A laptop, tablet, wireless mouse, and coffee sit on a marble café table beside a small pouch and battery.
The Logitech Pebble Mouse 2 (model M350s) is a slim, quiet, cheap travel mouse. It runs on one AA battery. TechRadar's review says it is great in a laptop bag and a poor choice as a main desk or gaming mouse. Logitech's own documentation backs most of that up and adds some details a buyer should know before ordering.
A laptop, tablet, wireless mouse, and coffee sit on a marble café table beside a small pouch and battery. The verdict in brief​
Trusted Reviews calls it a decent, affordable mouse for use on the go or in the office. TechRadar's Jasmine Mannan reaches a similar conclusion. She wouldn't make it her primary mouse, but she plans to keep it as a dedicated on-the-road accessory. Her scorecard gives design and value 5 out of 5, and features and performance 3 out of 5.
Her testing ran for a few weeks. She used it for productivity on a Windows PC and an iPad, took it commuting, and tried some gaming. She dropped the gaming quickly because it didn't feel right. That is a subjective impression, not a benchmark. The review has no latency, noise or battery-drain measurements.
Design and comfort​
The mouse is flat and about 25mm tall, with a slight rise toward the palm end. The reviewer says it takes time to get used to and compares it unfavourably with a curved mouse, especially for a claw grip. She says it suits smaller hands and can become uncomfortable for larger hands over long sessions. She also found the feet a bit less slippery than those on her usual Razer Cobra Pro.
It has only three controls: left click, right click and a clickable wheel. The faceplate is held on by magnets and pulls off to reach the AA battery. Colour options in the review are pink, black and white, plus two limited designs (Study Buddy and Coffee Cat) by EdgyKatrina.
What Logitech's documentation adds​
Connectivity on Windows and other systems​
Logitech's support pages list Windows 10 and 11 or later, macOS 11+, iPadOS 14+, Android 9+, ChromeOS and Linux as compatible. The mouse uses Bluetooth Low Energy. The review mentions the separate Logi Bolt USB receiver, and Logitech's spec sheet confirms the receiver is not included. The box holds the mouse, a pre-installed AA battery and documentation.
This matters for desktops without Bluetooth. If your PC lacks it, you need to buy the Bolt receiver separately. Logitech says it plugs into a USB-A port and is paired through Logi Options+ or Logi Web Connect.
Pairing up to three devices​
Logitech's documented procedure for adding a device is:
  • Pick a channel with the Easy-Switch button.
  • Press and hold the button for three seconds until the LED blinks rapidly.
  • Finish pairing in the computer's Bluetooth settings.
  • After that, a short press switches between paired devices.
If a device drops off, Logitech says to hold the Easy-Switch button until the light blinks. That gives you a three-minute pairing window. The LED goes steady for 10 seconds once pairing succeeds.
Switching is a manual channel change. Logitech Flow is a separate feature that moves the cursor between two computers. It needs Logi Options+ installed on both.
Options+ and the middle button​
The only reprogrammable control is the middle click, and it needs the optional Logi Options+ app. Logitech documents these uses:
  • App-specific actions for apps such as Chrome, Spotify, WhatsApp and Zoom.
  • A gesture mode, where you hold the button while moving the mouse to navigate windows and desktops.
  • Scroll speed and direction settings.
  • Smooth scrolling, which is Windows-only.
  • Pointer speed adjustment.
  • Low-battery notifications.
So "no extra buttons" is true of the hardware. One of the three buttons can still do more than middle-click.
Sensor and report rates​
The sensor runs from 400 to 4,000 DPI. Logitech lists a Bluetooth report rate of 88–133Hz and a Logi Bolt rate of 125Hz. Dedicated gaming mice are commonly much faster, though that comparison is general industry knowledge and not from the sources here. These figures fit the reviewer's gaming caveat, but they don't prove how it performs in games.
Battery and noise claims​
Logitech rates battery life at up to 24 months from one non-rechargeable AA alkaline cell. TechRadar openly says it couldn't verify that in a few weeks of testing, so treat it as a manufacturer figure. Logitech also says Silent Touch Technology removes 90% of click noise. That is Logitech's claim. The reviewer only describes the clicks and wheel as much quieter and "haptic" in feel.
Spec sheet details​
TechRadar lists 106 × 58.7 × 26.62mm and 76g. Logitech's spec sheet gives a height of 106.7mm. It also says the 76g figure includes the receiver and an AA battery, and that the mouse alone weighs 53g without battery or receiver. Logitech lists button durability at 3 million cycles for the left and right buttons and 1 million for the wheel button.
Versus the original Pebble M350​
Logitech's support article lists these M350s changes:
  • Logi Options+ support and a customizable middle button.
  • Bluetooth 5.1 and Logi Bolt compatibility.
  • Three-device Easy-Switch instead of two.
  • A 4,000 DPI sensor instead of 1,000.
Retail listings show it dropped the bundled Unifying receiver. Best Buy customer-review commentary notes the M350s doesn't ship with a receiver and moved from Unifying to Logi Bolt. That is a customer review, not an official statement. It is more than a repaint, though shoppers who just want a simple mouse may find a discounted M350 enough.
Price and availability​
TechRadar's review contradicts itself on the Australian price (AU$54 in one place, AU$29 in another). I would not trust either figure without checking a current local retailer. The review gives $19.99 / £14.99 as the current price. It says launch prices were £24.99 / $29.99. Logitech's US store page showed $19.99 against a struck-through $24.99, labelled 20% off, with the Coffee Cat edition flagged as low stock. That is a live listing, not a permanent price. Limited editions are sold while supplies last and only in some markets.
Who should buy it​
A good fit:
  • Travelers and commuters who want a pocketable, quiet backup mouse.
  • People who juggle a laptop and a tablet or phone.
  • Anyone who is tired of recharging peripherals.
A poor fit:
  • Large-handed users and anyone who wants a sculpted ergonomic grip.
  • Buyers who need side buttons for workflows or games.
  • Gamers wanting low-latency performance. Look at the SteelSeries Rival Pro Mini, which TechRadar suggests.
  • Buyers wanting something even smaller. TechRadar points to the foldable Logitech Mobi Fold.
Bottom line​
At about $20, the Pebble Mouse 2 is easy to recommend as a bag mouse and hard to recommend as a main one. Check that your PC has Bluetooth or budget for a Bolt receiver. If you want the middle button to do something useful, install Logi Options+. Treat the two-year battery claim as a promise Logitech has made, not one anyone has tested yet.
Correction (November 19, 2026): The compatible-systems list originally included iOS 14+. Logitech's Pebble Mouse 2 M350s spec sheet does not list iOS, and Logitech states the mouse is not supported on iOS. The list has been corrected.
  1. Logitech Pebble Mouse 2 review: the perfect travel mouse but not a fit for gaming or productivity TechRadar 2026-11-20T01:00:00+00:00
  2. Specification - Pebble Mouse 2 M350s – Logitech Assistenza e download support.logi.com
  3. Getting Started - Pebble Mouse 2 M350s – Logitech Support + Download support.logi.com
