, but check your dock's wattage before ditching Lenovo's 140W charger.
Battery Life, Pricing, and Should You Buy It?
Despite housing an 18-core SoC, a Blackwell GPU, and a 165Hz OLED panel, the 92.5Wh battery holds up well across two distinct test methodologies:
- PCWorld (UL Procyon Office Productivity loop): 11 hours and 40 minutes, an impressive result for simulated Microsoft Office workloads.
- Tom's Hardware (150-nit web, video, and OpenGL loop): 10 hours and 30 minutes—edging out the Snapdragon X2 Elite Extreme-powered Zenbook A16 (10:26) and sitting just 13 minutes behind the Surface Laptop Ultra (10:43), though trailing the 16-inch MacBook Pro's 15 hours and 57 minutes.
Then there is the price tag—the biggest hurdle for any Windows buyer. Lenovo's US storefront starts the base Pro 9n (18-core N1X, 32GB RAM, 512GB Gen4 SSD, Windows 11 Home Arm64) at $2,999.99, roughly $400 above the $2,599 starting Surface Laptop Ultra. Upgrading storage to 1TB (Gen4) adds $200—putting reviewed 1TB configurations around $3,199 to $3,249.99—while 2TB (Gen5) adds $650 and Windows 11 Pro adds $50. Stepping up to the 20-core N1X adds $450 and unlocks 64GB (standard at $4,249) or 128GB (+$1,400), pushing maxed-out builds to $6,149.99. Although PCWorld initially saw it listed only via Lenovo directly, retail listings at Tom's Hardware and major electronics outlets show configurations appearing at Best Buy, Amazon, Walmart, Newegg, and Micro Center as well.
Who should buy the Lenovo Pro 9n? Windows developers, creators, and AI enthusiasts who want the lightest, quietest, and best-cooled RTX Spark laptop tested so far—complete with a calibrated 165Hz OLED, standout webcam, and real legacy ports—will find that the 18-core base chip hits the sweet spot in performance per dollar. Who should hold off? Anyone expecting MacBook Pro-class battery endurance, 4K pixel density, on-screen stylus drawing, or large 20B+ local LLM capacity without paying $4,249+ for 64GB of unified memory. For everyone else, Lenovo just proved that "entry-level" RTX Spark doesn't mean second-rate.
- Lenovo Pro 9n review: RTX Spark muscle meets Lenovo finesse PCWorld · 2026-11-23T14:00:00+00:00
- storagereview.com storagereview.com
- lenovo.com lenovo.com
